    [Plugin] extrudeEdgesByLathe
    104 Posts 43 Posters 83.4k Views 43 Watching
      Khai
      oooh yus.
      working great so far ๐Ÿ˜„
      • kenK Offline
        ken
        Tig
        Am I missing something? Is there a difference between your lath tool and 1001bits lath tool? I have used both, and I cannot see any difference in the final product after smoothing.
        Both seemed to do the job, I am just wondering what I am missing.
        Ken
          This one is free. ๐Ÿ˜‰
            Ben Ritter
            TIG,
            Thank you!
            • N Offline
              nektares
              nice!! i can sure use this plug-in! thanks!
              • EdsonE Offline
                Edson
                Tig
                Ken
                is there a tool called lath in the 1001bit set of tools? the only one that i found that does a similar thing is Extrude along curved sloping path.
                edson mahfuz, architect| porto alegre โ€ข brasil
                http://www.mahfuz.arq.br
                • EdsonE Offline
                  Edson
                  tig,
                  thanks for one more wonderful tool. it works fine in my mac. but forgive my dumbness: i have not understood how to set it up, that is, how to position the curve or face in relation to the center of the curve. could explain it a little further?
                    mike d
                    thanks tig
                    The grass is always GREENER on the roof.
                      Thanks for sharing Tig. Very much appreciated and needed
                      • boofredlayB Offline
                        boofredlay
                        Thanks TIG.
                        When prompted to pick a center point I am not getting the option to pick a specific point, rather a general area. There is no indication that I am picking an endpoint or midpoint of another line etc. that I may have placed for my center point.
                        Edit: Ok if I hover long enough I see the tool tip say "endpoint" or "midpoint". If a visual clue could be added that would be great.
                        Thanks again for this.
                        • mitcorbM Offline
                          mitcorb
                          Thank you, TIG.
                          I will give this a run through and let you know.
                            Dan
                            Thank you, Tig!
                            A really useful plugin. And it works perfectly ๐Ÿ˜„ .
                            A question, though: the cursor isn't supposed to snap to a given point when asked for the lathe center?
                            I noticed the tooltip telling me where my cursor points, but a more consistent visual feedback seems necessary, IMHO.
                            Thanks again, great work!
                              Tig
                              Ken
                              1001 tools ? ๐Ÿ˜‰
                              This is a separate tool written entirely from scratch. ๐Ÿค“
                                The 'pick center-point' prompt/point_pick will 'infer' to any suitable point - e.g. intersection/midpoint/end/on_edge/center etc... but it you have a specific point that you want the arc to sweep from then I suggest you make some cline/guides-intersections or cpoints etc to snap to during the tool - before using it... ๐Ÿค“
                                  You can pick the center anywhere - 'off-center' skews stuff BUT you might want that... Set up with guides or cpoints if you want to 'lathe' about a definite center...
                                  Thanks for the feedbacks... you should know that I wrote it 'from scratch' during today... so there might be [probably are] some improvements possible... Let me know of anything you think might improve it...
                                  ๐Ÿค“
                                  • kenK Offline
                                    ken
                                    [/quote]
                                    1001 tools ? ๐Ÿ˜‰
                                    [/quote]
                                    I certainly did not mean to imply that you plugin was anything but your own creation. I was just wondering if your plugin handled the arc or circle segments or finish the lath function differently. I only ask that question because of the way Sketchup make circles and arcs with segments.
                                    Again thanks for all you scripts.
                                    Ken
                                      Ken
                                      My 'lathe' uses NO arcs at all - all of the edges that are created are pseudo-arcs - i.e. edges that might make an arc BUT aren't actually part of an arc... It simply makes a 'followme' of a face [or any polyline !!!] around a supposed arc shaped path, that is correct without any distortions of the geometry - unlike the built-in 'followme' < 360 degrees...
                                        dtrarch
                                        This is a long needed tool and thanks a bunch for taking the trouble.
                                        Long time ago there was one with the same ruby name so good idea to flush the old one if exist before install.
                                        Much needed and appreciated by all. ๐Ÿ˜
                                        Cheers
                                        dtr
                                        • simon le bonS Offline
                                          simon le bon
                                          dear Tig,
                                          This tool is so great ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                          It compensate something we can tell it is an irritating kind of bug of FollowMe Tool when we need to draw a "piece of cake".
                                          But it can do much more, and it is so easy to use.. Super ๐Ÿ˜„
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/lathe_Tigth.jpg
                                          You surf so easily with ruby that you are a sort of Yoda jedaรฏ in the SketchUpSpace...
                                          Thank again, thank for this...
                                          simon.
                                            Seems you must say that the "path" or the "face" must be on a vertical plan else maybe result will be not that you want ๐Ÿ˜‰
                                            Cool plug as always โ˜€
                                            • 1 / 6
