    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.0m Views 345 Watching
      Daniel S
      When you make a group with SketchUp the bounding box will be always aligned to the axes.
      With this plugin you can choose the orientation of this bounding box but only for making deformations.
      Is it possible to make the script work to group the geometry with the selected user orientation box?
      Daniel S
      • fredo6F Offline
        Daniel S
        Daniel,
        It is probably possible, though a new function.
        I have also seen a request from Pilou to generate the geometry of the bounding box.
        Do you see any other function related to playing with Bounding boxes?
          Daniel S
          I don´t see other function related to playing with Bounding boxes. But actually I use a lot this plugins to generate groups:
          Explode2Groups.rb (TIG)
          http://forums.sketchucation.com/viewtopic.php?p=15421
          UnfoldPart1.rb (TIG) (It´s a very old script.. it was the first step for a unfold plugin but is very handy in lot of models)
          "Select a group containing faces and choose 'Unfold Part 1' from the Plugins menu. The faces become separate groups(...)"
          They are very usefull and very effective.. but in some situations you need to generate the groups not aligned to the axes.
          Gráfico1.jpg 😒
          Daniel S
            Daniel S
            @xrok1 said:
            Daniel, you could make a component instead of a group, then align axis.
            Thank you xrok1.. I will try that.
            Daniel S
            • X Offline
              xrok1
              Fredo, it seems that the target scaling doesn't like small measures under and inch or two, sometimes i have to scale like 6" or so past so that i can then scale back to the place i originally intended. is this a known issue?
                Kuddl
                Hi Fredo,
                I think that's a little bug in FredoScale!
                "Make Groups and unique component"
                Unique Component is OK, but groups remain unchanged.
                Is this normal? 😳
                Thanks for this great plugin! 👍
                Kuddl
                • fredo6F Offline
                  @kuddl said:
                  Hi Fredo,
                  Is this normal? 😳
                  Kuddl
                  In SU7, Groups are made unique only when you Edit them and change the geometry. So the concept is a little bit different.
                  • fredo6F Offline
                    [Chinese version - 11 Nov 09 - 21:50 CET
                    Diweiman and the SuBAR_CLT team at SketchupBar have translated the script into Chinese.
                    See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=17948#p144180).
                      gavvy
                      😮 just fit me !
                      • mariochaM Offline
                        mariocha
                        Just wanted to say that this plugin, amongs others, is really worth a donation, imho. 😄
                        The parametric feature of the tools is so useful. !
                        %(#008000)[Mario C.
                        • fredo6F Offline
                          [Update to Chinese version - 26 Nov 09 - 21:50 CET
                          The SuBAR_CLT team at SketchupBar have updated the translation the script into Chinese.
                            jpurdy77
                            unable to use plugin fredoscale on a mac, is there a help/ instructions on what to do.
                            thanks
                            • Chris FullmerC Offline
                              Hi James, re-read the first post of this thread. It describes a lot. And it has a .pdf file that includes installation help.
                              Or if you were a bit more specific, more specific help might returned too. Its unclear if you just can't find the downlaod file, can't figure out how to install it, or can't use the tools once its installed. Plenty of places people tend to get lost in the process.
                                jpurdy77
                                ok, well i tried for a hour or so and im running a mac, the help is for windows or so it seems. downloaded it but cant seem to get it running in sketch up. must be something wrong, thus a mac step y step guid would help.
                                James
                                  ok, so you're looking for installation help then, right? Where did you place the files? Perhaps you could take screenshot of the plugins folder if that is where youn put them?
                                    mics_54
                                    Edit postDelete postReport this postReply with quoteRe: [Plugin Library] LibFredo6 - v3.4b - 11 Nov 09
                                    by mics_54 on Sun Dec 13, 2009 6:54 pm
                                    I hope this is the right place to post a question about fredo scale.
                                    I find the tool very useful and will start by thanking you for making it. I would like to thank you with a donation when things are more fiscally condusive.
                                    Now, I build cabinetry etc and often a face frame on a cabinet will have multiple drawers. I have used fredoscale to stretch the cabinets to a taller dimension (or shorter as the case may be) with complete success with all members maintaining their original dimensions except the height or width. However on face fronts with multiple openings I can not find a way to stretch the front taller and have the openings for multiple drawers increase uniformly.
                                    Can FS do this or am I asking too much at this time? I just wondered if I wasn't using the tool to it's capabilities.
                                    tia!
                                    • fredo6F Offline
                                      Maybe a picture would help to understand the exact issue you have.
                                      Just in case, did you try with the Divider (key F4)? This allows positioning the pivot stretch plane where you need.
                                        mics_54
                                        No I didn't and I thought I saw something regarding that but I couldn't find it again. I am assuming there is only one stretch plane so I would need to use it 4 times on a face front with four openings. Here is an image the front and cabinet.
                                          mics_54
                                          Fredo, I found the video and it answered my questions thanks. I guess I would have to calculate the adjustmet in the size of each drawer opening and resize the front accordingly x4.
                                          Thanks again.
                                          • Y Offline
                                            ygcl
                                            Well,but don`t download.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 58
                                            • 59
                                            • 19 / 59
