    [Plugin] 2D Tools
    791 Posts 178 Posters 501.8k Views 177 Watching
      Already updated with some minor fixes ! http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
      • CadFatherC Offline
        CadFather
        Thanks TIG, some alternative icons if needed..
        Icons.zip
          CadFather
          Hi TIG, how difficult would a double click to fillet all the corners be? (or something similar)
          also: is text tag now redundant?
            dedmin
            Couldn't get the 2d line style tool to work?
            • halroachH Offline
              halroach
              can't get the line styles to work either. Would it have to do with the styles?
              FlexTools - Super Quick Windows, Doors, Slats...
                rv1974
                Fillet tool is a nice addition. Thank you TIG!
                P.S.I have 2 sets of the same icons on one tollbar. How to solve it?
                  TextTag works similarly but sticks onto on 3D Faces and has a few more options like 'face_camera'...
                  The fillet tool works by picking two edges so your idea might be difficult ?
                    Please ensure that earlier folders and 2D .rbs have been removed - perhaps (re)do a 'clean' install ?
                      There's aglitch on the layer creation... I'll issue an update to fix it asap...
                        v2.3 now available here http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                        Tweaks to LineStyle Tools [layer visibility glitch etc] and now CafFather's alternative icon set included [as zip], if desired...
                          dedmin
                          Line styles still don't work - I can see layers are visible, but lines don't chance.
                            Check you have materials to show mode is set 'on' - i.e. face materials show up... Check View/Hidden-Geometry is 'off'.
                            Start the linestyle tool, right-click in empty space, in the dialog that opens set the style to a line-width you know will show up at the size of model (default=1, if the edges are very long than perhaps =6, very small =.25 ???) and then style='Dashed' and color='Red' - so it'll be clearly distinguishable from the original edge. Pick an edge - that edge should get moved onto the ...HIDN layer [and disappear as it's switched 'off'] and a new dashed styled-line 'group' should be made and appear on the ...STYL layer ? Open the Outliner to see what groups you have... Get Entity Info on the edge and new group to check what happens...
                            Run the tool with the Windows/Ruby Console open and copy/paste us any error messages that you get, if it persists...
                            Consider posting a small [purged] model with the problem if it's not fixed ?
                            D 1 Reply Last reply Reply Quote 0
                            • N Offline
                              NewOne
                              Wonderful set of tools. ☀ I'm not a McDonand's fan, but this time i must say: I'm lovin' It!
                              However, one thing is annoying. As you can see in attached image, the line is clipped when drawing (the mouse cursor is not seen, but this img was captured while drawing with 2d rectangle tool). I think this is because the drawing gets out its boundingbox and if that boundingbox is updated on mouse move, this clipping will not occur anymore.
                              One more thing: could Set Z-Plane tool to have inference? I'd like to be able to snap on vertexes and edges.
                              Thanks again for all the tools you made!.
                                dedmin
                                  dedmin
                                  I see from the video it's not working... The ...HIDN layer should turn off if you have it 'on'. I suspect it's something to do with scenes/pages... Do you get any Ruby Console Errors ?
                                  I notie the lines are only afew mm long so choose a small width - 4 = 4" ~= 100mm x10 the length of the line !
                                    @newone said:
                                    Wonderful set of tools. ☀ I'm not a McDonand's fan, but this time i must say: I'm lovin' It!However, one thing is annoying. As you can see in attached image, the line is clipped when drawing (the mouse cursor is not seen, but this img was captured while drawing with 2d rectangle tool). I think this is because the drawing gets out its boundingbox and if that boundingbox is updated on mouse move, this clipping will not occur anymore.
                                    I'll look into the rectangle's drawing clipping.
                                    The Z-plane tool does have inferencing tooltips and will snap to these points but the cursor doesn't cahnge, I look at this too...
                                      dedmin
                                      @tig said:
                                      dedmin
                                      Error; #<NoMethodError; undefined method `set_visibility' for nil;NilClass>
                                      C;/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DlinestyleTool.rb;188;in `style_line'
                                      C;/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DlinestyleTool.rb;166;in `onLButtonDown'
                                      • EarthMoverE Offline
                                        EarthMover
                                        I'm getting the same errors as dedmin with the line style tool.
                                        Content Creator at Skapeup
                                        • kenK Offline
                                          ken
                                          Attached is the VCB during drawing an arc. Not sure, what VCB is displaying, however your help guide indicated that the VCB should be displaying the “swept-angle”
                                          Thanks for the plugin
                                          Ken
                                          • EdsonE Offline
                                            Edson
                                            warning to mac users: in order for this pluging to open you must put it at USER\Libray\application support\google\google sketchup 7\plugins, not in the main plugins folder.
                                            TIG: i click on the help icon and get nothing. is this a problem or there is nothing there?
                                            http://www.mahfuz.arq.br
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 39
                                            • 40
                                            • 24 / 40
