    [Plugin] TrueTangents v3.0
    95 Posts 34 Posters 120.3k Views 34 Watching
      v1.7 now available http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
      With new filletarc tool to fillet a selected arc/circle to a selected line/cline, to a radius given in a dialog, clines/cpoints for centers/tangent-points etc for the 4 or 8 possible fillets depending on whether or not the line intersects the arc...
      • jeff hammondJ
        damn! perfect!
        thanks a ton TIG
        • simon le bonS
          simon le bon
          filletarc tool: what a good idea πŸ‘
          filletarc
          Select an arc/circle and a cline/line (aka guide-line)
          Run filletarc
          unfortunately, it doesn't appear for me in the plugin menu 😞
          (what am I doing wrong?) ❓ simon
          • jeff hammondJ
            @simon le bon said:
            I'm a little bit disappointed by the fact that depending on the radius is, the tangent lines cannot join perfectly ( certainly due to segmentation of the circles)
            but that's the whole point πŸ˜„
            the cpoints are placed in the correct place so you can the draw (or redraw) the arcs at the true position. Hence - true tangents
              Here's v1.8 that fixes the missing menu item glitch - there are now 5 !
              My latest tool "Fillet Arc [Arc+Line|Cline]" should now appear in the Plugins menu at the end of the rest 😳
              At the last moment just before I uploaded v1.7 I changed that item's text to read "Fillet Arc [Arc+Line/Cline]" forgetting that a '/' in a menu name stops it appearing - at least on PCs...
              Note that typing filletarc in the Console also runs it...
              Sorry for the confusion... πŸ˜•
                filletarc
                Run filletarc
                There should be a group of 4+1 tools in the Plugins menu with TrueTangents et al the last one is FilletArc... Alternatively select an arc/circle and a line/cline and type filletarc in the Ruby Console - it should work... If not, then there might be a problem with the install...
                • utilerU
                  utiler
                  Thank you TIG, your generosity is greatly appreciated!!!! πŸŽ‰
                  Just Curious...
                    @Tig
                    Why not make a submenu?
                    because I have yet hundred of plugs 😳 and a big list screen πŸ˜’
                    And have you somewhere a list of your different Ruby plugs? β˜€
                      Pilou
                      Just what I was thinking... It started as one item and grew... I'll make a sub-menu and add the 5 into it in the next release...
                      • jeff hammondJ
                        [V1.9 submenu & individual tools are working well on mac]
                        • BepB
                          Bep
                          folding req.skp
                          Hallo Tig
                          I noticed your keep on working to make this plugin perfect.
                          The problem I would realy like to get solved with this ruby is that when you have got a drawing of an unfolded 3D structure where only faces are field-surveyed it is impossible to accurately fold it to a 3D model.
                          It would be an addition to your true Tangents Ruby, and the true intersections ruby
                          this time ,to find the true intersection points of two circles in 3D .
                          Once these points are found you would have I interference point to rotate the faces to.
                          And it would be possible to measure the angle of rotation these faces should be rotated .
                          I hope you wil find time to look into this.
                          Thanks for all your efforts.
                          Greetings ,Bep van Malde
                          "History is written by the winners"
                          • jeff hammondJ
                            i did around 15 hrs of modeling this weekend and used truetangents 9-10 times..
                            man, it's waay better doing certain things with this plugin.. way better!
                            thanks again for this one
                              v1.9 now has a sub-menu in Plugins 'Tangent-Tools...' that accesses the 5 tools...
                              404 Not Found
                              (forums.sketchucation.com)
                              • simon le bonS
                                simon le bon
                                Hi Tig,
                                Thanks to reply so quickly each time πŸ‘
                                But sorry to disturb you with my small problem.
                                There should be a group of 4 tools in the Plugins menu with TrueTangents et al the last one is FilletArc...
                                Well.. if I make the account:
                                %(#0000BF)[>truetangents
                                commontangents
                                trueintersections
                                tangentialarcs
                                filletarc]
                                There should be a group of 5 tools ❓ isn't it?
                                but you produce so many tools that you may lose the account πŸ˜†
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolth.jpg
                                Yes it does!
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt2th.jpg
                                (please clic the pic to zoom)
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt3th.jpg
                                Thank you dear Tig to be so kind and generous with S'Up Community...
                                ++simon.
                                • simon le bonS
                                  simon le bon
                                  πŸ‘ πŸ˜‰ this tool is a ruby!
                                  I'm not sure to understand right to be correct 😳 !!
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt004th.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt005th.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt006th.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt007th.jpg
                                  Is this the right way?
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt008th.jpg
                                  Am I correct if I follow the tangent inference this way?
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt009th.jpg
                                  The possibilities are very numerous
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt010th.jpg
                                  😎 simon
                                  • jeff hammondJ
                                    the const. points show where a real, non-segmented circle would cross at key points.. these are basically layout tools for people that need real world measurements when building arcs and if your use of SU is mostly to draw things that are organic and/or don't need to be 100% precise then you probably have no real need for TrueTangents (ie, if you're drawing a building simply for representational purposes then it doesn't matter if a wall is 3/4" too thick.. if you're drawing a building that is going to be built in real world using the SU print, then it better be exact or there's going to be a lot of cussing on the jobsite)
                                    if you really had a need for this plugin then i don't think there would be any question about it's usage.. you would see its benefits immediately.
                                    • jeff hammondJ
                                      [btw, it's the top of a pool.. a down&dirty render of what's happening with that drawing]
                                      • jeff hammondJ
                                        for example ---
                                        without using truetangents, modify this SKP to correspond with this jpg.. the stuff in red is missing in the attached .skp.. (and it is possible to do without TrueTangents but it's a major headache)
                                        if you decide to do this with TrueTangents, you would use the 4th addition.. Tangential Arcs [Arcs+Line]
                                        tt_quiz.skp
                                        • jeff hammondJ
                                          here's a video showing how you might use truetangents to finish that skp.. (fwiw, i'm using didier bur's arc ruby to draw my arcs.. included in that is a 'center + two points' option in which you select the centerpoint and the two ends of the desired arc.. all of these points are given to me via truetangents)
                                          [flash=680,378:1hkwq6mh]http://www.youtube.com/v/OWsg1q4HcKU&hl=en&fs=1&" type=[/flash:1hkwq6mh]
                                            Cool video! 😎
                                            Yes that is tricky and thanks to Tig for this new true gem! β˜€
                                            • 3 / 5
