    [Plugin] VisMap - Layer/Scene Visibility Map
    126 Posts 15 Posters 58.6k Views 15 Watching
    • chrisglasierC Offline
      chrisglasier
      @bob james said:
      I model their equipment and, for the pieces that will appear at different places in each scene, I make a new location-sensitive instance. Once all of this is done I can then, with your tool, turn on the applicable location-sensitive pieces of equipment at the appropriate location in the appropriate scene. ...
      That's very interesting. Am I right in thinking each layer configuration is saved in a client specific file? As VisMap is in a webdialog what would you think about saving configurations as JavaScript arrays, so that you need not open and close files and quickly move through the configurations, and, with further devices, compare selected parts/costs/status and suchlike in different configurations? If the Sketchup Viewer had plugin facilities, clients could access your configurations via the Net as a normal part of their business operation.
      If the Sketchup Viewer had plugin facilities ... now that's definitely another topic ... sorry!
        SHAHEEN
        thanks mr. martin
        " An eye for an eye only ends up making the whole world blind "
        Gandhi
        • Bob JamesB Offline
          Bob James
          Not quite. Each scene in the process has its own layer configuration. The process (movement of their satellite through the facility) may take 10 or 15 scenes. This client-specific SU file is then saved. In most cases each scene is rendered using IDXRenditioner, the result saved, each picture touched up in Photoshop (if necessary), and the result put into a PowerPoint presentation. Sometimes the entire set of scenes is made into an SU animation.
          During the development process I also use new version of Layer Manager to save the layer configurations (great plugin - use it and its associated Layer Tools all the time).
            MartinRinehart
            <sketchup src='my_slick_model.skp'> If you had a better browser, you'd see My Slick Model here </sketchup>
            Right?
              MartinRinehart
              Like so?
              Or should Layer0 always be at the top?
                Bob James
                Super!! 😍
                Can I download this version? I'm just beginning a new project. πŸŽ‰
                My vote would be for Layer(0) to be at the top.
                  Jim
                  Like this:
                    Bob James
                    I like Jim's layout better, but would still prefer Layer(0) at the beginning (but that's not a show stopper).
                      chrisglasier
                      Forgive me if I have missed something but isn't layer0 always going to have to be the active layer and should not appear at all? If not it seems there will be lots of complications with reassignment/hiding.
                      Both seem to ignore the scene name problem!
                        'Layer0' is most often used as the current layer - you then put 'assembled' groups/components/etc on other layers to control visibility. However, you can set any layer as the 'active' one BUT it's not recommended without a good reason... An example would be you are puttings dimensions on the model and want them all to be on layer 'DIMS' - make that the active layer, add the dimensions [you can then switch them on and off separated from everything else] BUT remember to go back to active=Layer0 afterwards otherwise chaos will ensue...
                          chrisglasier
                          Ah yes I should have written ... "always going to have to be the active layer" when using VisMap
                            MartinRinehart
                            Actually, Chris, I'd turn Layer0 off, if I could. In my tutorial I teach the common gospel re Layer0, but I don't believe it. I consider a model incomplete until Layer0 is empty.
                              chrisglasier
                              Yes I agree, empty, active and not an option in VisMap! Otherwise if you try and hide another layer that is active you will get an alert "You cannot hide an active layer" or something like that.
                                MartinRinehart
                                Sorted layer names.
                                These two are not in the .zip yet. Please rename "vismap.txt" to "vismap.js", try them in .../Plugins/Vismap and let me know.
                                Thanks.
                                vismap.txt
                                vismap.rb
                                  chrisglasier
                                  Sorted layer names.
                                  Thanks.
                                  Just in case you want feedback here are two screenshots. Layer0 is empty, active and visible in all scenes. Some other layers also seem incorrectly checked - awkward to crosscheck though.
                                  Perhaps the VIs strings did not get sorted (see top row, which was presumably previously level0).
                                  And you really ought to address the awkwardness of the scene names and disappearing headers and unnecessary buttons (in my opinion,of course!).
                                    Bob James
                                    Alphabetizing works great. πŸ‘
                                    It still has a problem with pre-existing models with many layers and many scenes. I tried a new approach: I deleted all but one scene and re-saved the model with a different name. VisMap still would not load the layer names. (see attached)
                                    Another request: Since you can have multiple models open at the same time, wouldn't it be a good idea to have the file name in the VisMap dialog box title?
                                    ![After clicking on "Get Data from Model"](/uploads/imported_attachments/M321_Screenshot2009-09-25at4.54.52PM.JPG "After clicking on "Get Data from Model"")
                                      MartinRinehart
                                      It still has a problem with ...
                                      Bob, I need a sample model.
                                      I also need a Mac. Will look at the name thing.
                                        MartinRinehart
                                        Can you send me a model? Post here or MartinRinehart at gmail dot com.
                                        Ground-up rebuild, but not anytime soon. Scene names should be in a separate window you can move/size to suit. Title should be in a frame you can fold away. Scene #s should be frozen. You should have Ctrl/+, Ctrl/- to adjust size....
                                          chrisglasier
                                          Please download sceneModel R1.4.zip from here.
                                            chrisglasier
                                            The Layers SU Window is small, redimensionable, fully interactive and has a table scrolling. Furthermore, it allows to add / remove layers and configure them dynamically. You will miss however the Sorting into alphabetical order! Fredo
                                            Just for the sake of good order:
                                            On a PC you can sort layers alphabetically by clicking on "Name."
                                            Pedantically
                                            • 5 / 7
