    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 227.5k Views 52 Watching
    • K
      kwistenbiebel
      Fantastic Fredo!!
      This is a plugin I will use very often (always?). finally a way to keep on editing those high poly scenes (trees, etc...).
      I agree that a feature like this should be standard SU stuff, but I am glad you made it into a plugin.
      Thanks. Much appreciated
      • N
        notareal
        👍 A keeper.
        • I
          ideas_arte
          Wow !!!!! did not the boys at Google, you did!
          Greatly appreciated, I will be testing and commenting
          Thanx!! Thanx!! Thanx!! Thanx!!
          http://www.addemoticons.com/emoticon/animated/AddEmoticons04230.gif
          http://www.addemoticons.com/emoticon/animated/AddEmoticons04213.gif
          Greetings.
            Bigre 😲 ☀ 😎
            • W
              Whaat
              Another winner Fredo! I had a similar idea once but never got to implementing it. I also wanted to mention that I have been using your Round Corner script lately and it is incredible! Great work!
              • fredo6F
                Thanks Dale. It shows that the Google SU team should have a closer look to what they could do natively in the Sketchup application, as this could be a useful complement to their quest for high-poly support.
                • urgenU
                  urgen
                  ...thanks FREDO!...briliant! 👍 👍 👍 😄
                  --pupil forever...------
                  • P
                    Pg09
                    Thank You!
                    • StinkieS
                      Stinkie
                      Oooh, this one's going to come in very handy indeed. Thanks!
                      • W
                        wsms
                        it works really good!
                        this function shall be put in a new version of su
                        • erikBE
                          erikB
                          Thanks Fredo for this very handy pluging.
                          Much appreciated ! 👍
                          greetings, erikB
                            DJMX1
                            je poste mon petit pack d'icônes pour GHOSTCOMP. J'ai fait ça pour moi et je partage.
                            http://img2.pict.com/16/93/89/1543527/0/ghostcompv1.png
                            prendre les icônes et les copiées dans le dossier "IMAGES_Standard" du plugin GHOSTCOMP
                            http://www.box.net/shared/gv8ooblvog
                            • fredo6F
                              prendre les icônes et les copier dans le dossier "IMAGES_Standard" du plugin GHOSTCOMP
                              Thanks a lot.
                              Actually, the best is to create a subfolder IMAGES_DJMX1 in the folder GHOSTCOMP_DIR_10 and put the icons there. Then in the Default Parameters dialog box for GhostComp you can enable these icons. This way, you are sure that they won't be overwritten in a next release of GhostComp.
                                DJMX1
                                amazing! DJMX1 in a plugin of Fredo, I'm too happy! thank you
                                • E
                                  Ecuadorian
                                  This is excellent for preparing renderings with tons of 3D vegetation, Thank you very much!
                                  An option to have just wireframes of the two bounding boxes options (recursive and simple) would be cool for the next version. ☀
                                  -Miguel Lescano
                                  • troyhomeT
                                    troyhome
                                    You're some kind of SketchUp Santa Claus! Thank You
                                    IOviz.com
                                    SU Pro 2024 PC
                                      stegagG
                                      What is the message in SU7 :
                                      Loading file error GhostCompAlgo.rb
                                      uninitialized constant GhostComp::T6Errore di caricamento del file GhostCompLoader.rb
                                      • fredo6F
                                        It looks like a problem of installation, most probably your Unzip programs not reconstructing the folder hierarchy.
                                        Check out the footprint of files and folder in the post and in the documentation.
                                        It seems that some users have this type of problem.
                                        By curiosity, which utility do you use to unzip the files?
                                          stegagG
                                          Sorry, but I have dome an error of unzip
                                          Hi.
                                          • L
                                            latence
                                            Fredo THANK YOU for all your great work!
                                            • 1 / 6
