    [Locked] 2D Toolset - Use Newer Version Link
    56 Posts 20 Posters 91.9k Views 20 Watching
      @pixero said:
      It very good already.
      No harm in wishing, ehe?
      What about the Polyline curve tool?
      Is it just me or is there a bug?
      What sort of bug ?
      • PixeroP Offline
        Pixero
        If I make a open form the lines are separated but if I draw a closed form they are turned into one.
        How are we meant to exit the tool? I clicked esc.
        • kenK Offline
          ken
          Thanks. The hatching is a win for me.
          Feedback. I know that when you think of 2d drawing, the Z axis is at a zero elevation. However, at least on my machine, the orbit tool works better when the drawing is done using the Front view. I never can get the orbit tool to behave to my request in the Top View. And why would I need the use of the orbit tool when doing 2d drawing. Well, after using Sketchup for the last couple of years, I try an orbit everything, even Word and Xcel documents. Therefore, it is a learned response. However, I do feel I get more info from the drawing when I orbit.
          Again thanks for the tools.
          Ken
          • honoluludesktopH Offline
            honoluludesktop
            TIG, Wow, having 2D icons make putting the commands directly on the "draw" menu for quick access unnecessary. Fantastic.
            • EarthMoverE Offline
              EarthMover
              Nice update TIG! Can you tell me how to get the polyline curve to work? Is there a way to tell the script you are finished drawing the segments so it can convert them to a "curve"?
              Content Creator at Skapeup
                I'll look at it...
                  The PolylineCurve works much as the PolylIne Tool - you click on a line end twice or the start point of the first line to say you are done. The difference is that it then converts the points to a Curve at the end and any loose edges should be erased - obviously it sounds like it's not doing that ! I'll investigate... When I am more awake tomorrow ☀
                  • bagateloB Offline
                    bagatelo
                    Would it be possible a tool that draw rectangles with round corner?
                    I thank your efforts in any way.
                      DIEGO-RODRIGUEZ
                      Tig, I have been some errors running the plugins
                      http://www.youtube.com/watch?v=_UZUfNm8STk
                      suggestion:
                      You can add
                      - Double Line Tool?
                      - Ellipse Tool (defined by its 2diameters)?
                      http://www.youtube.com/watch?v=G_t_gMqP8lM
                      - Polygon Tool of xsides (defining the length of one side)?
                      http://www.youtube.com/watch?v=lYniLhupg1Q
                        Today's update available here http://forums.sketchucation.com/viewtopic.php?p=180259#p180259
                        Main changes are:
                        Return/Enter now ends the Polyline and PolylineCurve Tools and draws geometry.
                        Esc during the Tool now undoes the last Polyline and PolylineCurve pieces draw up to then.
                        PolyLineCurve Tool now draws both looped and open-ended curves, BUT if they branch - e.g. you draw a loop back onto one of the set's earlier edges mid-point - then it'll make the best curve it can out of what it has, and the rest will stay as loose lines.
                        Default number of segments for Arc and Circle now = 18, this can be set different for an Arc and a Circle, AND any changed values a remembered during that session in that model.
                        Arc now draws a ghost-arc as you stretch it out.
                        Circle now draws a ghost-circle as you stretch it out.
                        Hopefully this will address some of the errors reported... 😒
                        On the other requests:
                        A Rectangle with Rounded Corners
                        • I'd use the Rectangle Tool and then use a 'fillet' or 'rounded-corners' tool to round its corners (there are several available - I use Ktools's 'Make-L'tool); or you could use the main Arc tool and draw tangential arcs at the corners - you can use Entity-Info to change its radius etc - then erase the unwanted bits ?
                          I don't know of an tool to do it right off. I've no plans to make one - sorry...
                        A Double-Line Tool
                        • Didier Bur has already made one - it works fine in 2D too - dline.zip on http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_geo_page.htm
                        An Ellipse Tool
                        • Didier Bur has already made one - it works fine in 2D too - Ellipse.zip on http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_geo_page.htm
                        A Polygon Tool with set side dimension.
                        • You could make a Polygon using the main Polygon tool of the 2D Circle tool with required number of edges/segments set, but that has a given radius rather than a side length. You also need to rotate it to the orientation angle you want. To make it a given side length draw a Polygon and then immediately group it. Edit that group and use the Tapemeasure tool and pick two vertices of an edge; now type in the size you want as units (e.g. 500mm) and it'll ask you if you want to scale everything, say 'Yes' - remember that this scaling is limited to the current active_entities, so don't panic - the polygon inside the group will now have its edges at the desired length: exit the group and explode it... I have a Polygon.side=1234 method that I might publish one day...
                        Any other ideas ? ❓
                          Ben Ritter
                          TIG, thank you.
                            EarthMover
                            I'd be interested in seeing some 2D boolean functions added. Standard add, subtract and perhaps one that will allow you to draw a bunch of overlapping shapes and it will remove all the interior lines and just leave the perimeter shape. Essentially automating the intersect and removal of unwanted lines to create secondary shapes.
                            Is it possible to toggle the tools to draw CLines by hitting CTRL? Similar to how Fredo did with TOS. Not so important for the line tools but it would be a helpful feature for the Arc and Circle tools.
                            Another thing I was wondering is if you could have a tool that would define the height of Z. If you click on a point that is, let's say, 96" up on the Z, then all the tools would draw flat on that Z height. This would be nice for drawing out 2nd story floorplans and such.
                            Also, with the polyline curve tool....is there a way you could then translate the series of polylines into a flowing set of Arcs? Every other vertex would define the span of the arc and the middle verticies would define the bulge. Similar to the technique for your 2D arc tool, but just allowing you to draw out a series of polylines and having it translate into to tangent arcs. Similar to how you can convert polylines to curve splines in Fredo's Bezier tools. Just a thought.
                            Thanks again TIG!
                              Ben Ritter
                              TIG,
                              The hatch dialog doesn't appear for me.
                              Ben
                                Jim
                                Hi TIG,
                                Don't assume the variable $exStrings is defined. It is for most people, but not for all. It is originally defined in one of the rubies that came with SketchUp - but not everyone loads those.
                                  @jim said:
                                  Hi TIG,
                                  Point taken.
                                  I just quickly clobbered these tools together from stuff mainly based on the linetool ruby that had it in... I'll trap it in the next release...
                                    Here's another update - with potential $exStrings problem circumvented...
                                      @ben ritter said:
                                      TIG,
                                      Ben
                                      Have you put the '2DtoolsIcons' folder into the Plugins folder. In that there should be a folder called 'Hatching' containing the jpgs ? What does the Ruby Console say when it fails ?
                                        Here's this morning's update with improve undo for 2D polyline/curves etc...
                                          honoluludesktop
                                          TIG, So far so good, NO Great! If you get around to expanding the software set, how about triming; both, to the intersection of, and in reference from 🙂
                                            anglaret
                                            Thanks TIG,
                                            it is very interesting that somebody care about 2D.I work a lot in 2d
                                            The hatch tool is very nice
                                            I have a tedious problem with drawing doors, and I remember asking Google
                                            to put in SU the "pie" tool that exists in Layout:
                                            click on a point, go to the distance you like, click again than you can draw
                                            a pie : radius is fixed, and 2 sides of the pie are drawn
                                            In 3 clicks you draw a door
                                            Marc
                                            • 2 / 3
