    New API doc - typos and questions
    370 Posts 35 Posters 355.4k Views 35 Watching
      Got to disagree there. .os_language and .get_locale should both return the system settings, as that's what they indicate. They have their uses. But maybe there should be extra method to get the SU language...
        Ah, I see now:
        http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#get_locale
        The get_locale method returns the language code for the language SketchUp is running in.
        Valid return values include (but are not limited to): EN, QE, DE, FR, JP, ES, and IT.
        Yes, Sketchup.get_locale should according to the docs NOT return the system locale...
        • T
          tomasz
          Yep, get_locale should not be an alias of os_language as doc suggests and os_language should read os language instead of local SU language. πŸ˜• πŸ˜„
          • T
            tomasz
            Sketchup.os_language
            Sketchup.get_locale
            In Polish version of SU6 PL both methods return 'pl' string.
            Current description is misleading because I've got SU6 PL installed in Vista EN.
            get_locale should refer to SU language instead of OS!
            The os_language method is used to retrieve a two character code representing the os language. This is an alias for the get_locale method.
              So, os_language reads the SU locale? that's the wrong method?
              • T
                tomasz
                I have investigated the case and it turned out that SU reads the OS language settings , not the language version of the OS itself. I had the language settings set to Polish in VistaENG. That was why SU returned os_language as 'pl' and get_locale also as 'pl'. So the documentation in right when the OS language selected in OS settings has its presence in SU.
                When OS language settings, say Portuguese, is not supported by SU then os_language returns 'en-US' which is wrong.
                  Animation
                  http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/animation.html
                  The first example on that page:
                       # This is an example of a simple animation that floats the camera up to
                       # a z position of 200". The only required method for an animation is
                       # nextFrame. It is called whenever you need to show the next frame of
                       # the animation. If nextFrame returns false, the animation will stop.
                       class FloatUpAnimation
                         def nextFrame(view)
                           new_eye = view.camera.eye
                           new_eye.z = new_eye.z + 1.0
                           view.camera.set(new_eye, view.camera.target, view.camera.up)
                           view.show_frame
                           return new_eye.z < 500.0
                       # This adds an item to the Camera menu to activate our custom animation.
                       UI.menu("Camera").add_item("Run Float Up Animation") {
                         Sketchup.active_model.active_view.animation = FloatUpAnimation.new
                  It makes a class named FloatUpAnimation, but no mention of Animation. A bit confusing.
                  Is it like the Observers?
                  Should it say class FloatUpAnimation < Animation
                  • scottliningerS
                    scottlininger
                    It is like observers. It doesn't actually have to be a subclass to work. Any object that replies to the nextFrame callback can be used as an animation.
                    • Scott Lininger
                      SketchUp Software Engineer
                      Have you visited the Ruby API Docs?
                      Isn't observer like that as well? I realised once that I had used the wrong observer class as a base, but the observer still worked.
                      • scottliningerS
                        scottlininger
                        Yes, that's how observers are as well.
                        πŸ˜„
                        • Scott Lininger
                          How much of this thread have you processed Scott?
                          I think I'm loosing track of what I have reported.
                          • scottliningerS
                            scottlininger
                            I have a lot of catch up to do. I have a paper copy here that I've marked as I update. I'll remerge that back into the forum soon.
                            • Scott Lininger
                              designforlife
                              A small thing, just noticed a typo that I don't think is already covered. The entry for EntityObserver.onChangeEntity method states:
                              The onEraseEntity method is invoked when your entity is modified.
                              Mike
                                Scott: I think it's worth to also add some notes on the observers that aren't working. Especially those that seem to cause bugsplats. http://forums.sketchucation.com/viewtopic.php?f=180&t=20676
                                • C
                                  cjthompson
                                  I'm not sure if you've caught this yet, but transformation.xaxis, yaxis, and zaxis return vectors, not points.
                                    The Model collection some times doesn't list all the materials when you call .each on it.
                                    http://forums.sketchucation.com/viewtopic.php?f=11&t=21243
                                      WebDialog.new
                                      See Martin's post: http://forums.sketchucation.com/viewtopic.php?f=180&t=21502
                                        MartinRinehart
                                        The following was agreed, in http://forums.sketchucation.com/viewtopic.php?f=180&t=21502 to correctly document WebDialog.new.
                                        Alternate to the API docs, with help. This is for PC:
                                        title - string - This text will appear in the title bar of your WebDialog
                                        scrollable - boolean - This is a NOP. You get scrollbars, regardless. Workaround: <body scroll=no>.
                                        key - string - If this is nil or an empty string, your dialog's size/location is stored in "HKEY_CURRENT_USER/Software/Google/SketchUp7/WebDialog_". You should definitely include here the name of your Ruby, which will be concatenated:
                                        "HKEY_CURRENT_USER/Software/Google/SketchUp7/WebDialog_MyRuby"
                                        width, height, left, top - integers - size/location, in pixels, of the first appearance of your WebDialog. All subsequent appearances will be taken from the registry entry.
                                        resizeable - boolean - if false, your user cannot resize the dialog. Defaults to true, if omitted.
                                        • T
                                          tomasz
                                          class ShadowInfo
                                          ShadowTime_time_t
                                          SunRise_time_t
                                          SunSet_time_t
                                          TZOffset
                                          UseSunForAllShading
                                          Those keys are not mentioned/explained in the documentation.
                                            MartinRinehart
                                            Topic: WebDialog.new
                                            The second parameter, scrollbars, appears to be operational on the Mac. PCs get scrollbars, regardless.
                                            • 18
                                            • 19
                                            • 8 / 19
