    Render this: Fountain
    56 Posts 24 Posters 16.8k Views 24 Watching
    • C
      Click Draw
      Hey Adam,
      Are you using Modo much these days? Just curious cause I'm still thinking about getting a second modeler. Great renders as always by the way.
      Thanks,
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
      • massimoM
        massimo Moderator
        Another shot with a different HDRI and a little spot-light on ivy.
        • U
          Ultimatez 32
          @michaliszissiou said:
          Some one asked me why I post models made in blender here. But these have modeled just for this purpose. If I want to render them in blender (I did) then can use a higher level of faces-details.
          So this fountain is not modeled in SU (see topology on att.), so importing it to MAX and render with vray, has really nothing to do with SU. Its an interesting work flow though. Always the capability to export SU models to other apps. If this is possible (for a complicated model).
          So earthmother, these are great renders, but why do you need to import a model in SU and export it in MAX?
          I think the fountain is made in SU, with the usual tools and SDS (check the dome) Is that right solo?
          Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
          • Al HartA
            Al Hart
            I like this water effect.
            Al Hart
            IRender nXt from Render Plus
            • massimoM
              massimo Moderator
              Thanks Al. πŸ˜„
              • olisheaO
                olishea
                massimo please could you post a sketchup view of your scene? is the jet of water a clipmap? looks very impresive indeed, well done!
                earthmover these simply are beautiful, audi scene is awesome!
                oli
                • EarthMoverE
                  EarthMover
                  Thanks Oli! I think one of the biggest advantages of rendering in Max is that you can use an HDRI and display it in the background of the viewport. You can then move the Vray sun into position so that it is comparable to the HDRI light source. In the Audi render, the HDRI showed a light source that was casting a shadow on the adjacent buildings, so in Max I was able to draw a big box behind my camera and drop the sun just slightly above it. This effect of shadow casting based on the HDRI, is what I think added a lot to the realism of the image. It would be nice if the Twilight guys figure out how to do this inside of the SU.
                  @click draw said:
                  Hey Adam,
                  Thanks,
                  Jeff
                  Hey Jeff. Thanks! I haven't used it much of late. Played with some sculpting the other day, but nothing serious. Honestly I'm at the point where I think I need to rewatch the tutorials as I forget half the stuff I learned previously, and I haven't had the energy to relearn lately.
                  Content Creator at Skapeup
                    Some mosaics πŸ˜„
                      redsteel
                      ...a fountain? ...a few renders? ...sounds fun πŸ˜„ so here it is something a little different πŸ˜‰
                      • massimoM
                        massimo Moderator
                        Thanks Oli. The jet is not a clipmap. I made the water effect mixing three different models: one for the jet, one for the rings and one for the "boiling water" in the middle. The models are in obj format and I've composed the scene in Kerkythea so i can't post a SU view, sorry. You can find the water models I used here. πŸ˜„
                        Kerkythea view
                          remon_v
                          let there be water:
                          http://i22.photobucket.com/albums/b336/remon_v/2.jpg
                          modo render, just started learning modo
                          only pp was curves+photofilter
                          • michaliszissiouM
                            michaliszissiou
                            All these are fantastic renders. So this contest lol, is interesting. Here's some more models in .3ds format like this fountain.
                            http://www.archidom.net/ddd/mod_dek5.htm
                              Sheik
                              SU+Realflow4+Maxwell
                              http://i832.photobucket.com/albums/zz242/Sheiken/FountainConc2.jpg
                                d12dozr
                                That is amazing! ...some color would make it perfect πŸ˜„
                                http://goo.gl/f7ooYh
                                • 3 / 3
