    [Plugin] Sculpt Tools v 1.0...
    100 Posts 51 Posters 134.3k Views 50 Watching
      markitekt
      This a fantastic plugin! It really works great with SketchUp's sandbox tools. There's so much more I need to explore with this. It really opens the door to more organic forms. I look forward to its future development and tutorials.
      Mark P.
      • X Offline
        xrok1
        i'd love to see pictures of some of the things people have made with this plugin. 😄
        • majidM Offline
          majid
          does any one is going to make a document please?
          or does anyone knows how that "lock" feature works?
            dacad
            does anyone know how to make the "planar lock work"?
            David
              Jim
              BTM,
              Just my opinion here, but it might be better to have a single entry in the Extensions list that toggles the tools as a set instead of having an entry for each tool in the set. Same with your Merge tools.
              • majidM Offline
                majid
                David
                me 2 😄
                  BTM
                  David
                  me 2 😄
                  It should work by clicking 3 times to make the face which defines the plane (an infinite face), and then when you use a sculpt tool, any vertices on that plane are 'locked' to it, and cannot move from it.
                    CPhillips
                    Welcome back BTM! Awsome plugin.
                    • mitcorbM Offline
                      mitcorb
                      I would like to repeat an earlier post:
                      [Question-- Is the "lagline" setting in the dialog a selection of a visual cue? If it is, I have not seen it.] Meaning I could not get it to work.
                      mitcorb
                        BTM
                        mitcorb
                        It's not a visual cue. It's a feature to allow sculpting even if there's a lot of lag; when you sculpt, it will affect not only the vertices around the cursor, but also around the line between the cursor and the last cursor position:
                        You can draw fast with lagline on.
                        • mitcorbM Offline
                          mitcorb
                          Thanks -BTM:
                          I think I understand what you mean.
                          As for drawing fast, that would be when I get a new desktop system. My current machine has a Pentium 4 with 1.6Ghz.
                          • W Offline
                            wsms
                            thanks for everybody who build this plugin!
                            i am just trying to sculpt something out~
                            the only problem is the speed of my computer...
                              BTM
                              ok, I'm starting work on sculpt tools again; a new tool I'm probably going to add in the next release is flatten. I've got it working, but It's not finished yet.
                              It flattens nearby points to the plane they best fit. If you hold shift, it will keep the previous plane, so you can create a flat surface. It has a setting which allows it to not affect points on the other side of the plane, so you can sculpt somewhat hard surfaces in the model, like in this image.
                              ( though, with sketchup, it's admittedly not very useful)
                              an 'icosphere', with flatten used in different places.
                              I'll see if I can get an inflate/ deflate tool in the next release alswell.
                              • X Offline
                                xrok1
                                SWEET!
                                🤢 sorry got a little too excited 🤣
                                • majidM Offline
                                  majid
                                  wowww it is unbelievable ...man... the only remaining thin is documenting the plugin... is there anyone here ,so experienced, to do that?
                                  • E Offline
                                    ENG. YASEEN
                                    Wow It's working in SU Pro7 ..... That's Great 😍
                                    Thank u 👍
                                    Sculpt By SU Pro7
                                    My Website:
                                    http://xyz4studio.blogspot.com/
                                    • boofredlayB Offline
                                      boofredlay
                                      Is anybody using this in their work flow? If so how and to what success?
                                      I am surprised we have not seen a bunch of examples so far.
                                      • majidM Offline
                                        majid
                                        I am wondering that if it is possible to have a tool for adding detail , or even reducing the details, while keeping the surface smoothness (if it is a curved surface).
                                        maybe something like the picture
                                          Sandbox Tool->Add Details
                                            troyhome
                                            I wish sandbox did more thank only triangulation
                                            IOviz.com
                                            SU Pro 2024 PC
                                            • 2 / 5
