    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 242.5k Views 61 Watching
    • CadFatherC
      CadFather
      wonder if anyone has the same thing - when i use extrude lines, i cannot draw the vector easily - it stop/starts or disappears.
      only with difficulty i can align it along an axis..
      will keep an eye if there's a clash somewhere
      • Bob JamesB
        Bob James
        @boilingsnow said:
        What you have is not the latest version...so you can get or the buttons loaded.
        The Projection folder I have is dated 6 July 2009 and I downloaded the "Projection Patch" but I don't see any difference. What am I missing?
        • CadFatherC
          CadFather
          Hi Didier,
          this is what's happening - the inferencing works well when you have faces behind the cursor.
          it snaps strangely when in empty space
          thought i'd cheer you up for the day... ๐Ÿ˜’ ๐Ÿ˜„
            It's me or when using undo with for exemple the Extrude line along a vector all the lines are killed ๐Ÿ˜ฎ
            It's some annoying when you have made 10 extrude lines successive all is to remake ๐Ÿ˜‰
            Does not possible to have a real undo successive?
            • Didier BurD
              Didier Bur
              Hi Pilou,
              Someone asked me (a long time ago I confess) to have a global undo instead of a step by step undo. How to satisfy everybody ?
              In french: on m'a demandรฉ il y a longtemps de faire un annuler global plutรดt que par รฉtape. c'est l'un ou l'autre, c'est difficile de contenter tout le monde...
              DB
              • Didier BurD
                Didier Bur
                Nothing. The new RBS is an update of the "extrude lines tool" to have smoothed surfaces when extruding curves, arcs, and circles.
                Regards,
                DB
                • Didier BurD
                  Didier Bur
                  Hem hem,
                  Inference when there's no face behind cursor snaps to the Red-Green plane as I see ๐Ÿ˜ฎ
                  Must look into it...
                  DB
                    Damned! ๐Ÿ˜ฎ
                    It's very more subtle to have a partial Undo than a global Undo for this sort of function (just 10 clicks than a painful remake ๐Ÿ˜ฎ
                    It's even absurd! ๐Ÿ˜ฎ
                    As the drawing of the vector is not so evident, an error is speedy arrived! ๐Ÿ˜ณ
                    I am very disappointed ๐Ÿ’š
                      DIEGO-RODRIGUEZ
                      a question.
                      How can extrude line and get the result of this image?
                      http://forums.sketchucation.com/download/file.php?id=29592&t=1
                        TIG's extrudeEdgesByRails.rb... NOT yet on general release...
                          dylan
                          Look forward to it's release TIG ๐Ÿ‘
                          http://dmdarchitecture.co.uk/
                          • H
                            Heven7_floor
                            Thanks for your wonderful created things โ˜€
                            and kindly sharing for helpfully used in SU ๐Ÿ’š
                            Cheer ๐Ÿ‘ ๐Ÿ‘
                            • EdsonE
                              Edson
                              hi didier,
                              would it be possible to include something in the code of PROJECTIONS that would remember the state of the tool bar (open or closed) when sketchup is opened, much like you did for Layer Manager? ok, you suggested we do it but it works the same way.
                              thanks.
                              edson mahfuz, architect| porto alegre โ€ข brasil
                              http://www.mahfuz.arq.br
                              • K
                                K-TEE
                                the best mission
                                • Didier BurD
                                  Didier Bur
                                  mission
                                  ??? ๐Ÿ˜ฒ
                                  DB
                                  • aadbuildA
                                    aadbuild
                                    Well done Didier, I dont know if any one else uses this for dimensioning but it saves so much time. I use guides to dimension so that the leader does not go through the model. It takes hours to dimension this way and now it takes minutes.
                                    One question I read on the sketchucation forum that this plugin lets you assign attributes to faces . I did not see this... Must be a miss print
                                    Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                                    https://www.plusspec.com
                                    • K
                                      kenc3dan
                                      Hi Didier,
                                      It doesn't work at all in 7.1 for me on Windows XP.
                                      I've read this entire thread and I can confirm that I have...
                                      -projection_extension.rb in the Plugins folder
                                      -All the PNGs and projection.rbs in the Projection folder inside the Plugins folder.
                                      I can't wait to check this thing out! Such a cool set of tools!
                                      Please let me know if there is some more recent version.
                                      I've tried the version in your first post...
                                      Re: [plugin] Projections version 2 UPDATED 03.07.09
                                      and I've tried the patch in that same post.
                                      Thanks so much!
                                      • K
                                        kenc3dan
                                        Cancel that. ๐Ÿ˜•
                                        Oops, forgot to activate the Projections toolbar under View > Toolbars.
                                        Maybe this is happening to others?
                                        Thanks again!
                                          @didier bur said:
                                          Developpers note: anyone knows how to smooth surfaces ? entity.smooth=true doesn't seem to work as expected.
                                          You must soft and smooth
                                          Smooth only hides the edge and makes the adjacent faces be treated as one surface.
                                          To blend the shading of the adjacent faces you must also apply soft. Soft alone does not hide the edge - it only affects the face's shading.
                                          Example in this thread:
                                          http://forums.sketchucation.com/viewtopic.php?f=15&t=23239#p196744
                                          • EdsonE
                                            Edson
                                            unfortunately, projections ceased to work for me on mac after i installed sketchup 7.1.
                                            • 4 / 8
