    [Plugin] 2D Tools
    791 Posts 178 Posters 520.3k Views 177 Watching
      Does the Z-Plane set the elevation the lines are drawn on, or is it also possible to define a plane that's different than the standard axis?
        Only on a flat Z-plane - these are 2D Tools... 😄
        Although some like Fillet work in '3D' too...
          2D, yes - just wondered if you could specify the 2D work-plane arbitrary - not just top-down from the world axis.
            Already updated with some minor fixes ! http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
            • CadFatherC Offline
              CadFather
              Thanks TIG, some alternative icons if needed..
              Icons.zip
                CadFather
                Hi TIG, how difficult would a double click to fillet all the corners be? (or something similar)
                also: is text tag now redundant?
                  dedmin
                  Couldn't get the 2d line style tool to work?
                  • halroachH Offline
                    halroach
                    can't get the line styles to work either. Would it have to do with the styles?
                    FlexTools - Super Quick Windows, Doors, Slats...
                      rv1974
                      Fillet tool is a nice addition. Thank you TIG!
                      P.S.I have 2 sets of the same icons on one tollbar. How to solve it?
                        TextTag works similarly but sticks onto on 3D Faces and has a few more options like 'face_camera'...
                        The fillet tool works by picking two edges so your idea might be difficult ?
                          Please ensure that earlier folders and 2D .rbs have been removed - perhaps (re)do a 'clean' install ?
                            There's aglitch on the layer creation... I'll issue an update to fix it asap...
                              v2.3 now available here http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                              Tweaks to LineStyle Tools [layer visibility glitch etc] and now CafFather's alternative icon set included [as zip], if desired...
                                dedmin
                                Line styles still don't work - I can see layers are visible, but lines don't chance.
                                  Check you have materials to show mode is set 'on' - i.e. face materials show up... Check View/Hidden-Geometry is 'off'.
                                  Start the linestyle tool, right-click in empty space, in the dialog that opens set the style to a line-width you know will show up at the size of model (default=1, if the edges are very long than perhaps =6, very small =.25 ???) and then style='Dashed' and color='Red' - so it'll be clearly distinguishable from the original edge. Pick an edge - that edge should get moved onto the ...HIDN layer [and disappear as it's switched 'off'] and a new dashed styled-line 'group' should be made and appear on the ...STYL layer ? Open the Outliner to see what groups you have... Get Entity Info on the edge and new group to check what happens...
                                  Run the tool with the Windows/Ruby Console open and copy/paste us any error messages that you get, if it persists...
                                  Consider posting a small [purged] model with the problem if it's not fixed ?
                                  D 1 Reply Last reply Reply Quote 0
                                  • N Offline
                                    NewOne
                                    Wonderful set of tools. ☀ I'm not a McDonand's fan, but this time i must say: I'm lovin' It!
                                    However, one thing is annoying. As you can see in attached image, the line is clipped when drawing (the mouse cursor is not seen, but this img was captured while drawing with 2d rectangle tool). I think this is because the drawing gets out its boundingbox and if that boundingbox is updated on mouse move, this clipping will not occur anymore.
                                    One more thing: could Set Z-Plane tool to have inference? I'd like to be able to snap on vertexes and edges.
                                    Thanks again for all the tools you made!.
                                      dedmin
                                        dedmin
                                        I see from the video it's not working... The ...HIDN layer should turn off if you have it 'on'. I suspect it's something to do with scenes/pages... Do you get any Ruby Console Errors ?
                                        I notie the lines are only afew mm long so choose a small width - 4 = 4" ~= 100mm x10 the length of the line !
                                          @newone said:
                                          Wonderful set of tools. ☀ I'm not a McDonand's fan, but this time i must say: I'm lovin' It!However, one thing is annoying. As you can see in attached image, the line is clipped when drawing (the mouse cursor is not seen, but this img was captured while drawing with 2d rectangle tool). I think this is because the drawing gets out its boundingbox and if that boundingbox is updated on mouse move, this clipping will not occur anymore.
                                          I'll look into the rectangle's drawing clipping.
                                          The Z-plane tool does have inferencing tooltips and will snap to these points but the cursor doesn't cahnge, I look at this too...
                                            dedmin
                                            @tig said:
                                            dedmin
                                            Error; #<NoMethodError; undefined method `set_visibility' for nil;NilClass>
                                            C;/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DlinestyleTool.rb;188;in `style_line'
                                            C;/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DlinestyleTool.rb;166;in `onLButtonDown'
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 39
                                            • 40
                                            • 17 / 40
