    [Plugin] Point v1.2
    42 Posts 25 Posters 83.0k Views 25 Watching
    • jeff hammondJ
      @bob james said:
      Have a problem loading: see attachment.
      ditto
      looks very useful too... anyone know how to make this mac compatible?
        Matt666
        @ Bones : Hi ! I will give a try... Not sure I can do that...
        @ Jeff Hammond & Bob James : Ok, thank you for that! I have asked to Fredo6 (because his compatibility between Win & Mac is great), so be patient please! 😄
        @ simon le bon ... Bah didon belle présentation !! Merci à toi 😳 Thank you for this great presentation!!
        Frenglish at its best !
        My scripts
        • simon le bonS
          simon le bon
          • MALAISEM
            MALAISE
            Obviously useful 👍 👍
            MALAISE 😄
              Matt666
              Thank you Pierre!
              A new version 1.2 is available... Try to fix Mac problems.
              My scripts
              • jeff hammondJ
                Merci!
                it's working nicely now on my mac.
                btw, i think the provided icon is too small.. it's 16x16 but SU can use 24x24 as well..
                @simon le bon said:
                But at the end we need to erase all those construction points!!!
                No problem! Just use the so powerful Matt666's Selection Manager 😉 😉
                another option is edit->delete guides.. not as powerful as selection manager but it will get rid of the points as well.
                  agrazdi
                  I found this plugin great.
                  But it could be excelent if after you inferrenced the distance with another object you could tape /# of spaces and add constructions points. Sort of dividing a line in 2,3,4.... spaces.
                  Is it possible to add this request ?
                  agrazdi
                  • I
                    ilay7k
                    Matthieu, thank you
                    great addition for making of general plans
                      Matt666
                      Thank you!
                      agrazdi, I will see what I can do!
                      My scripts
                      • simon le bonS
                        simon le bon
                        Hi NewOne,
                        Your icons are NumberOne 😉
                        But when i try to use them (32x32), their quality isn't at the "rendez-vous" . Why? I can't say.
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Matt_Point.jpg
                        simon
                        • N
                          NewOne
                          @simon le bon said:
                          Hi NewOne,
                          simon
                          Well... This is what I do now: try to figure out why on image viewer and on forum page the icon looks nice, but in Sketchup is a little messed up.
                          QUESTION: how many colors does sketchup accept for icons? true color, 256, or less? 😳
                            Jim
                            Sketchup Toolbar icons are 24x24, or 16x16 for the small icons. Tool cursors are 32x32.
                            • N
                              NewOne
                              THANK YOU !!
                              I tested with 24x24 and it looks wonderfull.
                              • N
                                NewOne
                                --EDITED POST-- changed the files, and added code suggestion.
                                Alternate icons for PointTool
                                Matt666, if you like this icons, please edit your script to use 24x24px and 16x16px icons.
                                The changes I made to your script to accept those icons and cursor icon are:
                                cmd.large_icon = File.join(p, "PointTool", "PointTool24x24.png")
                                cmd.small_icon = File.join(p, "PointTool", "PointTool16x16.png")
                                and
                                def initialize
                                #...your previous code
                                p=Sketchup.find_support_file("Plugins")
                                pointTool_cursor_path = File.join(p,  "PointTool", "PointTool cursor.png")
                                @@pointTool_cursor = UI;;create_cursor(pointTool_cursor_path, 3, 30)
                                def onSetCursor
                                UI;;set_cursor(@@pointTool_cursor)
                                I am not sure if this is entirely correct, but it works for me.
                                If you decide to change the icons, pay attention on hotspot coordinates of the cursor 😉
                                Suggestion: add getExtents method to avoid disappearance of the OpenGL line.
                                def getExtents
                                bbox = Geom;;BoundingBox.new
                                	bbox.add @ip1.position
                                	if (@state == 0)
                                		bbox.add @ip.position if (@ip.valid? && @ip.display?)
                                	elsif
                                		bbox.add @ip2.position
                                	bbox
                                P.S. I like your script very much, it ease my work a lot! It's a simple, but strong idea!
                                contains 16x16, 24x24 and 32x32 PNG
                                visual example
                                • N
                                  NewOne
                                  for making the script to show cursor, see this post: http://forums.sketchucation.com/viewtopic.php?f=180&t=13077&st=0&sk=t&sd=a&start=15#p184325
                                  contains icons (24x24, 16x16) and cursor (32x32)
                                  • simon le bonS
                                    simon le bon
                                    Hi NewOne,
                                    Thank for it (the blue pen) . Now adopted 👍 😉
                                    simon
                                    • W
                                      watkins
                                      Dear Matt,
                                      I have downloaded your version 1.2, but cannot work out how to draw a single point other than hitting the Esc key. What should I do?
                                      Kind regards,
                                      Bob
                                      • utilerU
                                        utiler
                                        @simon le bon said:
                                        Hi NewOne,
                                        simon
                                        I think JClements made the Construction line tool Icon. Would be good to see a similar icon for the point tool also.
                                        Both point and Construction line tool I use all the time, thanks heaps guys!!!!!
                                        Just Curious...
                                        • JClementsJ
                                          JClements
                                          Try one of these.
                                          16x16
                                          • JClementsJ
                                            JClements
                                            Or this one.24x24
                                            • 2 / 3
