    [Plugin] Point v1.2
    42 Posts 25 Posters 81.3k Views 25 Watching
    • Bob JamesB Offline
      Bob James
      Have a problem loading: see attachment.
      • jeff hammondJ Offline
        ditto
        looks very useful too... anyone know how to make this mac compatible?
          Matt666
          @ Bones : Hi ! I will give a try... Not sure I can do that...
          @ Jeff Hammond & Bob James : Ok, thank you for that! I have asked to Fredo6 (because his compatibility between Win & Mac is great), so be patient please! 😄
          @ simon le bon ... Bah didon belle présentation !! Merci à toi 😳 Thank you for this great presentation!!
          Frenglish at its best !
          My scripts
          • simon le bonS Offline
            simon le bon
            • MALAISEM Offline
              MALAISE
              Obviously useful 👍 👍
              MALAISE 😄
                Matt666
                Thank you Pierre!
                A new version 1.2 is available... Try to fix Mac problems.
                My scripts
                  Merci!
                  it's working nicely now on my mac.
                  btw, i think the provided icon is too small.. it's 16x16 but SU can use 24x24 as well..
                  @simon le bon said:
                  But at the end we need to erase all those construction points!!!
                  No problem! Just use the so powerful Matt666's Selection Manager 😉 😉
                  another option is edit->delete guides.. not as powerful as selection manager but it will get rid of the points as well.
                    agrazdi
                    I found this plugin great.
                    But it could be excelent if after you inferrenced the distance with another object you could tape /# of spaces and add constructions points. Sort of dividing a line in 2,3,4.... spaces.
                    Is it possible to add this request ?
                    agrazdi
                    • I Offline
                      ilay7k
                      Matthieu, thank you
                      great addition for making of general plans
                        Matt666
                        Thank you!
                        agrazdi, I will see what I can do!
                        My scripts
                          simon le bon
                          Hi NewOne,
                          Your icons are NumberOne 😉
                          But when i try to use them (32x32), their quality isn't at the "rendez-vous" . Why? I can't say.
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Matt_Point.jpg
                          simon
                          • N Offline
                            NewOne
                            @simon le bon said:
                            Hi NewOne,
                            simon
                            Well... This is what I do now: try to figure out why on image viewer and on forum page the icon looks nice, but in Sketchup is a little messed up.
                            QUESTION: how many colors does sketchup accept for icons? true color, 256, or less? 😳
                              Jim
                              Sketchup Toolbar icons are 24x24, or 16x16 for the small icons. Tool cursors are 32x32.
                              • N Offline
                                NewOne
                                THANK YOU !!
                                I tested with 24x24 and it looks wonderfull.
                                • N Offline
                                  NewOne
                                  --EDITED POST-- changed the files, and added code suggestion.
                                  Alternate icons for PointTool
                                  Matt666, if you like this icons, please edit your script to use 24x24px and 16x16px icons.
                                  The changes I made to your script to accept those icons and cursor icon are:
                                  cmd.large_icon = File.join(p, "PointTool", "PointTool24x24.png")
                                  cmd.small_icon = File.join(p, "PointTool", "PointTool16x16.png")
                                  and
                                  def initialize
                                  #...your previous code
                                  p=Sketchup.find_support_file("Plugins")
                                  pointTool_cursor_path = File.join(p,  "PointTool", "PointTool cursor.png")
                                  @@pointTool_cursor = UI;;create_cursor(pointTool_cursor_path, 3, 30)
                                  def onSetCursor
                                  UI;;set_cursor(@@pointTool_cursor)
                                  I am not sure if this is entirely correct, but it works for me.
                                  If you decide to change the icons, pay attention on hotspot coordinates of the cursor 😉
                                  Suggestion: add getExtents method to avoid disappearance of the OpenGL line.
                                  def getExtents
                                  bbox = Geom;;BoundingBox.new
                                  	bbox.add @ip1.position
                                  	if (@state == 0)
                                  		bbox.add @ip.position if (@ip.valid? && @ip.display?)
                                  	elsif
                                  		bbox.add @ip2.position
                                  	bbox
                                  P.S. I like your script very much, it ease my work a lot! It's a simple, but strong idea!
                                  contains 16x16, 24x24 and 32x32 PNG
                                  visual example
                                  • N Offline
                                    NewOne
                                    for making the script to show cursor, see this post: http://forums.sketchucation.com/viewtopic.php?f=180&t=13077&st=0&sk=t&sd=a&start=15#p184325
                                    contains icons (24x24, 16x16) and cursor (32x32)
                                      simon le bon
                                      Hi NewOne,
                                      Thank for it (the blue pen) . Now adopted 👍 😉
                                      simon
                                      • W Offline
                                        watkins
                                        Dear Matt,
                                        I have downloaded your version 1.2, but cannot work out how to draw a single point other than hitting the Esc key. What should I do?
                                        Kind regards,
                                        Bob
                                        • utilerU Offline
                                          utiler
                                          @simon le bon said:
                                          Hi NewOne,
                                          simon
                                          I think JClements made the Construction line tool Icon. Would be good to see a similar icon for the point tool also.
                                          Both point and Construction line tool I use all the time, thanks heaps guys!!!!!
                                          Just Curious...
                                          • JClementsJ Offline
                                            JClements
                                            Try one of these.
                                            16x16
                                            • 2 / 3
