    [Plugin] Point v1.2
    42 Posts 25 Posters 83.0k Views 25 Watching
    • MALAISEM
      MALAISE
      Obviously useful 👍 👍
      MALAISE 😄
        Matt666
        Thank you Pierre!
        A new version 1.2 is available... Try to fix Mac problems.
        Frenglish at its best !
        My scripts
        • jeff hammondJ
          Merci!
          it's working nicely now on my mac.
          btw, i think the provided icon is too small.. it's 16x16 but SU can use 24x24 as well..
          @simon le bon said:
          But at the end we need to erase all those construction points!!!
          No problem! Just use the so powerful Matt666's Selection Manager 😉 😉
          another option is edit->delete guides.. not as powerful as selection manager but it will get rid of the points as well.
            agrazdi
            I found this plugin great.
            But it could be excelent if after you inferrenced the distance with another object you could tape /# of spaces and add constructions points. Sort of dividing a line in 2,3,4.... spaces.
            Is it possible to add this request ?
            agrazdi
            • I
              ilay7k
              Matthieu, thank you
              great addition for making of general plans
                Matt666
                Thank you!
                agrazdi, I will see what I can do!
                My scripts
                • simon le bonS
                  simon le bon
                  Hi NewOne,
                  Your icons are NumberOne 😉
                  But when i try to use them (32x32), their quality isn't at the "rendez-vous" . Why? I can't say.
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Matt_Point.jpg
                  simon
                  • N
                    NewOne
                    @simon le bon said:
                    Hi NewOne,
                    simon
                    Well... This is what I do now: try to figure out why on image viewer and on forum page the icon looks nice, but in Sketchup is a little messed up.
                    QUESTION: how many colors does sketchup accept for icons? true color, 256, or less? 😳
                      Jim
                      Sketchup Toolbar icons are 24x24, or 16x16 for the small icons. Tool cursors are 32x32.
                      • N
                        NewOne
                        THANK YOU !!
                        I tested with 24x24 and it looks wonderfull.
                        • N
                          NewOne
                          --EDITED POST-- changed the files, and added code suggestion.
                          Alternate icons for PointTool
                          Matt666, if you like this icons, please edit your script to use 24x24px and 16x16px icons.
                          The changes I made to your script to accept those icons and cursor icon are:
                          cmd.large_icon = File.join(p, "PointTool", "PointTool24x24.png")
                          cmd.small_icon = File.join(p, "PointTool", "PointTool16x16.png")
                          and
                          def initialize
                          #...your previous code
                          p=Sketchup.find_support_file("Plugins")
                          pointTool_cursor_path = File.join(p,  "PointTool", "PointTool cursor.png")
                          @@pointTool_cursor = UI;;create_cursor(pointTool_cursor_path, 3, 30)
                          def onSetCursor
                          UI;;set_cursor(@@pointTool_cursor)
                          I am not sure if this is entirely correct, but it works for me.
                          If you decide to change the icons, pay attention on hotspot coordinates of the cursor 😉
                          Suggestion: add getExtents method to avoid disappearance of the OpenGL line.
                          def getExtents
                          bbox = Geom;;BoundingBox.new
                          	bbox.add @ip1.position
                          	if (@state == 0)
                          		bbox.add @ip.position if (@ip.valid? && @ip.display?)
                          	elsif
                          		bbox.add @ip2.position
                          	bbox
                          P.S. I like your script very much, it ease my work a lot! It's a simple, but strong idea!
                          contains 16x16, 24x24 and 32x32 PNG
                          visual example
                          • N
                            NewOne
                            for making the script to show cursor, see this post: http://forums.sketchucation.com/viewtopic.php?f=180&t=13077&st=0&sk=t&sd=a&start=15#p184325
                            contains icons (24x24, 16x16) and cursor (32x32)
                            • simon le bonS
                              simon le bon
                              Hi NewOne,
                              Thank for it (the blue pen) . Now adopted 👍 😉
                              simon
                              • W
                                watkins
                                Dear Matt,
                                I have downloaded your version 1.2, but cannot work out how to draw a single point other than hitting the Esc key. What should I do?
                                Kind regards,
                                Bob
                                • utilerU
                                  utiler
                                  @simon le bon said:
                                  Hi NewOne,
                                  simon
                                  I think JClements made the Construction line tool Icon. Would be good to see a similar icon for the point tool also.
                                  Both point and Construction line tool I use all the time, thanks heaps guys!!!!!
                                  Just Curious...
                                  • JClementsJ
                                    JClements
                                    Try one of these.
                                    16x16
                                    • JClementsJ
                                      JClements
                                      Or this one.24x24
                                      • JClementsJ
                                        JClements
                                        • JClementsJ
                                          JClements
                                          and the master file.
                                          Xara format.
                                          Great app. Cheap. Free trial down load at http://www.xara.com
                                          Point Tool Icon for Utiller.zip
                                          • utilerU
                                            utiler
                                            You're the man, John!!!!
                                            Just Curious...
                                            • 2 / 3
