    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 242.5k Views 61 Watching
    • mitcorbM
      mitcorb
      I am also not seeing buttons 1, 5, 8, 9. If I mouse over these buttons their descriptions show up. I have not fully tested the functions yet. At first I thought the update would overwrite the previous. And then I reviewed the first post where you say to delete the previous, so I did that. However, the four mentioned buttons do not get their png's, which I believe are in the auxiliary folder.
      • Bob JamesB
        Bob James
        I see all the buttons, but agree that the surface is not smoothed
        • B
          blajnov
          Am I missing something? There are 4 items you show on your first post that are blank on my toolbar. The icons for them are not even in the projection folder inside the zip file. I am confused.
          Here, all the buttons, change the folder from the archive of "Projection"
          Projection.zip
          • B
            boilingsnow
            What you have is not the latest version...so you can get or the buttons loaded.
            The latest version updated on 3. July is missing buttons.
            So waiting for Didier Bur.
            • B
              boilingsnow
              No they are still not "all the buttons" compared to the latest update in first page. There are at least three buttons missing.
              It seems Didier Bur has updated the .rb but forgotten to change the folder. You can get all the buttons loaded because your .rb is not the latest one.
              • Didier BurD
                Didier Bur
                Sorry for the missing icons. Zip updated.
                DB
                • boofredlayB
                  boofredlay
                  Thanks.
                  • CadFatherC
                    CadFather
                    Hi Didier, regarding your smooth problem - have a look at Matt's script here
                    404 Not Found
                    (forums.sketchucation.com)
                    • Didier BurD
                      Didier Bur
                      Hi Cadfathher,
                      Thanks a million. I knew that smoothing was possible, but the ruby doc is REALLY bad, it doesn't mention that an edge can be smoothed only when it shares 2 faces.
                      It works now. Patch published.
                      DB
                      • CadFatherC
                        CadFather
                        fantastic 👍
                        • CadFatherC
                          CadFather
                          wonder if anyone has the same thing - when i use extrude lines, i cannot draw the vector easily - it stop/starts or disappears.
                          only with difficulty i can align it along an axis..
                          will keep an eye if there's a clash somewhere
                          • Bob JamesB
                            Bob James
                            The Projection folder I have is dated 6 July 2009 and I downloaded the "Projection Patch" but I don't see any difference. What am I missing?
                            • CadFatherC
                              CadFather
                              Hi Didier,
                              this is what's happening - the inferencing works well when you have faces behind the cursor.
                              it snaps strangely when in empty space
                              thought i'd cheer you up for the day... 😒 😄
                                It's me or when using undo with for exemple the Extrude line along a vector all the lines are killed 😮
                                It's some annoying when you have made 10 extrude lines successive all is to remake 😉
                                Does not possible to have a real undo successive?
                                • Didier BurD
                                  Didier Bur
                                  Hi Pilou,
                                  Someone asked me (a long time ago I confess) to have a global undo instead of a step by step undo. How to satisfy everybody ?
                                  In french: on m'a demandé il y a longtemps de faire un annuler global plutôt que par étape. c'est l'un ou l'autre, c'est difficile de contenter tout le monde...
                                  DB
                                  • Didier BurD
                                    Didier Bur
                                    Nothing. The new RBS is an update of the "extrude lines tool" to have smoothed surfaces when extruding curves, arcs, and circles.
                                    Regards,
                                    DB
                                    • Didier BurD
                                      Didier Bur
                                      Hem hem,
                                      Inference when there's no face behind cursor snaps to the Red-Green plane as I see 😮
                                      Must look into it...
                                      DB
                                        Damned! 😮
                                        It's very more subtle to have a partial Undo than a global Undo for this sort of function (just 10 clicks than a painful remake 😮
                                        It's even absurd! 😮
                                        As the drawing of the vector is not so evident, an error is speedy arrived! 😳
                                        I am very disappointed 💚
                                          DIEGO-RODRIGUEZ
                                          a question.
                                          How can extrude line and get the result of this image?
                                          http://forums.sketchucation.com/download/file.php?id=29592&t=1
                                            TIG's extrudeEdgesByRails.rb... NOT yet on general release...
                                            • 4 / 8
