    New API doc - typos and questions
    370 Posts 35 Posters 295.6k Views 35 Watching
      remus
      I dont know if that would be possible, as what each element means varies a lot depending on the transformation (or combination of transformations) that have happened. The exception to this is the final column ([12],[13],[14]) which always represent translation.
        Well, an explaination of the difference would be great. Because transformation is a big scary wolf when you start SU scripting... IMO...
          remus
          I wonder if theyd mind linking out to another site, theres lots of stuff out there:
          301 Moved Permanently
          (www.ugrad.cs.ubc.ca)
          301 Moved
          (www.google.co.uk)
            Got to disagree there. .os_language and .get_locale should both return the system settings, as that's what they indicate. They have their uses. But maybe there should be extra method to get the SU language...
              Ah, I see now:
              http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#get_locale
              The get_locale method returns the language code for the language SketchUp is running in.
              Valid return values include (but are not limited to): EN, QE, DE, FR, JP, ES, and IT.
              Yes, Sketchup.get_locale should according to the docs NOT return the system locale...
                tomasz
                Yep, get_locale should not be an alias of os_language as doc suggests and os_language should read os language instead of local SU language. πŸ˜• πŸ˜„
                Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                  tomasz
                  Sketchup.os_language
                  Sketchup.get_locale
                  In Polish version of SU6 PL both methods return 'pl' string.
                  Current description is misleading because I've got SU6 PL installed in Vista EN.
                  get_locale should refer to SU language instead of OS!
                  The os_language method is used to retrieve a two character code representing the os language. This is an alias for the get_locale method.
                    So, os_language reads the SU locale? that's the wrong method?
                      tomasz
                      I have investigated the case and it turned out that SU reads the OS language settings , not the language version of the OS itself. I had the language settings set to Polish in VistaENG. That was why SU returned os_language as 'pl' and get_locale also as 'pl'. So the documentation in right when the OS language selected in OS settings has its presence in SU.
                      When OS language settings, say Portuguese, is not supported by SU then os_language returns 'en-US' which is wrong.
                        Animation
                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/animation.html
                        The first example on that page:
                             # This is an example of a simple animation that floats the camera up to
                             # a z position of 200". The only required method for an animation is
                             # nextFrame. It is called whenever you need to show the next frame of
                             # the animation. If nextFrame returns false, the animation will stop.
                             class FloatUpAnimation
                               def nextFrame(view)
                                 new_eye = view.camera.eye
                                 new_eye.z = new_eye.z + 1.0
                                 view.camera.set(new_eye, view.camera.target, view.camera.up)
                                 view.show_frame
                                 return new_eye.z < 500.0
                             # This adds an item to the Camera menu to activate our custom animation.
                             UI.menu("Camera").add_item("Run Float Up Animation") {
                               Sketchup.active_model.active_view.animation = FloatUpAnimation.new
                        It makes a class named FloatUpAnimation, but no mention of Animation. A bit confusing.
                        Is it like the Observers?
                        Should it say class FloatUpAnimation < Animation
                        • scottliningerS Offline
                          scottlininger
                          It is like observers. It doesn't actually have to be a subclass to work. Any object that replies to the nextFrame callback can be used as an animation.
                          • Scott Lininger
                            SketchUp Software Engineer
                            Have you visited the Ruby API Docs?
                            Isn't observer like that as well? I realised once that I had used the wrong observer class as a base, but the observer still worked.
                              scottlininger
                              Yes, that's how observers are as well.
                              πŸ˜„
                              • Scott Lininger
                                How much of this thread have you processed Scott?
                                I think I'm loosing track of what I have reported.
                                  scottlininger
                                  I have a lot of catch up to do. I have a paper copy here that I've marked as I update. I'll remerge that back into the forum soon.
                                  • Scott Lininger
                                    designforlife
                                    A small thing, just noticed a typo that I don't think is already covered. The entry for EntityObserver.onChangeEntity method states:
                                    The onEraseEntity method is invoked when your entity is modified.
                                    Mike
                                      Scott: I think it's worth to also add some notes on the observers that aren't working. Especially those that seem to cause bugsplats. http://forums.sketchucation.com/viewtopic.php?f=180&t=20676
                                        cjthompson
                                        I'm not sure if you've caught this yet, but transformation.xaxis, yaxis, and zaxis return vectors, not points.
                                          The Model collection some times doesn't list all the materials when you call .each on it.
                                          http://forums.sketchucation.com/viewtopic.php?f=11&t=21243
                                            WebDialog.new
                                            See Martin's post: http://forums.sketchucation.com/viewtopic.php?f=180&t=21502
                                            • 18
                                            • 19
                                            • 8 / 19
