    Twilight Render is Out
    extensions
    74 Posts 28 Posters 18.3k Views 28 Watching
      kwistenbiebel
      @notareal said:
      ...But if you did mean Twilight ws KT, those should be quite similar... but it's much up to engine version and used settings. Twilight is just much much more streamlined.
      re important...
      Yes, that's what I meant. Thanks for explaining.
      I'll be sure to try it out.
        avariant
        @chris fullmer said:
        I'm just hoping that at some point I find the "register" button on their forums...
        Registration is done on the front page of the website, http://www.TwilightRender.com. There should be a 'Create Account' link on the lower left side. The forum is tied into the website, so one registration works for both.
        @dale said:
        Sadly, appears to be windows only?
        For now it's windows only, but we do hope to put out a Mac version as soon as possible.
        • H Offline
          hobbnob
          😞 its such a shame about the price, i doubt any sp users will even bother with the trial version because of this. anyways, i have bothered to do as such, and there is no way of recording animations. can anyone help or is this just another app with false claims?
          My WIP Thread:Here
          • FrederikF Offline
            Frederik
            I'm really not sure what you mean... πŸ˜•
            Do you feel that 59,00 USD is expensive for such a powerfull build-in render application...??
            Look at the alternatives... They're much more expensive and haven't got a fraction of the features Twilight Render has... πŸ˜‰
            I assume that you are doing something wrong, cause this is definitely not a false claim...!!
            Checkout the SketchyPhysics animation: Blugarero thread at the Twilight forum and you'll see... πŸ˜‰
            Or check out the animation thread...
            You have the option to make:
            Fly through rendered animations
            Scenes where only the sun/sky is animated
            AND (as the only render application I know of)
            Animations using Animated objects (SkethcyPhysics)
            Please don't try to spread such false claims, without checking things first... πŸ˜„
            Cheers
            Kim Frederik
            • PixeroP Offline
              Pixero
              After a quick test I couldnt find where to make settings like anti alias quality and such? (Shadows were a bit grainy.)
              • N Offline
                notareal
                I think there is no direct setting for AA and such, but presets are just xml files. Reasonable easy to tune, if needed.
                • H Offline
                  Howard leslie
                  After a quick test - A few observations / questions....
                  1. Pages (Scenes) with Sections - did not appear to render as expected (Section Cut Disappeared in Rendered Version, Model was whole again - no section cut displayed).
                  2. On a large model, a couple of Layers that I thought I'd turned off in the Scene had reappeared again on the Rendered Version - anyone else notice this or was it just me ???
                    Didn't notice it but is it possible to batch the renders ???
                    ie queue up a whole load of models / scenes and then run them overnight for example ???
                  • Maybe dump them out to Windows Task Scheduler ???
                  (I did see the option to run a single render in the background while carrying on modelling in SU).
                  Seems quite promising though.
                  Congratulations to everyone who has been involved with producing Twilight on getting this far.
                  Regards
                  Howard L'
                  • FletchF Offline
                    Fletch
                    hi hobbnob,
                    you will find all info you need on rendering your SketchyPhysics animations on Pages 14-15 of the user manual... and in this thread.
                    please come join us at the Twilight forum for questions on how things work, we are happy to help. πŸ˜‰
                    I do believe there will be many SP (SketchyPhysics) users who would LOVE to render their awesome work with this great plugin. This is why we worked so hard to make it possible.
                    hint: use the "animation" presets when rendering SP animations... and be sure you've followed the manual's advice for animations.
                    Please see this demo video or this demo vid... no false claims πŸ˜‰
                    Fletch
                    • FletchF Offline
                      Fletch
                      1. Pages (Scenes) with Sections - ...
                      2. On a large model, a couple of Layers that I thought I'd turned off ...
                        ...batch the renders ???
                        ...Seems quite promising...Congratulations to everyone who has been involved with producing Twilight
                      Hi Howard,
                      1- SketchUp's unique ability to show a section cut does not translate to any render engine I am aware of yet... πŸ˜•
                      This issue is discussed in the user manual on page 11 topic 1, but in short, you will need to use Whaat's Zorro2 plugin to create your section and then render it with Twilight.
                      2- Please join us at the Twilight Community to ask troubleshooting probs. This is the SketchUcation forum, and I would like to respect that. But you can please send me the file at SFletcher-at-twilightrender dot com
                      3 - Batch Render works well in Twilight, via the animation panel, see the Reference Section of the Manual called "Batch Render".
                      Fletch
                      • FletchF Offline
                        Fletch
                        re:AA quality, the simple answer is to simply choose the "next step up" in render quality from the "Easy" settings.
                        The long answer is here. πŸ˜‰
                        Please feel free to ask questions like this in the Twilight Forum. I am known for being quite helpful and easy to work with πŸ˜‰ But I also realize one tends to avoid joining "yet another forum" at first... but when you're ready, you can join here. πŸ˜„
                        Fletch
                        • EarthMoverE Offline
                          EarthMover
                          A test render from a recent design. I really like the UI. I think it's simple, but allows you to go deeper if you'd like. I noticed no support for transparent .tif images, but .png will render fine. I also really like the ability to choose certain items in sketchup and render them as an alpha for post processing. A render region option would be nice, but I don't see it anywhere.
                          Kim and Fletch, you guys will be getting my $59 tonight and I'll pass the word along to my sketchup using friends who don't frequent SCF. I wish you much success with the project.
                          Also, just curious.....what will the price be after the special introductory price is done?
                          Content Creator at Skapeup
                            Pg09
                            Hey Fletch, Frederik!
                            Long time no see! I was surprised to see another project beside KT and Thea but i will def check it out.
                            You guys are not involved in Thea development?
                            • X Offline
                              xrok1
                              AWSOME! i specially like the material templates.
                              a god send for the materially challenged like me πŸ˜•
                              πŸ‘ πŸ‘ πŸ‘
                              • david_hD Offline
                                david_h
                                Um . . .how do we know this isn't just Podium 2 in disguise?
                                • soloS Offline
                                  You would have seen Sepo posting his thumbs up. πŸ˜„
                                  • david_hD Offline
                                    david_h
                                    Good Point. Olishea would be doing hand stands as well.
                                    • X Offline
                                      xrok1
                                      and... it would cost more πŸ˜‰
                                      • X Offline
                                        xrok1
                                        i just got some weird results? i rendered the cabin scene after using chris's scale and rotate script, now there seems to be some weird z-depth thing. the grass renders on top of the cabin even though its phisically behind it in the scene. i'll upload the file so others can try it???????cabinz.jpg
                                        cabin2.skp
                                          As for "batch render mode" (rendering a bunch of preset scenes in SU) it should work just like it does in "plain" SU; set your scene transition to (say) 1 second and export as animation with 1 fps - i.e. it will export one image per scene.
                                          (This also works the same way in Kerkythea).
                                          Make sure NOT to choose a progressive rendering preset however πŸ˜„
                                            john.warburton
                                            Not unique Fletch. MicroGDS has this, AND will preserve the cut when rendering (AND imports Sketchup SKP files.)
                                            Life's a reach, and then you gybe.
                                            • 2 / 4
