    Reed-texture
    18 Posts 6 Posters 7.0k Views 6 Watching
      remon_v
      I made this reed texture I want to use in my renders (vray for su) and share with you guys.
      I got it from cgtextures.com but I made it tileable.
      The Second thing is I don't have a displacement map for it and I'm not really good with it.
      It would be nice if anyone can create it and put it here aswell as I don't know how I would create one for this texture.
      here it is:
      http://i22.photobucket.com/albums/b336/remon_v/reed-texture.jpg
      cheers
      remon_v
        Hi Remon,
        I can try to make a displacement map (or would a normal map also work in Vray?).
        Is the texture (the original) royalty free however?
        • soloS Offline
          Hope this helps.
          Displacement map
          Spec map
          Normals map
            remon_v
            hey very nice! I downloaded the texture from cgtextures.com for free. Only it wasn't tileable and the lighting wasn't correct so I corrected it. Dunno if that's what's you're asking. I'm going to try the texture now and I'll show you the result. Only where should I put the normal map?
            remon_v
              You either use the displacement map or the normal map. Not sure where it should go in V-ray though...
                remon_v
                the displacement is working but not like I want it to work.... but that can be me though because I'm only using vfsu for a few months now. I'll try to create one myself. Oh and vfsu doesn't support normal maps (Jackson told me).
                remon_v
                  remon_v
                  oke with this texture blurred displacement maps don't really work I thing. I did some test and I got the best result (so far) with this map:
                  http://i22.photobucket.com/albums/b336/remon_v/reeds_thatch_DISP3.png
                  this is the result:
                  http://i22.photobucket.com/albums/b336/remon_v/displacement.png
                  any suggestions to improve it??
                  remon_v
                  • soloS Offline
                    Looks like a great Coir mat now.
                      remon_v
                      I used solo's displacement map to bump it.... maybe that's a better sollution 😄
                      http://i22.photobucket.com/albums/b336/remon_v/bump.png
                        remon_v
                        yeah but Jackson told me it can only displace in that direction. As I would like to see it more to overlay each other.
                          remon_v
                          http://i22.photobucket.com/albums/b336/remon_v/9.png
                          made some renders from my WIP where I had to use the reed texture for.
                          It gives a strange effect of displacement at some points. The roof is smoothed and when I click it is "1 face" now. Maybe that's the problem and I should subdivide the face into smaller faces? And is it possible to subdivide after smoothing?
                          remon_v
                            Aerilius
                            I'm not an expert about displacement, but as far as I know, smoothing is only a shading technique, so you have the same amount of faces, but they look smooth. I think the renderer creates geometry from the displacement map, so the subsequent smoothing will have no effect. Try to subdivide.
                              remon_v
                              yeah I guess your right... thnx I will do some experimenting tomorrow when I'm at the office.
                              remon_v
                              • F Offline
                                fymoro
                                Hi remon_v,
                                Here is my try to help you to solve the displacement problem that you have.
                                For this kind of texture, I would prefer to use a displacement map like attached here.
                                you can see the result:
                                • Use this map for the displacement at 0.15 in the material setting
                                • And in the render option, change the EDGE LENGTH PIX parameter from 4 to 2.5.
                                I hope that this try help you, Cheers Fred.
                                Displacement Map
                                Test Render
                                http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                                  remon_v
                                  hey fymoro,
                                  Really apreciate your help.
                                  I know about the edge lenght... I think I even put it at 1.
                                  Nice render... I will give it a try.
                                  cheers
                                  remon_v
                                    dylan
                                    The image of the barn is looking fantastic.
                                    It's a really nice model and rendering 👍
                                    http://dmdarchitecture.co.uk/
                                      To me, it rather looks like the triangulation of the (non planar) roof seems through. When smoothing extreme angles (like 120 degrees or less for instance), the smoothing will always look surrealistic.
                                        remon_v
                                        thnx Dylan.... it's still a WIP so I'll post some new renders when I'm done.
                                        I already undid the smoothing. I'll experiment with the roof when I got some free time.
