    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • EdsonE
      Edson
      fredo,
      it worked. thanks!
      the only remaining issue is that although the polyline segmentor function is working (and it shows in the contextual menu) its icon does not show in the toolbar. i had a look in the script's folder and there was no icon for it there. am i missing something?
      regards.
      http://www.mahfuz.arq.br
      • O
        otb designworks
        Curiously, I am missing the same button image as Edson.
        Thankfully, though, no loss of functionality.
        Cheers, Chuck
        OTB Designworks is on Youtube
        • fredo6F
          This is normal.
          I never designed an icon for it!
            smithsam
            First, I have to say, what an amazing plugin. I just discovered it today. Always frustrated by lack of Bezier curves in Sketchup. Wow!
            I did discover one problem though. The documentation does not display. I get a blank window.
            Mac 0S X 10.5.6 MacBook Pro Intel
            Sketchup 7 Pro
            doc.tiff
              agpig
              thank you man it's so helpful 😍
              • EdsonE
                Edson
                @watkins said:
                Dear Frodo,
                Kind regards,
                Bob
                watkins,
                i just could not resist pulling your leg about the mix up of fredo6's username with the main character in The Lord of the Rings.
                • W
                  watkins
                  Dear Edson,
                  You are not the only one to spot that. I will have to be more careful in future.
                  Regards,
                  Bob
                    mattg
                    Just re-downloaded this for SU7.
                    Any reason why the toolbar won't hug the side of the screen.
                    Seems to only want to sit horizontally along the top.
                    • fredo6F
                      Matt,
                      As you may know, scripts have zero control over the toolbar placement from Ruby.
                      So it must be SU7 or the configuration of the toolbar set.
                      In my SU7 environment, I don't have any particular issue.
                      • W
                        watkins
                        Dear Mattg
                        You should be able to 're-shape' the rectangle of icons by searching for re-sizing arrows at the edges using the mouse pointer. Once re-shaped (horizontal rectangle to vertical rectangle) it can be placed along the side.
                        Regards,
                        Bob
                          mattg
                          Thanks Bob, too easy!
                            jdspdx
                            Thanks fredo! I have the same condition as smithsam - Quickcard and Tutorials open as blank boxes from Documentation menu. Both are in BZ_Dir_12. --- jdspdx
                            • fredo6F
                              This seems to be related to the Mac platform, dealing with how Adobe PFD reader is installed or configured to ruun in web browser Safari.
                              I would need other Mac users to advise and possibly gives hints on how to resolve this.
                              • Bob JamesB
                                Bob James
                                My two cents worth: I have no problem with any feature of Bezierspline on my Intel iMac.
                                Also the pdf files located in the BZ_DIR_12 folder open in Adobe Reader 9.
                                  Ayashi
                                  Excellent plugin! Thank you dude!
                                  • mitcorbM
                                    mitcorb
                                    Thanks, Fredo:
                                    I had a glance at this link and it looks very informative.
                                    • fredo6F
                                      I discovered a remarkable tutorial on BezierSpline written by Scott Onstottfrom AECBytes at http://www.aecbytes.com/tipsandtricks/2009/issue42-sketchup.html. It will drive you with a step-by-step tour of the plugin, with all types of curves (much better than what I could do).
                                      • O
                                        oblin77
                                        Hello Fredo06
                                        Where I can find and download your plugin BezierSpline v1.21 ?
                                        thank you
                                        Best regards
                                        olivier de france
                                        • soloS
                                          Try the first page.
                                          • plot-parisP
                                            plot-paris
                                            don't know if that behavior is specific to my machinde. but when I have drawn a curve, then go into edit mode, press Ctrl to unlock allow curve points to be moved outside the initial drawing plane and then press the up arrow to lock it to a vertical direction, my cursor doesn't stick to the point anymore. meaning, that when I move up my cursor only by a tiny bit, the curve point shoots up vertically a lot faster, and in very wide increments too.
                                            if that is the general behavior of the plugin, would it be possible to change it, so that the point still sticks to the position of the curser (only the vertical position of course. to make things easier, a dotted horizontal line could be connecting the curve point and the curser).
                                            any ideas if thats possible?
                                            • 22
                                            • 23
                                            • 3 / 23
