    New API doc - typos and questions
    370 Posts 35 Posters 310.4k Views 35 Watching
      It is like observers. It doesn't actually have to be a subclass to work. Any object that replies to the nextFrame callback can be used as an animation.
      Isn't observer like that as well? I realised once that I had used the wrong observer class as a base, but the observer still worked.
      • scottliningerS Offline
        scottlininger
        Yes, that's how observers are as well.
        πŸ˜„
        • Scott Lininger
          SketchUp Software Engineer
          Have you visited the Ruby API Docs?
          How much of this thread have you processed Scott?
          I think I'm loosing track of what I have reported.
            scottlininger
            I have a lot of catch up to do. I have a paper copy here that I've marked as I update. I'll remerge that back into the forum soon.
            • Scott Lininger
              designforlife
              A small thing, just noticed a typo that I don't think is already covered. The entry for EntityObserver.onChangeEntity method states:
              The onEraseEntity method is invoked when your entity is modified.
              Mike
                Scott: I think it's worth to also add some notes on the observers that aren't working. Especially those that seem to cause bugsplats. http://forums.sketchucation.com/viewtopic.php?f=180&t=20676
                  cjthompson
                  I'm not sure if you've caught this yet, but transformation.xaxis, yaxis, and zaxis return vectors, not points.
                    The Model collection some times doesn't list all the materials when you call .each on it.
                    http://forums.sketchucation.com/viewtopic.php?f=11&t=21243
                      WebDialog.new
                      See Martin's post: http://forums.sketchucation.com/viewtopic.php?f=180&t=21502
                        MartinRinehart
                        The following was agreed, in http://forums.sketchucation.com/viewtopic.php?f=180&t=21502 to correctly document WebDialog.new.
                        Alternate to the API docs, with help. This is for PC:
                        title - string - This text will appear in the title bar of your WebDialog
                        scrollable - boolean - This is a NOP. You get scrollbars, regardless. Workaround: <body scroll=no>.
                        key - string - If this is nil or an empty string, your dialog's size/location is stored in "HKEY_CURRENT_USER/Software/Google/SketchUp7/WebDialog_". You should definitely include here the name of your Ruby, which will be concatenated:
                        "HKEY_CURRENT_USER/Software/Google/SketchUp7/WebDialog_MyRuby"
                        width, height, left, top - integers - size/location, in pixels, of the first appearance of your WebDialog. All subsequent appearances will be taken from the registry entry.
                        resizeable - boolean - if false, your user cannot resize the dialog. Defaults to true, if omitted.
                          tomasz
                          class ShadowInfo
                          ShadowTime_time_t
                          SunRise_time_t
                          SunSet_time_t
                          TZOffset
                          UseSunForAllShading
                          Those keys are not mentioned/explained in the documentation.
                          Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                            MartinRinehart
                            Topic: WebDialog.new
                            The second parameter, scrollbars, appears to be operational on the Mac. PCs get scrollbars, regardless.
                              Jim
                              Just a general request for the API docs. When viewing a method which references another class, would it be possible to link to that class? For example, you are the viewing Model.bounds description - it would be nice to be able to jump right to the BoundingBox class.
                              Thanks.
                                Jim
                                I wonder if we should lock this list and start a new one for 7.1?
                                  Maybe once Scott has updated the docs first?
                                    Entity.typename
                                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entity.html#typename
                                    I think it's worth noting here that .typename comparison is slow and should be avoided if possible. Ref: http://forums.sketchucation.com/viewtopic.php?f=180&t=19576&st=0&sk=t&sd=a#p166340
                                    .typename is required if you need to identify entity types that don't have ruby API classes, such as DimensionLinear, DimensionRadial and Polyline3d. And if you scan for these that you check for entities of class DrawingElement before you do a .typename comaprison.
                                      tomasz
                                      "DisplayColorbyLayer" key of RenderinOptions should read "DisplayColorByLayer"
                                      • N Offline
                                        NewOne
                                        What's wrong with Colorby Layer ? 🀣
                                          tomasz
                                          Try read the value of it. Such a key does not exist.
                                            Did I miss a joke..? πŸ˜•
                                            • 11
                                            • 18
                                            • 19
                                            • 9 / 19
