    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 403.0k Views 71 Watching
    • mitcorbM Offline
      mitcorb
      TIG:
      Thanks for the Example skp.
      I will try to provide you with examples as time permits. And I have been observing the Ruby console.
      My last experiment was with Polyline Divider as the profile and rails from Fredo's Bezier collection. I got the mesh ok, but of course, the math complexity reversed and crisscrossed the beginning and ending copies of the profile causing an oblate spheroid bulge(same shape as an American football) and wings like Pilou's harlequin flying fish. However, there was no comment in the console.
      Unfortunately the file is saved on my home machine. I will have to send it later.
      • jeff hammondJ Offline
        hey TIG
        here's a problem i've run into sometimes in an instance where it seems it should work. i'm only getting partial results in this case.
        any ideas?
        railQ.skp
          With the Jeff curve
          I have black crosses in the v7 😮
          and a false surface in the V6 😉
            using that same file, here's another weird thing i can't figure out. (a video's probably easiest for me because i don't have to type as much 😄)
            (at first, it shows the problem i was previously talking about)
            after that, i copy/move the profile and each rail the same amount along the red axis.. then end up with entirely different results.
            [flash=640,385:lwa8fguo]http://www.youtube.com/v/LN5Q9KjU9m0&hl=en_US&fs=1&[/flash:lwa8fguo]
              here's another question/problem i'm seeing..
              it seems like the grid should line up according to the corresponding segments of the two rails (the 2rails being at the top&bottom of this picture)
              click pic for larger
              like this, there's a kink being created in the surface along the left edge (which is somewhat visible in the inset picture..the surface drops down prior to rising because it appears the grid line is in the wrong place).. i guess i could make the surface bigger than needed and trim away some of the outer edges but that's not really optimal.. if it's fixable, i think it's worth fixing.
              thanks a ton for figuring all this stuff out ❗ 😄
                These problems seem to relate to the way the vertices in the the curves are ordered. They are reordered by the script before making the mesh... BUT obviously not well enough in some cases.
                If you explode the three curves in your railQ.skp in turn and then immediately weld them back into new curves they make the mesh perfectly... So my re-order and weld's must vary somewhere...
                I'll look at the ordering algorithms etc and release an update asap... 😒
                  Daniel S
                  Amazing TIG!!!
                  Thanky you!!!
                  How about an option to maintain height?
                  In your script shape curves scale in both the height and width dimensions. It will be great to have an option to remove the association between the height scaling from the width scaling for some models.
                  As an example: here is what your script make:
                  And here with Maintain height:
                  Daniel S
                    didn't even realize vertices were in a particular order 😄 .. is the grid example something to do with the order as well or something different?
                    daniel, that's going into a different territory in that the profile changes as it moves along the rails (the halfcircle doesn't remain the same in terms of shape).. if something like that is possible in SU then i have another request that's similar though different.. i'll hold off on asking for now 😄
                      Panga
                      Thanks a lot for this new tool, it'll be very usefull !!
                        When you want draw a "straight" curve line with some number of segments for fit with other curves for The TIG Plug
                        Draw a line, Right Click Divide then Weld = some painful 😮
                        A more quicky trick 💭
                        Draw a polyline of 1 segment by the BezierSpline of Fredo6
                        Then Right Click / Convert to Segmentor and enter the number of segments 😉
                        Et voilà 💚
                        It's a pity than we can't draw an arc circle "Straight" or scale it to 0 or Bulge =0 ! 😡
                        • MALAISEM Offline
                          MALAISE
                          TIG some Champagne ?
                          Amazing tool made by TIG 👍 👍
                          MALAISE
                          • X Offline
                            xrok1
                            great plug thanks!
                            maybe you could combine this with edges by edges then have the option to pick just 1 rail or 2? one more function, one less plugin! 😄
                            • X Offline
                              xrok1
                              Jeff, i found that if you explode the rails then weld them again that the problem is fixed. at least for me.
                                This is the temporary fix... I'm incorporating this into the code so the glitches don't happen... However that makes new glitches which I'm now fixing............. 🤓
                                • X Offline
                                  xrok1
                                  oops, sorry i could help. 😳
                                    xrok1 😉
                                    Your idea of being able to pick a profile and then pick just one rail is quite simple to do.
                                    For the next update I will add that option - you'll simply pick the profile and click on rail twice - if you pick another rail it works as now, if you pick the same rail again then it's assumed that it has a 'twin' at the other end of the profile and uses that... simplicity... 💭
                                    • utilerU Offline
                                      utiler
                                      TIG, probably a silly question, but what is the difference from this plugin and extrudebyedges?
                                      http://forums.sketchucation.com/viewtopic.php?f=180&t=20065&st=0&sk=t&sd=a&hilit=extrude+edges
                                      Is is simple that this script allows for more random meshes?
                                      Just Curious...
                                      • X Offline
                                        xrok1
                                        awsome.
                                        BTW, your plug is turning me into some kind of artsy fartsy... STOP IT! 😆
                                        • utilerU Offline
                                          utiler
                                          Thanks mate, clear as crystal..... 👍
                                          Just Curious...
                                          • mitcorbM Offline
                                            mitcorb
                                            @xrok1:
                                            for your excellent bowl and spork and "foon" model, did you use specific dimensions and scale? Or was this a free form experiment and the model elements proportioned by eye?
                                            I am preparing to use Extrude by Rails with dimensional or scale control and was wondering about this.
                                            Thanks, mitcorb
                                            • 19
                                            • 20
                                            • 2 / 20
