    Render this: Fountain
    56 Posts 24 Posters 15.1k Views 24 Watching
    • michaliszissiouM Offline
      michaliszissiou
      @solo said:
      very cool image.
      You broke my fountain!!
      Would be cool to see a SP explosion, where the fountain busts into hundred of flying bits.
      Now tell me pete, do I promote another app? πŸ˜†
      Hey Boofredlay, nice scene. Is this in the alley of the Stoppels?
      • olisheaO Offline
        olishea
        boofredlay that image is amazing! so funny 🀣
        oli
        • GarethG Offline
          Gareth
          @solo said:
          Another one, calm water (pump bust)
          I used some (excuse the shameless promotion) Solopack plants.
          nice one Pete.....but it needs a Flamingo.....!!! πŸ˜†
            richcat
            @earthmover said:
            Nice Rich! Thanks for sharing the fountain spray you found. Ivy looks nice on the wall...I would add a concrete texture to the fountain itself with a little dirt on it.
            Thanks - Looking for a nice concrete/similar texture at the moment. It was a nice marble texture but didn't show up. 😳
            @ecuadorian said:
            Richard, that's some of the best non post production grass I've seen in this forum. πŸ‘
            Is it a component composed of several clipmaps spread around with component spray? Or a full 3D component? Is that ivy from the ivy generator? I know, too many questions... πŸ’š Hey, that grass and ivy would make a nice tutorial. πŸ˜›
            Thanks again for the comments, but 😒 sorry to disappoint as its part of the rendering software, that you apply as a property to sketchup materials, a bit similar to the free tree program from Al(but when rendered comes out 3d), Its a ground cover version that I have adapted for ivy. Maybe Al would consider a ground cover/ivy version for sketchup. ❓
            • EarthMoverE Offline
              EarthMover
              Quick scene with HDRI background lighting and image. Evermotion Audi and light posts added for flair.
              Content Creator at Skapeup
              • U Offline
                Ultimatez 32
                looks really realistic, what renderer is that?
                Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                • Al HartA Offline
                  Al Hart
                  @richcat said:
                  We have that in the plans. (To create a custom, tileable material).
                  However, when I tried to put ground cover under my fountain it took so long to render that I gave up. (Ground cover works by generating thousands of leaves and flowers at render time - so it doesn't work well yet for large areas)
                  But it is very impressive if you were able to get it to work or Ivy.
                  Al Hart
                  IRender nXt from Render Plus
                    bmscmoreira
                    The mystery behind the sparkle disappearing is nothing compared to the strange reflection appearing on the water surface...
                    πŸ˜† πŸ˜† πŸ˜†
                    http://www.brunomoreira.net
                    • massimoM Offline
                      massimo Moderator
                      A detail. With HDRI background lighting. My first try with water. πŸ˜„
                        EarthMover
                        Another slightly more dramatic try. Also a couple from a previous render.
                        All vray for Max. A good bit of PP on the first one using photoshop and Toy camera. 2nd set is Raw output using HDRI + Vray sun.
                          sepo
                          That Audi render looks very good.
                            michaliszissiou
                            Some one asked me why I post models made in blender here. But these have modeled just for this purpose. If I want to render them in blender (I did) then can use a higher level of faces-details.
                            So this fountain is not modeled in SU (see topology on att.), so importing it to MAX and render with vray, has really nothing to do with SU. Its an interesting work flow though. Always the capability to export SU models to other apps. If this is possible (for a complicated model).
                            So earthmother, these are great renders, but why do you need to import a model in SU and export it in MAX?
                              EarthMover
                              @michaliszissiou said:
                              So ??earthmother??, these are great renders, but why do you need to import a model in SU and export it in MAX?
                              I did not create the fountain. I downloaded the posted .skp and used the component stringer plugin that Chris just made to model the fountain spray. The idea behind the thread is to use your favorite render app to render the posted model. For me this is Vray and I happen to have it for 3ds Max. I bought Max before I even knew sketchup existed. Now that I model in SU almost exclusively, I typically just use max for rendering and scene staging, utilizing it's high poly support to render my SU models. No different than someone exporting out of sketchup into Vue or Maxwell studio. So to answer your question, my workflow is not Max to SU to Max, as this would be quite silly. 90% of what I model starts in SU....I'm not sure what program the fountain was modeled in.
                                Click Draw
                                Hey Adam,
                                Are you using Modo much these days? Just curious cause I'm still thinking about getting a second modeler. Great renders as always by the way.
                                Thanks,
                                Jeff
                                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                • massimoM Offline
                                  massimo Moderator
                                  Another shot with a different HDRI and a little spot-light on ivy.
                                  • U Offline
                                    Ultimatez 32
                                    I think the fountain is made in SU, with the usual tools and SDS (check the dome) Is that right solo?
                                    • Al HartA Offline
                                      Al Hart
                                      I like this water effect.
                                      Al Hart
                                      • massimoM Offline
                                        massimo Moderator
                                        Thanks Al. πŸ˜„
                                        • olisheaO Offline
                                          olishea
                                          massimo please could you post a sketchup view of your scene? is the jet of water a clipmap? looks very impresive indeed, well done!
                                          earthmover these simply are beautiful, audi scene is awesome!
                                          oli
                                            EarthMover
                                            Thanks Oli! I think one of the biggest advantages of rendering in Max is that you can use an HDRI and display it in the background of the viewport. You can then move the Vray sun into position so that it is comparable to the HDRI light source. In the Audi render, the HDRI showed a light source that was casting a shadow on the adjacent buildings, so in Max I was able to draw a big box behind my camera and drop the sun just slightly above it. This effect of shadow casting based on the HDRI, is what I think added a lot to the realism of the image. It would be nice if the Twilight guys figure out how to do this inside of the SU.
                                            @click draw said:
                                            Hey Adam,
                                            Thanks,
                                            Jeff
                                            Hey Jeff. Thanks! I haven't used it much of late. Played with some sculpting the other day, but nothing serious. Honestly I'm at the point where I think I need to rewatch the tutorials as I forget half the stuff I learned previously, and I haven't had the energy to relearn lately.
                                            • 2 / 3
