    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 403.0k Views 71 Watching
      Daniel S
      Amazing TIG!!!
      Thanky you!!!
      How about an option to maintain height?
      In your script shape curves scale in both the height and width dimensions. It will be great to have an option to remove the association between the height scaling from the width scaling for some models.
      As an example: here is what your script make:
      And here with Maintain height:
      Daniel S
      • jeff hammondJ Offline
        @tig said:
        These problems seem to relate to the way the vertices in the the curves are ordered. They are reordered by the script before making the mesh... BUT obviously not well enough in some cases.
        didn't even realize vertices were in a particular order 😄 .. is the grid example something to do with the order as well or something different?
        daniel, that's going into a different territory in that the profile changes as it moves along the rails (the halfcircle doesn't remain the same in terms of shape).. if something like that is possible in SU then i have another request that's similar though different.. i'll hold off on asking for now 😄
          Panga
          Thanks a lot for this new tool, it'll be very usefull !!
            When you want draw a "straight" curve line with some number of segments for fit with other curves for The TIG Plug
            Draw a line, Right Click Divide then Weld = some painful 😮
            A more quicky trick 💭
            Draw a polyline of 1 segment by the BezierSpline of Fredo6
            Then Right Click / Convert to Segmentor and enter the number of segments 😉
            Et voilà 💚
            It's a pity than we can't draw an arc circle "Straight" or scale it to 0 or Bulge =0 ! 😡
            • MALAISEM Offline
              MALAISE
              TIG some Champagne ?
              Amazing tool made by TIG 👍 👍
              MALAISE
              • X Offline
                xrok1
                great plug thanks!
                maybe you could combine this with edges by edges then have the option to pick just 1 rail or 2? one more function, one less plugin! 😄
                • X Offline
                  xrok1
                  Jeff, i found that if you explode the rails then weld them again that the problem is fixed. at least for me.
                    This is the temporary fix... I'm incorporating this into the code so the glitches don't happen... However that makes new glitches which I'm now fixing............. 🤓
                    • X Offline
                      xrok1
                      oops, sorry i could help. 😳
                        xrok1 😉
                        Your idea of being able to pick a profile and then pick just one rail is quite simple to do.
                        For the next update I will add that option - you'll simply pick the profile and click on rail twice - if you pick another rail it works as now, if you pick the same rail again then it's assumed that it has a 'twin' at the other end of the profile and uses that... simplicity... 💭
                        • utilerU Offline
                          utiler
                          TIG, probably a silly question, but what is the difference from this plugin and extrudebyedges?
                          http://forums.sketchucation.com/viewtopic.php?f=180&t=20065&st=0&sk=t&sd=a&hilit=extrude+edges
                          Is is simple that this script allows for more random meshes?
                          Just Curious...
                          • X Offline
                            xrok1
                            awsome.
                            BTW, your plug is turning me into some kind of artsy fartsy... STOP IT! 😆
                            • utilerU Offline
                              utiler
                              Thanks mate, clear as crystal..... 👍
                              Just Curious...
                              • mitcorbM Offline
                                mitcorb
                                @xrok1:
                                for your excellent bowl and spork and "foon" model, did you use specific dimensions and scale? Or was this a free form experiment and the model elements proportioned by eye?
                                I am preparing to use Extrude by Rails with dimensional or scale control and was wondering about this.
                                Thanks, mitcorb
                                • X Offline
                                  xrok1
                                  it was freeform 😆 but i can't see any reason it couldn't be dimensioned accurately if you wish to.
                                  • majidM Offline
                                    majid
                                    WOW TIG !!!! this is great!! thank you...you are killing me slowly 😉 you ruby programmers are changing SU to a verrry different app. !!!thank you mate again
                                      ExtrudeEdgesByEdges takes two groups - edges in them need not be continuous - and makes a mesh - it extrudes each edge in one set in the direction of the edges in the other - there is no 'followme' etc...
                                      ExtrudeEdgesByRails is similar BUT it only works on curves. It takes a selected profile and makes a mesh from it along two selected rails [or with the forthcoming version one rail picked twice - making it similar in that usage to EEbyEdges]. The main difference is that at each pair of 'nodes' [vertices] in the two rails the profile is placed and rotated and then scaled to fit between the rails, giving a smoothly curving mesh surface: also the number of 'nodes' in each rail is equalized if the number of vertices in the two rails is uneven - now making the 'lofting' of two unequally segmented rails possible...
                                      • mitcorbM Offline
                                        mitcorb
                                        TIG:
                                        What are the possibilities of being able to orbit and inspect the initial results of the extrusion on rails while going through the checklist so that decisions can be made in the workflow? Does this make sense?
                                          @mitcorb said:
                                          TIG:
                                          It's something that's not so easy to do... but I'll look at it - I currently have a version with most of the bugs ironed out - it'll be published soonest...
                                          • mitcorbM Offline
                                            mitcorb
                                            Thanks, TIG:
                                            You are a master.
                                            I am currently experimenting and learning this excellent tool.
                                            • 19
                                            • 20
                                            • 3 / 20
