    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 230.5k Views 52 Watching
    • fredo6F
      @djmx1 said:
      Par contre la transformation en fil de fer, ou la dégradation progressive, sont très longue dès que l'objet dépasse les 200ko (voir même plantage !)
      Si tu as une solution.
      Wireframe and Simplify options are rather for components that are not too complex, but would be repeated hundreds times in the model.
      In this version 1.0, I did not optimize the generation of Ghosts actually, as my primary goal was to understand whether the concept would be useful.
      @djmx1 said:
      J'avais fait un post sur le bounding box, et je ne sais pas si toi tu est capable de le faire, j'aurais voulu un plugin qui me permette d'activer une vue type
      bounding box, comme quand le fichier est trop lourd et que sketchup dégrade l'image en remplaçant les objet par des bounding box. C'est pas la même utilisation que GHOSTCOMP, et ça m'aurait bien rendu service.
      Dans l'attente.
      You can generate a Bounding Box Ghost for all objects (do a Select All before generation). The problem is to have a view where Ghosts are activated while in other views they are not.
      This again underlines that it should be the SU Team integrating this type of dual appearance concept in the native Sketchup application. In Ruby script, there are too many limitations to make something clean, fast, safe and transparent to the model (i.e. without creating tons of hidden components, use a hidden layer, ...).
      • K
        kwistenbiebel
        Fantastic Fredo!!
        This is a plugin I will use very often (always?). finally a way to keep on editing those high poly scenes (trees, etc...).
        I agree that a feature like this should be standard SU stuff, but I am glad you made it into a plugin.
        Thanks. Much appreciated
        • N
          notareal
          👍 A keeper.
          • I
            ideas_arte
            Wow !!!!! did not the boys at Google, you did!
            Greatly appreciated, I will be testing and commenting
            Thanx!! Thanx!! Thanx!! Thanx!!
            http://www.addemoticons.com/emoticon/animated/AddEmoticons04230.gif
            http://www.addemoticons.com/emoticon/animated/AddEmoticons04213.gif
            Greetings.
              Bigre 😲 ☀ 😎
              • W
                Whaat
                Another winner Fredo! I had a similar idea once but never got to implementing it. I also wanted to mention that I have been using your Round Corner script lately and it is incredible! Great work!
                • fredo6F
                  Thanks Dale. It shows that the Google SU team should have a closer look to what they could do natively in the Sketchup application, as this could be a useful complement to their quest for high-poly support.
                  • urgenU
                    urgen
                    ...thanks FREDO!...briliant! 👍 👍 👍 😄
                    --pupil forever...------
                    • P
                      Pg09
                      Thank You!
                      • StinkieS
                        Stinkie
                        Oooh, this one's going to come in very handy indeed. Thanks!
                        • W
                          wsms
                          it works really good!
                          this function shall be put in a new version of su
                          • erikBE
                            erikB
                            Thanks Fredo for this very handy pluging.
                            Much appreciated ! 👍
                            greetings, erikB
                              DJMX1
                              je poste mon petit pack d'icônes pour GHOSTCOMP. J'ai fait ça pour moi et je partage.
                              http://img2.pict.com/16/93/89/1543527/0/ghostcompv1.png
                              prendre les icônes et les copiées dans le dossier "IMAGES_Standard" du plugin GHOSTCOMP
                              http://www.box.net/shared/gv8ooblvog
                              • fredo6F
                                prendre les icônes et les copier dans le dossier "IMAGES_Standard" du plugin GHOSTCOMP
                                Thanks a lot.
                                Actually, the best is to create a subfolder IMAGES_DJMX1 in the folder GHOSTCOMP_DIR_10 and put the icons there. Then in the Default Parameters dialog box for GhostComp you can enable these icons. This way, you are sure that they won't be overwritten in a next release of GhostComp.
                                  DJMX1
                                  amazing! DJMX1 in a plugin of Fredo, I'm too happy! thank you
                                  • E
                                    Ecuadorian
                                    This is excellent for preparing renderings with tons of 3D vegetation, Thank you very much!
                                    An option to have just wireframes of the two bounding boxes options (recursive and simple) would be cool for the next version. ☀
                                    -Miguel Lescano
                                    • troyhomeT
                                      troyhome
                                      You're some kind of SketchUp Santa Claus! Thank You
                                      IOviz.com
                                      SU Pro 2024 PC
                                        stegagG
                                        What is the message in SU7 :
                                        Loading file error GhostCompAlgo.rb
                                        uninitialized constant GhostComp::T6Errore di caricamento del file GhostCompLoader.rb
                                        • fredo6F
                                          It looks like a problem of installation, most probably your Unzip programs not reconstructing the folder hierarchy.
                                          Check out the footprint of files and folder in the post and in the documentation.
                                          It seems that some users have this type of problem.
                                          By curiosity, which utility do you use to unzip the files?
                                            stegagG
                                            Sorry, but I have dome an error of unzip
                                            Hi.
                                            • 1 / 6
