    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      chrischancc
      so a gorgeous plugin!!
      • EdsonE Offline
        Edson
        hi fredo,
        i followed your instructions but something is not right as i do not get the cubic bezier curves in any way. please have a look at the attached images. i am on mac.
        http://www.mahfuz.arq.br
        • fredo6F Offline
          Edson,
          It seems you got the same Mac OS issue (or Podium related) as Kannonbal.
          See this thread http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=15182. You'll find a modified version of the script.
          I still don't understand what was going on by the way, and any clarification from Mac users would be helpful for the future.
          • EdsonE Offline
            Edson
            fredo,
            it worked. thanks!
            the only remaining issue is that although the polyline segmentor function is working (and it shows in the contextual menu) its icon does not show in the toolbar. i had a look in the script's folder and there was no icon for it there. am i missing something?
            regards.
            • O Offline
              otb designworks
              Curiously, I am missing the same button image as Edson.
              Thankfully, though, no loss of functionality.
              Cheers, Chuck
              OTB Designworks is on Youtube
              • fredo6F Offline
                This is normal.
                I never designed an icon for it!
                  smithsam
                  First, I have to say, what an amazing plugin. I just discovered it today. Always frustrated by lack of Bezier curves in Sketchup. Wow!
                  I did discover one problem though. The documentation does not display. I get a blank window.
                  Mac 0S X 10.5.6 MacBook Pro Intel
                  Sketchup 7 Pro
                  doc.tiff
                    agpig
                    thank you man it's so helpful 😍
                    • EdsonE Offline
                      Edson
                      @watkins said:
                      Dear Frodo,
                      Kind regards,
                      Bob
                      watkins,
                      i just could not resist pulling your leg about the mix up of fredo6's username with the main character in The Lord of the Rings.
                      • W Offline
                        watkins
                        Dear Edson,
                        You are not the only one to spot that. I will have to be more careful in future.
                        Regards,
                        Bob
                          mattg
                          Just re-downloaded this for SU7.
                          Any reason why the toolbar won't hug the side of the screen.
                          Seems to only want to sit horizontally along the top.
                          • fredo6F Offline
                            Matt,
                            As you may know, scripts have zero control over the toolbar placement from Ruby.
                            So it must be SU7 or the configuration of the toolbar set.
                            In my SU7 environment, I don't have any particular issue.
                            • W Offline
                              watkins
                              Dear Mattg
                              You should be able to 're-shape' the rectangle of icons by searching for re-sizing arrows at the edges using the mouse pointer. Once re-shaped (horizontal rectangle to vertical rectangle) it can be placed along the side.
                              Regards,
                              Bob
                                mattg
                                Thanks Bob, too easy!
                                  jdspdx
                                  Thanks fredo! I have the same condition as smithsam - Quickcard and Tutorials open as blank boxes from Documentation menu. Both are in BZ_Dir_12. --- jdspdx
                                  • fredo6F Offline
                                    This seems to be related to the Mac platform, dealing with how Adobe PFD reader is installed or configured to ruun in web browser Safari.
                                    I would need other Mac users to advise and possibly gives hints on how to resolve this.
                                    • Bob JamesB Offline
                                      Bob James
                                      My two cents worth: I have no problem with any feature of Bezierspline on my Intel iMac.
                                      Also the pdf files located in the BZ_DIR_12 folder open in Adobe Reader 9.
                                        Ayashi
                                        Excellent plugin! Thank you dude!
                                        • mitcorbM Offline
                                          mitcorb
                                          Thanks, Fredo:
                                          I had a glance at this link and it looks very informative.
                                          • fredo6F Offline
                                            I discovered a remarkable tutorial on BezierSpline written by Scott Onstottfrom AECBytes at http://www.aecbytes.com/tipsandtricks/2009/issue42-sketchup.html. It will drive you with a step-by-step tour of the plugin, with all types of curves (much better than what I could do).
                                            • 22
                                            • 23
                                            • 2 / 23
