    New API doc - typos and questions
    370 Posts 35 Posters 293.3k Views 35 Watching
      tomasz
      Sketchup.os_language
      Sketchup.get_locale
      In Polish version of SU6 PL both methods return 'pl' string.
      Current description is misleading because I've got SU6 PL installed in Vista EN.
      get_locale should refer to SU language instead of OS!
      The os_language method is used to retrieve a two character code representing the os language. This is an alias for the get_locale method.
        Yep, get_locale should not be an alias of os_language as doc suggests and os_language should read os language instead of local SU language. πŸ˜• πŸ˜„
        So, os_language reads the SU locale? that's the wrong method?
          tomasz
          I have investigated the case and it turned out that SU reads the OS language settings , not the language version of the OS itself. I had the language settings set to Polish in VistaENG. That was why SU returned os_language as 'pl' and get_locale also as 'pl'. So the documentation in right when the OS language selected in OS settings has its presence in SU.
          When OS language settings, say Portuguese, is not supported by SU then os_language returns 'en-US' which is wrong.
            Animation
            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/animation.html
            The first example on that page:
                 # This is an example of a simple animation that floats the camera up to
                 # a z position of 200". The only required method for an animation is
                 # nextFrame. It is called whenever you need to show the next frame of
                 # the animation. If nextFrame returns false, the animation will stop.
                 class FloatUpAnimation
                   def nextFrame(view)
                     new_eye = view.camera.eye
                     new_eye.z = new_eye.z + 1.0
                     view.camera.set(new_eye, view.camera.target, view.camera.up)
                     view.show_frame
                     return new_eye.z < 500.0
                 # This adds an item to the Camera menu to activate our custom animation.
                 UI.menu("Camera").add_item("Run Float Up Animation") {
                   Sketchup.active_model.active_view.animation = FloatUpAnimation.new
            It makes a class named FloatUpAnimation, but no mention of Animation. A bit confusing.
            Is it like the Observers?
            Should it say class FloatUpAnimation < Animation
            • scottliningerS Offline
              scottlininger
              It is like observers. It doesn't actually have to be a subclass to work. Any object that replies to the nextFrame callback can be used as an animation.
              • Scott Lininger
                SketchUp Software Engineer
                Have you visited the Ruby API Docs?
                Isn't observer like that as well? I realised once that I had used the wrong observer class as a base, but the observer still worked.
                  scottlininger
                  Yes, that's how observers are as well.
                  πŸ˜„
                  • Scott Lininger
                    How much of this thread have you processed Scott?
                    I think I'm loosing track of what I have reported.
                      scottlininger
                      I have a lot of catch up to do. I have a paper copy here that I've marked as I update. I'll remerge that back into the forum soon.
                      • Scott Lininger
                        designforlife
                        A small thing, just noticed a typo that I don't think is already covered. The entry for EntityObserver.onChangeEntity method states:
                        The onEraseEntity method is invoked when your entity is modified.
                        Mike
                          Scott: I think it's worth to also add some notes on the observers that aren't working. Especially those that seem to cause bugsplats. http://forums.sketchucation.com/viewtopic.php?f=180&t=20676
                            cjthompson
                            I'm not sure if you've caught this yet, but transformation.xaxis, yaxis, and zaxis return vectors, not points.
                              The Model collection some times doesn't list all the materials when you call .each on it.
                              http://forums.sketchucation.com/viewtopic.php?f=11&t=21243
                                WebDialog.new
                                See Martin's post: http://forums.sketchucation.com/viewtopic.php?f=180&t=21502
                                  MartinRinehart
                                  The following was agreed, in http://forums.sketchucation.com/viewtopic.php?f=180&t=21502 to correctly document WebDialog.new.
                                  Alternate to the API docs, with help. This is for PC:
                                  title - string - This text will appear in the title bar of your WebDialog
                                  scrollable - boolean - This is a NOP. You get scrollbars, regardless. Workaround: <body scroll=no>.
                                  key - string - If this is nil or an empty string, your dialog's size/location is stored in "HKEY_CURRENT_USER/Software/Google/SketchUp7/WebDialog_". You should definitely include here the name of your Ruby, which will be concatenated:
                                  "HKEY_CURRENT_USER/Software/Google/SketchUp7/WebDialog_MyRuby"
                                  width, height, left, top - integers - size/location, in pixels, of the first appearance of your WebDialog. All subsequent appearances will be taken from the registry entry.
                                  resizeable - boolean - if false, your user cannot resize the dialog. Defaults to true, if omitted.
                                    tomasz
                                    class ShadowInfo
                                    ShadowTime_time_t
                                    SunRise_time_t
                                    SunSet_time_t
                                    TZOffset
                                    UseSunForAllShading
                                    Those keys are not mentioned/explained in the documentation.
                                      MartinRinehart
                                      Topic: WebDialog.new
                                      The second parameter, scrollbars, appears to be operational on the Mac. PCs get scrollbars, regardless.
                                        Jim
                                        Just a general request for the API docs. When viewing a method which references another class, would it be possible to link to that class? For example, you are the viewing Model.bounds description - it would be nice to be able to jump right to the BoundingBox class.
                                        Thanks.
                                          Jim
                                          I wonder if we should lock this list and start a new one for 7.1?
                                            Maybe once Scott has updated the docs first?
                                            • 18
                                            • 19
                                            • 8 / 19
