    [Plugin] VisMap - Layer/Scene Visibility Map
    126 Posts 15 Posters 58.3k Views 15 Watching
      Jim
      Like this:
      • Bob JamesB Offline
        Bob James
        I like Jim's layout better, but would still prefer Layer(0) at the beginning (but that's not a show stopper).
        • chrisglasierC Offline
          chrisglasier
          Forgive me if I have missed something but isn't layer0 always going to have to be the active layer and should not appear at all? If not it seems there will be lots of complications with reassignment/hiding.
          Both seem to ignore the scene name problem!
            'Layer0' is most often used as the current layer - you then put 'assembled' groups/components/etc on other layers to control visibility. However, you can set any layer as the 'active' one BUT it's not recommended without a good reason... An example would be you are puttings dimensions on the model and want them all to be on layer 'DIMS' - make that the active layer, add the dimensions [you can then switch them on and off separated from everything else] BUT remember to go back to active=Layer0 afterwards otherwise chaos will ensue...
              chrisglasier
              Ah yes I should have written ... "always going to have to be the active layer" when using VisMap
                MartinRinehart
                Actually, Chris, I'd turn Layer0 off, if I could. In my tutorial I teach the common gospel re Layer0, but I don't believe it. I consider a model incomplete until Layer0 is empty.
                  chrisglasier
                  Yes I agree, empty, active and not an option in VisMap! Otherwise if you try and hide another layer that is active you will get an alert "You cannot hide an active layer" or something like that.
                    MartinRinehart
                    Sorted layer names.
                    These two are not in the .zip yet. Please rename "vismap.txt" to "vismap.js", try them in .../Plugins/Vismap and let me know.
                    Thanks.
                    vismap.txt
                    vismap.rb
                      chrisglasier
                      Sorted layer names.
                      Thanks.
                      Just in case you want feedback here are two screenshots. Layer0 is empty, active and visible in all scenes. Some other layers also seem incorrectly checked - awkward to crosscheck though.
                      Perhaps the VIs strings did not get sorted (see top row, which was presumably previously level0).
                      And you really ought to address the awkwardness of the scene names and disappearing headers and unnecessary buttons (in my opinion,of course!).
                        Bob James
                        Alphabetizing works great. πŸ‘
                        It still has a problem with pre-existing models with many layers and many scenes. I tried a new approach: I deleted all but one scene and re-saved the model with a different name. VisMap still would not load the layer names. (see attached)
                        Another request: Since you can have multiple models open at the same time, wouldn't it be a good idea to have the file name in the VisMap dialog box title?
                        ![After clicking on "Get Data from Model"](/uploads/imported_attachments/M321_Screenshot2009-09-25at4.54.52PM.JPG "After clicking on "Get Data from Model"")
                          MartinRinehart
                          It still has a problem with ...
                          Bob, I need a sample model.
                          I also need a Mac. Will look at the name thing.
                            MartinRinehart
                            Can you send me a model? Post here or MartinRinehart at gmail dot com.
                            Ground-up rebuild, but not anytime soon. Scene names should be in a separate window you can move/size to suit. Title should be in a frame you can fold away. Scene #s should be frozen. You should have Ctrl/+, Ctrl/- to adjust size....
                              chrisglasier
                              Please download sceneModel R1.4.zip from here.
                                chrisglasier
                                The Layers SU Window is small, redimensionable, fully interactive and has a table scrolling. Furthermore, it allows to add / remove layers and configure them dynamically. You will miss however the Sorting into alphabetical order! Fredo
                                Just for the sake of good order:
                                On a PC you can sort layers alphabetically by clicking on "Name."
                                Pedantically
                                  MartinRinehart
                                  Thanks to you guys, I've now reproduced the issue in a modest model. Probably closing in on the solution, though I won't be on it any longer, today.
                                  • fredo6F Offline
                                    Pedantically
                                    Chris, You are right actually. You can also sort them by visible / invisible and by color.
                                    We should sometime look at what the SU engineers are doing in the native application πŸ˜„
                                      Bob James
                                      Page not found
                                      We're sorry, but we were unable to locate the page you requested.
                                        chrisglasier
                                        @bob james said:
                                        A Google alert this morning Hong Kong time says it has recovered the page (I must have made some balls up with the new R1.05 plugin attachment), and it seems OK from here. I have also sent a copy of the zip as a reply to your email.
                                        Thanks (and apologises).
                                        PS Martin did you have the same problem?
                                          MartinRinehart
                                          Gentlemen:
                                          This pair should be smarter about which boxes are initially checked.
                                          Ruby
                                          Rename to "vismap.js"
                                          • EdsonE Offline
                                            Edson
                                            it did not work for me on mac.
                                            http://www.mahfuz.arq.br
                                            • 5 / 7
