    Render this: Fountain
    56 Posts 24 Posters 16.8k Views 24 Watching
    • B
      bmscmoreira
      The mystery behind the sparkle disappearing is nothing compared to the strange reflection appearing on the water surface...
      πŸ˜† πŸ˜† πŸ˜†
      http://www.brunomoreira.net
      • massimoM
        massimo Moderator
        A detail. With HDRI background lighting. My first try with water. πŸ˜„
        • EarthMoverE
          EarthMover
          Another slightly more dramatic try. Also a couple from a previous render.
          All vray for Max. A good bit of PP on the first one using photoshop and Toy camera. 2nd set is Raw output using HDRI + Vray sun.
          Content Creator at Skapeup
            sepo
            That Audi render looks very good.
            • michaliszissiouM
              michaliszissiou
              Some one asked me why I post models made in blender here. But these have modeled just for this purpose. If I want to render them in blender (I did) then can use a higher level of faces-details.
              So this fountain is not modeled in SU (see topology on att.), so importing it to MAX and render with vray, has really nothing to do with SU. Its an interesting work flow though. Always the capability to export SU models to other apps. If this is possible (for a complicated model).
              So earthmother, these are great renders, but why do you need to import a model in SU and export it in MAX?
              • EarthMoverE
                EarthMover
                @michaliszissiou said:
                So ??earthmother??, these are great renders, but why do you need to import a model in SU and export it in MAX?
                I did not create the fountain. I downloaded the posted .skp and used the component stringer plugin that Chris just made to model the fountain spray. The idea behind the thread is to use your favorite render app to render the posted model. For me this is Vray and I happen to have it for 3ds Max. I bought Max before I even knew sketchup existed. Now that I model in SU almost exclusively, I typically just use max for rendering and scene staging, utilizing it's high poly support to render my SU models. No different than someone exporting out of sketchup into Vue or Maxwell studio. So to answer your question, my workflow is not Max to SU to Max, as this would be quite silly. 90% of what I model starts in SU....I'm not sure what program the fountain was modeled in.
                • C
                  Click Draw
                  Hey Adam,
                  Are you using Modo much these days? Just curious cause I'm still thinking about getting a second modeler. Great renders as always by the way.
                  Thanks,
                  Jeff
                  Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                  • massimoM
                    massimo Moderator
                    Another shot with a different HDRI and a little spot-light on ivy.
                    • U
                      Ultimatez 32
                      I think the fountain is made in SU, with the usual tools and SDS (check the dome) Is that right solo?
                      Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                      • Al HartA
                        Al Hart
                        I like this water effect.
                        Al Hart
                        IRender nXt from Render Plus
                        • massimoM
                          massimo Moderator
                          Thanks Al. πŸ˜„
                          • olisheaO
                            olishea
                            massimo please could you post a sketchup view of your scene? is the jet of water a clipmap? looks very impresive indeed, well done!
                            earthmover these simply are beautiful, audi scene is awesome!
                            oli
                            • EarthMoverE
                              EarthMover
                              Thanks Oli! I think one of the biggest advantages of rendering in Max is that you can use an HDRI and display it in the background of the viewport. You can then move the Vray sun into position so that it is comparable to the HDRI light source. In the Audi render, the HDRI showed a light source that was casting a shadow on the adjacent buildings, so in Max I was able to draw a big box behind my camera and drop the sun just slightly above it. This effect of shadow casting based on the HDRI, is what I think added a lot to the realism of the image. It would be nice if the Twilight guys figure out how to do this inside of the SU.
                              @click draw said:
                              Hey Adam,
                              Thanks,
                              Jeff
                              Hey Jeff. Thanks! I haven't used it much of late. Played with some sculpting the other day, but nothing serious. Honestly I'm at the point where I think I need to rewatch the tutorials as I forget half the stuff I learned previously, and I haven't had the energy to relearn lately.
                                Some mosaics πŸ˜„
                                  redsteel
                                  ...a fountain? ...a few renders? ...sounds fun πŸ˜„ so here it is something a little different πŸ˜‰
                                  • massimoM
                                    massimo Moderator
                                    Thanks Oli. The jet is not a clipmap. I made the water effect mixing three different models: one for the jet, one for the rings and one for the "boiling water" in the middle. The models are in obj format and I've composed the scene in Kerkythea so i can't post a SU view, sorry. You can find the water models I used here. πŸ˜„
                                    Kerkythea view
                                      remon_v
                                      let there be water:
                                      http://i22.photobucket.com/albums/b336/remon_v/2.jpg
                                      modo render, just started learning modo
                                      only pp was curves+photofilter
                                      • michaliszissiouM
                                        michaliszissiou
                                        All these are fantastic renders. So this contest lol, is interesting. Here's some more models in .3ds format like this fountain.
                                        http://www.archidom.net/ddd/mod_dek5.htm
                                          Sheik
                                          SU+Realflow4+Maxwell
                                          http://i832.photobucket.com/albums/zz242/Sheiken/FountainConc2.jpg
                                            d12dozr
                                            That is amazing! ...some color would make it perfect πŸ˜„
                                            http://goo.gl/f7ooYh
                                            • 3 / 3
