    [Locked] 2D Toolset - Use Newer Version Link
    56 Posts 20 Posters 92.1k Views 20 Watching
      Ben Ritter
      TIG, thank you.
      • EarthMoverE Offline
        EarthMover
        I'd be interested in seeing some 2D boolean functions added. Standard add, subtract and perhaps one that will allow you to draw a bunch of overlapping shapes and it will remove all the interior lines and just leave the perimeter shape. Essentially automating the intersect and removal of unwanted lines to create secondary shapes.
        Is it possible to toggle the tools to draw CLines by hitting CTRL? Similar to how Fredo did with TOS. Not so important for the line tools but it would be a helpful feature for the Arc and Circle tools.
        Another thing I was wondering is if you could have a tool that would define the height of Z. If you click on a point that is, let's say, 96" up on the Z, then all the tools would draw flat on that Z height. This would be nice for drawing out 2nd story floorplans and such.
        Also, with the polyline curve tool....is there a way you could then translate the series of polylines into a flowing set of Arcs? Every other vertex would define the span of the arc and the middle verticies would define the bulge. Similar to the technique for your 2D arc tool, but just allowing you to draw out a series of polylines and having it translate into to tangent arcs. Similar to how you can convert polylines to curve splines in Fredo's Bezier tools. Just a thought.
        Thanks again TIG!
        Content Creator at Skapeup
          Ben Ritter
          TIG,
          The hatch dialog doesn't appear for me.
          Ben
            Jim
            Hi TIG,
            Don't assume the variable $exStrings is defined. It is for most people, but not for all. It is originally defined in one of the rubies that came with SketchUp - but not everyone loads those.
              @jim said:
              Hi TIG,
              Point taken.
              I just quickly clobbered these tools together from stuff mainly based on the linetool ruby that had it in... I'll trap it in the next release...
                Here's another update - with potential $exStrings problem circumvented...
                http://forums.sketchucation.com/viewtopic.php?p=180259#p180259
                  @ben ritter said:
                  TIG,
                  Ben
                  Have you put the '2DtoolsIcons' folder into the Plugins folder. In that there should be a folder called 'Hatching' containing the jpgs ? What does the Ruby Console say when it fails ?
                    Here's this morning's update with improve undo for 2D polyline/curves etc...
                    • honoluludesktopH Offline
                      honoluludesktop
                      TIG, So far so good, NO Great! If you get around to expanding the software set, how about triming; both, to the intersection of, and in reference from 🙂
                        anglaret
                        Thanks TIG,
                        it is very interesting that somebody care about 2D.I work a lot in 2d
                        The hatch tool is very nice
                        I have a tedious problem with drawing doors, and I remember asking Google
                        to put in SU the "pie" tool that exists in Layout:
                        click on a point, go to the distance you like, click again than you can draw
                        a pie : radius is fixed, and 2 sides of the pie are drawn
                        In 3 clicks you draw a door
                        Marc
                        • EdsonE Offline
                          Edson
                          hi tig,
                          it is not working for me. i followed your instructions but something is not right. can you help me? what do you mean by "The 2D#.rb needs to load before the others to make the sub-menu and toolbar..."? what can i do for it to happen? thanks.
                          2 images attached: one with the error message i get, the other showing the files i heve on my plugins folder.
                          http://www.mahfuz.arq.br
                            Edson
                            You are Mac ? I'll investigate... I doesn't like the status_text ??? Seems that if first part is in () the second after the ',' confuses it ! BUT not on a PC - I'll ensure the update avoids that possibility...
                            I am working on v2.0 which is quite different, so that might avoid the problem - perhaps needs a day or two...
                            Please hang in there... 😄
                              anglaret
                              Tig
                              I would be more precise
                              In Layout tools/arc/pie; is a brillant and simple tool that draw doors from above
                              I would be very very grateful for that tool in SU
                              Marc
                              • EdsonE Offline
                                Edson
                                @tig said:
                                Edson
                                yes, tig, i am on mac. thanks for looking into this. this promises to be one more of your greatly useful plugins.
                                  @anglaret said:
                                  Tig
                                  Marc
                                  I intend that they'll be something like that in v2... ➡
                                    honoluludesktop
                                    TIG, Out of curosity, how much time did it take you do do the plugin? Did you have templates to work from? As a retired amature programmer (pre OOPS), I find this kind of coding compact. Maybe I could learn something about ruby if you documented a little:-), or maybe I am just a old dog that can't:-( Good work.
                                      I took a few hours to get the first code out - look at the early exchanges with Jim -I based it on several pre-existing ideas... it then grew 'like topsy'... So far it's taken a couple of days to get where we are, on and off - I was away this weekend 'resting' and had T some better ideas for v2 that will be out soonest...
                                      • FletchF Offline
                                        Fletch
                                        TIG,
                                        I have wished for these tools since like the first day of using SketchUp!
                                        Now SU can be an illustration tool too (I use it for this sometimes, logo design, etc.)
                                        But now also I can trace these freaky CAD plans that look like they are flat but they are not, etc.
                                        THANKS A MILLION... you are a legend in your own time.
                                        Fletch
                                        • utilerU Offline
                                          utiler
                                          Hi TIG, downloaded the latest 2Dtoolset and having a play....
                                          I noticed a few things that you may wish to review:
                                          1. 2D Polyline doesn't acknowledge when it is on an axis. [change to green or red and tooltip to say "On Green axis"]
                                          2. 2D Arc doesn't reference axises at all.
                                          3. 2D circle doesn't acknowledge when it is on an axis either. [as per 2D polyline]
                                          Wishlist
                                          1. Arc to recognize tangents
                                          2. Can 2D rectangle produce a closed entity?
                                          Well done, mate, this is a great addition to GSU!!!
                                          Just Curious...
                                            Wishlist
                                            Your items are already on the list for v2, as is wish 1. Wish 2 - we could make it a modifier key - e.g. raw rectangle is lines, with alt key it's a loop...
                                            • 2 / 3
