    [Plugin] TrueTangents v3.0
    95 Posts 34 Posters 118.9k Views 34 Watching
    • mitcorbM Offline
      mitcorb
      Hmmm. Looks like it's time for me to check this out. Thank you, again, TIG
      • jeff hammondJ Offline
        oh man, that's great!
        i basically have two situations where i need to make the double benders and this fully covers one of those (the one that's much harder for me to figure out manually). Thanks so much for adding this to TrueTangents!
        [the other situation is when both arcs are a known radii but i can resolve that one easier.. still, if you think you could add the dialog box etc, that'd be cool too.. surely some other people would like that type of fillet tool in SU, no?]
          v1.7 now available http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
          With new filletarc tool to fillet a selected arc/circle to a selected line/cline, to a radius given in a dialog, clines/cpoints for centers/tangent-points etc for the 4 or 8 possible fillets depending on whether or not the line intersects the arc...
            damn! perfect!
            thanks a ton TIG
            • simon le bonS Offline
              simon le bon
              filletarc tool: what a good idea ๐Ÿ‘
              filletarc
              Select an arc/circle and a cline/line (aka guide-line)
              Run filletarc
              unfortunately, it doesn't appear for me in the plugin menu ๐Ÿ˜ž
              (what am I doing wrong?) โ“ simon
                @simon le bon said:
                I'm a little bit disappointed by the fact that depending on the radius is, the tangent lines cannot join perfectly ( certainly due to segmentation of the circles)
                but that's the whole point ๐Ÿ˜„
                the cpoints are placed in the correct place so you can the draw (or redraw) the arcs at the true position. Hence - true tangents
                  Here's v1.8 that fixes the missing menu item glitch - there are now 5 !
                  My latest tool "Fillet Arc [Arc+Line|Cline]" should now appear in the Plugins menu at the end of the rest ๐Ÿ˜ณ
                  At the last moment just before I uploaded v1.7 I changed that item's text to read "Fillet Arc [Arc+Line/Cline]" forgetting that a '/' in a menu name stops it appearing - at least on PCs...
                  Note that typing filletarc in the Console also runs it...
                  Sorry for the confusion... ๐Ÿ˜•
                    filletarc
                    Run filletarc
                    There should be a group of 4+1 tools in the Plugins menu with TrueTangents et al the last one is FilletArc... Alternatively select an arc/circle and a line/cline and type filletarc in the Ruby Console - it should work... If not, then there might be a problem with the install...
                    • utilerU Offline
                      utiler
                      Thank you TIG, your generosity is greatly appreciated!!!! ๐ŸŽ‰
                      Just Curious...
                        @Tig
                        Why not make a submenu?
                        because I have yet hundred of plugs ๐Ÿ˜ณ and a big list screen ๐Ÿ˜’
                        And have you somewhere a list of your different Ruby plugs? โ˜€
                          Pilou
                          Just what I was thinking... It started as one item and grew... I'll make a sub-menu and add the 5 into it in the next release...
                            [V1.9 submenu & individual tools are working well on mac]
                            • BepB Offline
                              Bep
                              folding req.skp
                              Hallo Tig
                              I noticed your keep on working to make this plugin perfect.
                              The problem I would realy like to get solved with this ruby is that when you have got a drawing of an unfolded 3D structure where only faces are field-surveyed it is impossible to accurately fold it to a 3D model.
                              It would be an addition to your true Tangents Ruby, and the true intersections ruby
                              this time ,to find the true intersection points of two circles in 3D .
                              Once these points are found you would have I interference point to rotate the faces to.
                              And it would be possible to measure the angle of rotation these faces should be rotated .
                              I hope you wil find time to look into this.
                              Thanks for all your efforts.
                              Greetings ,Bep van Malde
                              "History is written by the winners"
                                i did around 15 hrs of modeling this weekend and used truetangents 9-10 times..
                                man, it's waay better doing certain things with this plugin.. way better!
                                thanks again for this one
                                  v1.9 now has a sub-menu in Plugins 'Tangent-Tools...' that accesses the 5 tools...
                                  404 Not Found
                                  (forums.sketchucation.com)
                                    simon le bon
                                    Hi Tig,
                                    Thanks to reply so quickly each time ๐Ÿ‘
                                    But sorry to disturb you with my small problem.
                                    There should be a group of 4 tools in the Plugins menu with TrueTangents et al the last one is FilletArc...
                                    Well.. if I make the account:
                                    %(#0000BF)[>truetangents
                                    commontangents
                                    trueintersections
                                    tangentialarcs
                                    filletarc]
                                    There should be a group of 5 tools โ“ isn't it?
                                    but you produce so many tools that you may lose the account ๐Ÿ˜†
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolth.jpg
                                    Yes it does!
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt2th.jpg
                                    (please clic the pic to zoom)
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt3th.jpg
                                    Thank you dear Tig to be so kind and generous with S'Up Community...
                                    ++simon.
                                      simon le bon
                                      ๐Ÿ‘ ๐Ÿ˜‰ this tool is a ruby!
                                      I'm not sure to understand right to be correct ๐Ÿ˜ณ !!
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt004th.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt005th.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt006th.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt007th.jpg
                                      Is this the right way?
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt008th.jpg
                                      Am I correct if I follow the tangent inference this way?
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt009th.jpg
                                      The possibilities are very numerous
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/FilletarcToolt010th.jpg
                                      ๐Ÿ˜Ž simon
                                        the const. points show where a real, non-segmented circle would cross at key points.. these are basically layout tools for people that need real world measurements when building arcs and if your use of SU is mostly to draw things that are organic and/or don't need to be 100% precise then you probably have no real need for TrueTangents (ie, if you're drawing a building simply for representational purposes then it doesn't matter if a wall is 3/4" too thick.. if you're drawing a building that is going to be built in real world using the SU print, then it better be exact or there's going to be a lot of cussing on the jobsite)
                                        if you really had a need for this plugin then i don't think there would be any question about it's usage.. you would see its benefits immediately.
                                          [btw, it's the top of a pool.. a down&dirty render of what's happening with that drawing]
                                            for example ---
                                            without using truetangents, modify this SKP to correspond with this jpg.. the stuff in red is missing in the attached .skp.. (and it is possible to do without TrueTangents but it's a major headache)
                                            if you decide to do this with TrueTangents, you would use the 4th addition.. Tangential Arcs [Arcs+Line]
                                            tt_quiz.skp
                                            • 3 / 5
