    [Plugin] VisMap - Layer/Scene Visibility Map
    126 Posts 15 Posters 68.9k Views 15 Watching
    • chrisglasierC
      chrisglasier
      @martinrinehart said:
      @chrisglasier said:
      "always going to have to be the active layer" when using VisMap
      Actually, Chris, I'd turn Layer0 off, if I could. In my tutorial I teach the common gospel re Layer0, but I don't believe it. I consider a model incomplete until Layer0 is empty.
      Yes I agree, empty, active and not an option in VisMap! Otherwise if you try and hide another layer that is active you will get an alert "You cannot hide an active layer" or something like that.
        MartinRinehart
        Sorted layer names.
        These two are not in the .zip yet. Please rename "vismap.txt" to "vismap.js", try them in .../Plugins/Vismap and let me know.
        Thanks.
        vismap.txt
        vismap.rb
        • chrisglasierC
          chrisglasier
          Sorted layer names.
          Thanks.
          Just in case you want feedback here are two screenshots. Layer0 is empty, active and visible in all scenes. Some other layers also seem incorrectly checked - awkward to crosscheck though.
          Perhaps the VIs strings did not get sorted (see top row, which was presumably previously level0).
          And you really ought to address the awkwardness of the scene names and disappearing headers and unnecessary buttons (in my opinion,of course!).
          • Bob JamesB
            Bob James
            Alphabetizing works great. πŸ‘
            It still has a problem with pre-existing models with many layers and many scenes. I tried a new approach: I deleted all but one scene and re-saved the model with a different name. VisMap still would not load the layer names. (see attached)
            Another request: Since you can have multiple models open at the same time, wouldn't it be a good idea to have the file name in the VisMap dialog box title?
            ![After clicking on "Get Data from Model"](/uploads/imported_attachments/M321_Screenshot2009-09-25at4.54.52PM.JPG "After clicking on "Get Data from Model"")
              MartinRinehart
              It still has a problem with ...
              Bob, I need a sample model.
              I also need a Mac. Will look at the name thing.
                MartinRinehart
                Can you send me a model? Post here or MartinRinehart at gmail dot com.
                Ground-up rebuild, but not anytime soon. Scene names should be in a separate window you can move/size to suit. Title should be in a frame you can fold away. Scene #s should be frozen. You should have Ctrl/+, Ctrl/- to adjust size....
                • chrisglasierC
                  chrisglasier
                  Please download sceneModel R1.4.zip from here.
                  • chrisglasierC
                    chrisglasier
                    The Layers SU Window is small, redimensionable, fully interactive and has a table scrolling. Furthermore, it allows to add / remove layers and configure them dynamically. You will miss however the Sorting into alphabetical order! Fredo
                    Just for the sake of good order:
                    On a PC you can sort layers alphabetically by clicking on "Name."
                    Pedantically
                      MartinRinehart
                      Thanks to you guys, I've now reproduced the issue in a modest model. Probably closing in on the solution, though I won't be on it any longer, today.
                      • fredo6F
                        Pedantically
                        Chris, You are right actually. You can also sort them by visible / invisible and by color.
                        We should sometime look at what the SU engineers are doing in the native application πŸ˜„
                        • Bob JamesB
                          Bob James
                          Page not found
                          We're sorry, but we were unable to locate the page you requested.
                          • chrisglasierC
                            chrisglasier
                            @bob james said:
                            A Google alert this morning Hong Kong time says it has recovered the page (I must have made some balls up with the new R1.05 plugin attachment), and it seems OK from here. I have also sent a copy of the zip as a reply to your email.
                            Thanks (and apologises).
                            PS Martin did you have the same problem?
                              MartinRinehart
                              Gentlemen:
                              This pair should be smarter about which boxes are initially checked.
                              Ruby
                              Rename to "vismap.js"
                              • EdsonE
                                Edson
                                it did not work for me on mac.
                                http://www.mahfuz.arq.br
                                • Bob JamesB
                                  Bob James
                                  I took my main model (40MB) and started deleting layers (after I had deleted all but one scene). It initially had 205 layers and 22 scenes. After each set of deletions (about 20 at a time), I updated the scene and saved the model, then tried to "Get Data From Model". [VisMap dated 28 Sep 2009]
                                  I finally had to delete ALL the layers except Layer(0) before VisMap would "Get Data from Model". (See Attached)
                                  The really weird thing is that the file is still 13.6MB!!!!!!(See Attached)
                                  I can send you this if you can handle 14MB.
                                  This suggested something not right in how SU handles "something". How could a model with nothing in it be 13.6MB ❓ ❓
                                  VisMap after all the layers were removed.
                                  ![Shows the "empty" model is still 13.6MB](/uploads/imported_attachments/Qc7T_Screenshot2009-09-28at5.35.12PM.png "Shows the "empty" model is still 13.6MB")
                                    MartinRinehart
                                    I tightened that up a lot. That's Ruby catching an error and forwarding it to the WebDialog to show to you. Your model has some sort of internal damage. Try "Purge Unused."
                                    If that doesn't work, make a copy, delete half your layers and try again. If that fixes it, you've deleted a bad layer. If that doesn't work, make another copy and delete the other half of the layers. The remainder should work. Continue, working on quarters, eighths, ... until you find the bad layer.
                                    If you can't isolate a single bad layer, try rebuilding one layer at a time: turn all but one layer off. Select all, copy to clipboard, open fresh model, make a recipient layer, paste from clipboard. Vismap it to be sure it's clean. Repeat.
                                    Good luck.
                                      MartinRinehart
                                      I assume you "Purge Unused"? I don't want a copy. Your model has issues.
                                      Use the technique I suggested to Edson to rebuild. One layer at a time, select all, copy, paste into fresh file/fresh layer. Save. Keep Model Info open to File and watch size carefully. Use Vismap as an integrity check while you rebuild.
                                      Good luck.
                                      • EdsonE
                                        Edson
                                        martin,
                                        purge unused did not help. then i tried (sort of) your technique but by copying groups of five layers at a time to a new file and running vismap after each copy. it worked every time until all the layers had been copied.
                                        EDIT: however, the error reported above is happening with every file i open. i do not believe every one of them have problems. purge unused does not help, fix problems returns no problems. i cannot imagine having to move all layers to new files for every model i work on. my conclusion: vismap is still not being able to handle big files with many layers and scenes.
                                          MartinRinehart
                                          I'm not certain whether this is a size or a Mac issue. This morning I've been making a movie promoting a club I've designed. Could you try it? If your problem reappears, we'll know it's platform-related.
                                          Try http://www.MartinRinehart.com/download.html
                                          The last of the four downloads, rf.zip, contains "club.skp". Open it, add a couple scenes and VisMap it. (This was my first SketchUp model, so don't judge it too harshly, please.)
                                          • EdsonE
                                            Edson
                                            martin,
                                            i created some scenes and tried it with your file. it worked. your file has 3.8 Mb, mine have all more than 30Mb.
                                            • 5 / 7
