    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 227.0k Views 61 Watching
      blajnov
      Am I missing something? There are 4 items you show on your first post that are blank on my toolbar. The icons for them are not even in the projection folder inside the zip file. I am confused.
      Here, all the buttons, change the folder from the archive of "Projection"
      Projection.zip
        boilingsnow
        I see all the buttons, but agree that the surface is not smoothed
        What you have is not the latest version...so you can get or the buttons loaded.
        The latest version updated on 3. July is missing buttons.
        So waiting for Didier Bur.
          boilingsnow
          No they are still not "all the buttons" compared to the latest update in first page. There are at least three buttons missing.
          It seems Didier Bur has updated the .rb but forgotten to change the folder. You can get all the buttons loaded because your .rb is not the latest one.
          • Didier BurD Offline
            Didier Bur
            Sorry for the missing icons. Zip updated.
            DB
            • boofredlayB Offline
              boofredlay
              Thanks.
              • CadFatherC Offline
                CadFather
                Hi Didier, regarding your smooth problem - have a look at Matt's script here
                http://forums.sketchucation.com/viewtopic.php?f=180&t=11317&hilit=plugin
                  Didier Bur
                  Hi Cadfathher,
                  Thanks a million. I knew that smoothing was possible, but the ruby doc is REALLY bad, it doesn't mention that an edge can be smoothed only when it shares 2 faces.
                  It works now. Patch published.
                  DB
                    CadFather
                    fantastic ๐Ÿ‘
                      CadFather
                      wonder if anyone has the same thing - when i use extrude lines, i cannot draw the vector easily - it stop/starts or disappears.
                      only with difficulty i can align it along an axis..
                      will keep an eye if there's a clash somewhere
                      • Bob JamesB Offline
                        Bob James
                        The Projection folder I have is dated 6 July 2009 and I downloaded the "Projection Patch" but I don't see any difference. What am I missing?
                          CadFather
                          Hi Didier,
                          this is what's happening - the inferencing works well when you have faces behind the cursor.
                          it snaps strangely when in empty space
                          thought i'd cheer you up for the day... ๐Ÿ˜’ ๐Ÿ˜„
                            It's me or when using undo with for exemple the Extrude line along a vector all the lines are killed ๐Ÿ˜ฎ
                            It's some annoying when you have made 10 extrude lines successive all is to remake ๐Ÿ˜‰
                            Does not possible to have a real undo successive?
                              Didier Bur
                              Hi Pilou,
                              Someone asked me (a long time ago I confess) to have a global undo instead of a step by step undo. How to satisfy everybody ?
                              In french: on m'a demandรฉ il y a longtemps de faire un annuler global plutรดt que par รฉtape. c'est l'un ou l'autre, c'est difficile de contenter tout le monde...
                              DB
                                Didier Bur
                                Nothing. The new RBS is an update of the "extrude lines tool" to have smoothed surfaces when extruding curves, arcs, and circles.
                                Regards,
                                DB
                                  Didier Bur
                                  Hem hem,
                                  Inference when there's no face behind cursor snaps to the Red-Green plane as I see ๐Ÿ˜ฎ
                                  Must look into it...
                                  DB
                                    Damned! ๐Ÿ˜ฎ
                                    It's very more subtle to have a partial Undo than a global Undo for this sort of function (just 10 clicks than a painful remake ๐Ÿ˜ฎ
                                    It's even absurd! ๐Ÿ˜ฎ
                                    As the drawing of the vector is not so evident, an error is speedy arrived! ๐Ÿ˜ณ
                                    I am very disappointed ๐Ÿ’š
                                      DIEGO-RODRIGUEZ
                                      a question.
                                      How can extrude line and get the result of this image?
                                      http://forums.sketchucation.com/download/file.php?id=29592&t=1
                                        TIG's extrudeEdgesByRails.rb... NOT yet on general release...
                                          dylan
                                          Look forward to it's release TIG ๐Ÿ‘
                                          http://dmdarchitecture.co.uk/
                                          • H Offline
                                            Heven7_floor
                                            Thanks for your wonderful created things โ˜€
                                            and kindly sharing for helpfully used in SU ๐Ÿ’š
                                            Cheer ๐Ÿ‘ ๐Ÿ‘
                                            • 4 / 8
