    New API doc - typos and questions
    370 Posts 35 Posters 310.7k Views 35 Watching
      Layer.page_behavior vs Layer.page_behavior=
      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior
      The flag values seems to contradict between descriptions of the two methods.
        Pages.add_frame_change_observer
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/pages.html#add_frame_change_observer
        I don't find any more info on this FrameChange observer. Missing documentation?
        The argument is an object that implements a method frameChange with the following form:
        But then there's no example. And no FrameChange observer is listed in the Observer list.
          Transformation.to_a
          http://code.google.com/apis/sketchup/docs/ourdoc/transformation.html#to_a
          It would be every helpful if this listed the many items in this array and explained which each of them represents
          e.g. tra[14]= Z value
          • Chris FullmerC Offline
            @tig said:
            Transformation.to_a
            I AGREE!! πŸ˜„
              remus
              I dont know if that would be possible, as what each element means varies a lot depending on the transformation (or combination of transformations) that have happened. The exception to this is the final column ([12],[13],[14]) which always represent translation.
                Well, an explaination of the difference would be great. Because transformation is a big scary wolf when you start SU scripting... IMO...
                  remus
                  I wonder if theyd mind linking out to another site, theres lots of stuff out there:
                  301 Moved Permanently
                  (www.ugrad.cs.ubc.ca)
                  301 Moved
                  (www.google.co.uk)
                    Got to disagree there. .os_language and .get_locale should both return the system settings, as that's what they indicate. They have their uses. But maybe there should be extra method to get the SU language...
                      Ah, I see now:
                      http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#get_locale
                      The get_locale method returns the language code for the language SketchUp is running in.
                      Valid return values include (but are not limited to): EN, QE, DE, FR, JP, ES, and IT.
                      Yes, Sketchup.get_locale should according to the docs NOT return the system locale...
                        tomasz
                        Yep, get_locale should not be an alias of os_language as doc suggests and os_language should read os language instead of local SU language. πŸ˜• πŸ˜„
                        Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                          tomasz
                          Sketchup.os_language
                          Sketchup.get_locale
                          In Polish version of SU6 PL both methods return 'pl' string.
                          Current description is misleading because I've got SU6 PL installed in Vista EN.
                          get_locale should refer to SU language instead of OS!
                          The os_language method is used to retrieve a two character code representing the os language. This is an alias for the get_locale method.
                            So, os_language reads the SU locale? that's the wrong method?
                              tomasz
                              I have investigated the case and it turned out that SU reads the OS language settings , not the language version of the OS itself. I had the language settings set to Polish in VistaENG. That was why SU returned os_language as 'pl' and get_locale also as 'pl'. So the documentation in right when the OS language selected in OS settings has its presence in SU.
                              When OS language settings, say Portuguese, is not supported by SU then os_language returns 'en-US' which is wrong.
                                Animation
                                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/animation.html
                                The first example on that page:
                                     # This is an example of a simple animation that floats the camera up to
                                     # a z position of 200". The only required method for an animation is
                                     # nextFrame. It is called whenever you need to show the next frame of
                                     # the animation. If nextFrame returns false, the animation will stop.
                                     class FloatUpAnimation
                                       def nextFrame(view)
                                         new_eye = view.camera.eye
                                         new_eye.z = new_eye.z + 1.0
                                         view.camera.set(new_eye, view.camera.target, view.camera.up)
                                         view.show_frame
                                         return new_eye.z < 500.0
                                     # This adds an item to the Camera menu to activate our custom animation.
                                     UI.menu("Camera").add_item("Run Float Up Animation") {
                                       Sketchup.active_model.active_view.animation = FloatUpAnimation.new
                                It makes a class named FloatUpAnimation, but no mention of Animation. A bit confusing.
                                Is it like the Observers?
                                Should it say class FloatUpAnimation < Animation
                                • scottliningerS Offline
                                  scottlininger
                                  It is like observers. It doesn't actually have to be a subclass to work. Any object that replies to the nextFrame callback can be used as an animation.
                                  • Scott Lininger
                                    SketchUp Software Engineer
                                    Have you visited the Ruby API Docs?
                                    Isn't observer like that as well? I realised once that I had used the wrong observer class as a base, but the observer still worked.
                                      scottlininger
                                      Yes, that's how observers are as well.
                                      πŸ˜„
                                      • Scott Lininger
                                        How much of this thread have you processed Scott?
                                        I think I'm loosing track of what I have reported.
                                          scottlininger
                                          I have a lot of catch up to do. I have a paper copy here that I've marked as I update. I'll remerge that back into the forum soon.
                                          • Scott Lininger
                                            designforlife
                                            A small thing, just noticed a typo that I don't think is already covered. The entry for EntityObserver.onChangeEntity method states:
                                            The onEraseEntity method is invoked when your entity is modified.
                                            Mike
                                            • 18
                                            • 19
                                            • 8 / 19
