    Reed-texture
    18 Posts 6 Posters 7.2k Views 6 Watching
      Hi Remon,
      I can try to make a displacement map (or would a normal map also work in Vray?).
      Is the texture (the original) royalty free however?
      • soloS Offline
        Hope this helps.
        Displacement map
        Spec map
        Normals map
          remon_v
          hey very nice! I downloaded the texture from cgtextures.com for free. Only it wasn't tileable and the lighting wasn't correct so I corrected it. Dunno if that's what's you're asking. I'm going to try the texture now and I'll show you the result. Only where should I put the normal map?
          remon_v
            You either use the displacement map or the normal map. Not sure where it should go in V-ray though...
              remon_v
              the displacement is working but not like I want it to work.... but that can be me though because I'm only using vfsu for a few months now. I'll try to create one myself. Oh and vfsu doesn't support normal maps (Jackson told me).
              remon_v
                remon_v
                oke with this texture blurred displacement maps don't really work I thing. I did some test and I got the best result (so far) with this map:
                http://i22.photobucket.com/albums/b336/remon_v/reeds_thatch_DISP3.png
                this is the result:
                http://i22.photobucket.com/albums/b336/remon_v/displacement.png
                any suggestions to improve it??
                remon_v
                • soloS Offline
                  Looks like a great Coir mat now.
                    remon_v
                    I used solo's displacement map to bump it.... maybe that's a better sollution 😄
                    http://i22.photobucket.com/albums/b336/remon_v/bump.png
                      remon_v
                      yeah but Jackson told me it can only displace in that direction. As I would like to see it more to overlay each other.
                        remon_v
                        http://i22.photobucket.com/albums/b336/remon_v/9.png
                        made some renders from my WIP where I had to use the reed texture for.
                        It gives a strange effect of displacement at some points. The roof is smoothed and when I click it is "1 face" now. Maybe that's the problem and I should subdivide the face into smaller faces? And is it possible to subdivide after smoothing?
                        remon_v
                          Aerilius
                          I'm not an expert about displacement, but as far as I know, smoothing is only a shading technique, so you have the same amount of faces, but they look smooth. I think the renderer creates geometry from the displacement map, so the subsequent smoothing will have no effect. Try to subdivide.
                            remon_v
                            yeah I guess your right... thnx I will do some experimenting tomorrow when I'm at the office.
                            remon_v
                            • F Offline
                              fymoro
                              Hi remon_v,
                              Here is my try to help you to solve the displacement problem that you have.
                              For this kind of texture, I would prefer to use a displacement map like attached here.
                              you can see the result:
                              • Use this map for the displacement at 0.15 in the material setting
                              • And in the render option, change the EDGE LENGTH PIX parameter from 4 to 2.5.
                              I hope that this try help you, Cheers Fred.
                              Displacement Map
                              Test Render
                              http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                                remon_v
                                hey fymoro,
                                Really apreciate your help.
                                I know about the edge lenght... I think I even put it at 1.
                                Nice render... I will give it a try.
                                cheers
                                remon_v
                                  dylan
                                  The image of the barn is looking fantastic.
                                  It's a really nice model and rendering 👍
                                  http://dmdarchitecture.co.uk/
                                    To me, it rather looks like the triangulation of the (non planar) roof seems through. When smoothing extreme angles (like 120 degrees or less for instance), the smoothing will always look surrealistic.
                                      remon_v
                                      thnx Dylan.... it's still a WIP so I'll post some new renders when I'm done.
                                      I already undid the smoothing. I'll experiment with the roof when I got some free time.
