    Render this: Fountain
    56 Posts 24 Posters 15.1k Views 24 Watching
      sepo
      That Audi render looks very good.
      • michaliszissiouM Offline
        michaliszissiou
        Some one asked me why I post models made in blender here. But these have modeled just for this purpose. If I want to render them in blender (I did) then can use a higher level of faces-details.
        So this fountain is not modeled in SU (see topology on att.), so importing it to MAX and render with vray, has really nothing to do with SU. Its an interesting work flow though. Always the capability to export SU models to other apps. If this is possible (for a complicated model).
        So earthmother, these are great renders, but why do you need to import a model in SU and export it in MAX?
        • EarthMoverE Offline
          EarthMover
          @michaliszissiou said:
          So ??earthmother??, these are great renders, but why do you need to import a model in SU and export it in MAX?
          I did not create the fountain. I downloaded the posted .skp and used the component stringer plugin that Chris just made to model the fountain spray. The idea behind the thread is to use your favorite render app to render the posted model. For me this is Vray and I happen to have it for 3ds Max. I bought Max before I even knew sketchup existed. Now that I model in SU almost exclusively, I typically just use max for rendering and scene staging, utilizing it's high poly support to render my SU models. No different than someone exporting out of sketchup into Vue or Maxwell studio. So to answer your question, my workflow is not Max to SU to Max, as this would be quite silly. 90% of what I model starts in SU....I'm not sure what program the fountain was modeled in.
          Content Creator at Skapeup
            Click Draw
            Hey Adam,
            Are you using Modo much these days? Just curious cause I'm still thinking about getting a second modeler. Great renders as always by the way.
            Thanks,
            Jeff
            Have I mentioned how much of a laugh I get out of some of the Signatures on here!
            • massimoM Offline
              massimo Moderator
              Another shot with a different HDRI and a little spot-light on ivy.
              • U Offline
                Ultimatez 32
                I think the fountain is made in SU, with the usual tools and SDS (check the dome) Is that right solo?
                Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                • Al HartA Offline
                  Al Hart
                  I like this water effect.
                  Al Hart
                  IRender nXt from Render Plus
                  • massimoM Offline
                    massimo Moderator
                    Thanks Al. πŸ˜„
                    • olisheaO Offline
                      olishea
                      massimo please could you post a sketchup view of your scene? is the jet of water a clipmap? looks very impresive indeed, well done!
                      earthmover these simply are beautiful, audi scene is awesome!
                      oli
                        EarthMover
                        Thanks Oli! I think one of the biggest advantages of rendering in Max is that you can use an HDRI and display it in the background of the viewport. You can then move the Vray sun into position so that it is comparable to the HDRI light source. In the Audi render, the HDRI showed a light source that was casting a shadow on the adjacent buildings, so in Max I was able to draw a big box behind my camera and drop the sun just slightly above it. This effect of shadow casting based on the HDRI, is what I think added a lot to the realism of the image. It would be nice if the Twilight guys figure out how to do this inside of the SU.
                        @click draw said:
                        Hey Adam,
                        Thanks,
                        Jeff
                        Hey Jeff. Thanks! I haven't used it much of late. Played with some sculpting the other day, but nothing serious. Honestly I'm at the point where I think I need to rewatch the tutorials as I forget half the stuff I learned previously, and I haven't had the energy to relearn lately.
                          Some mosaics πŸ˜„
                            redsteel
                            ...a fountain? ...a few renders? ...sounds fun πŸ˜„ so here it is something a little different πŸ˜‰
                            • massimoM Offline
                              massimo Moderator
                              Thanks Oli. The jet is not a clipmap. I made the water effect mixing three different models: one for the jet, one for the rings and one for the "boiling water" in the middle. The models are in obj format and I've composed the scene in Kerkythea so i can't post a SU view, sorry. You can find the water models I used here. πŸ˜„
                              Kerkythea view
                                remon_v
                                let there be water:
                                http://i22.photobucket.com/albums/b336/remon_v/2.jpg
                                modo render, just started learning modo
                                only pp was curves+photofilter
                                  michaliszissiou
                                  All these are fantastic renders. So this contest lol, is interesting. Here's some more models in .3ds format like this fountain.
                                  http://www.archidom.net/ddd/mod_dek5.htm
                                    Sheik
                                    SU+Realflow4+Maxwell
                                    http://i832.photobucket.com/albums/zz242/Sheiken/FountainConc2.jpg
                                      d12dozr
                                      That is amazing! ...some color would make it perfect πŸ˜„
                                      http://goo.gl/f7ooYh
                                      • 3 / 3
