    Reed-texture
    18 Posts 6 Posters 7.5k Views 6 Watching
      remon_v
      I used solo's displacement map to bump it.... maybe that's a better sollution 😄
      http://i22.photobucket.com/albums/b336/remon_v/bump.png
        remon_v
        @solo said:
        Looks like a great Coir mat now.
        yeah but Jackson told me it can only displace in that direction. As I would like to see it more to overlay each other.
          remon_v
          http://i22.photobucket.com/albums/b336/remon_v/9.png
          made some renders from my WIP where I had to use the reed texture for.
          It gives a strange effect of displacement at some points. The roof is smoothed and when I click it is "1 face" now. Maybe that's the problem and I should subdivide the face into smaller faces? And is it possible to subdivide after smoothing?
          remon_v
            Aerilius
            I'm not an expert about displacement, but as far as I know, smoothing is only a shading technique, so you have the same amount of faces, but they look smooth. I think the renderer creates geometry from the displacement map, so the subsequent smoothing will have no effect. Try to subdivide.
              remon_v
              yeah I guess your right... thnx I will do some experimenting tomorrow when I'm at the office.
              remon_v
              • F
                fymoro
                Hi remon_v,
                Here is my try to help you to solve the displacement problem that you have.
                For this kind of texture, I would prefer to use a displacement map like attached here.
                you can see the result:
                • Use this map for the displacement at 0.15 in the material setting
                • And in the render option, change the EDGE LENGTH PIX parameter from 4 to 2.5.
                I hope that this try help you, Cheers Fred.
                Displacement Map
                Test Render
                http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                  remon_v
                  hey fymoro,
                  Really apreciate your help.
                  I know about the edge lenght... I think I even put it at 1.
                  Nice render... I will give it a try.
                  cheers
                  remon_v
                    dylan
                    The image of the barn is looking fantastic.
                    It's a really nice model and rendering 👍
                    http://dmdarchitecture.co.uk/
                    • GaieusG
                      To me, it rather looks like the triangulation of the (non planar) roof seems through. When smoothing extreme angles (like 120 degrees or less for instance), the smoothing will always look surrealistic.
                        remon_v
                        thnx Dylan.... it's still a WIP so I'll post some new renders when I'm done.
                        I already undid the smoothing. I'll experiment with the roof when I got some free time.
