    [Plugin] Multi face offset
    49 Posts 15 Posters 70.1k Views 15 Watching
      It's the simple things that are often the most complicated !
      [¡Se trata de las cosas simples que a menudo son las más complicadas!]
        And seems Protrude by Jim Foltz makes the same and more! 💚
          remus
          A veritable Smörgåsbord of repeated functionality 😛
            @Remus
            Thx for this new curious name 😆
            http://www.cliffordawright.com/caw/assets/Mezze table al-waha rest.jpg
            • PixeroP Offline
              Pixero
              Smörgåsbord is a swedish word. 👍
                DIEGO-RODRIGUEZ
                Be possible. After applying offset. be selected the new drawing?
                then able to apply, for example, multiple Push Pull
                http://img72.imageshack.us/img72/6033/sinttulo1p.jpg
                sorry for my English. Thank you
                  DIEGO-RODRIGUEZ
                  "Pilou" You're right, thank you very much
                    Protrude above can make that , just offset= 0 after use it and enable Height = that you want 😉
                    Only Protrude keep the selection 😉 Protrude is a very funny plug! 😎
                    For Push Pull multiple in general you can also use Joint Push Pull by Fredo6 or Projection2 by Didier Bur 😉
                    But both lost the selection! 😮
                    • CadFatherC Offline
                      CadFather
                      Hi Remus, first thanks for the useful script - i found out the offset may end reversed at times
                        remus
                        So it does. I dont suppose youve found what causes it? Whatever it is, i suspect it is a bug in offset.rb, it would be good to be able to pass it on to rickw, though.
                          CadFather
                          the hunch, says it may be something to do with the direction of the lines (start-end-front-back business..) - but i could not spot the pattern for sure yet
                            CadFather
                            Remus, couple of icons if needed..
                              remus
                              I dont know how to do toolbars 😳
                              I'll give it a go, though, those icons are too nice to waste 👍
                                CadFather
                                i think it's something along these lines.. check out Chris's loft or other tools - they will make sense
                                	if !file_loaded?(__FILE__) then
                                		toolbar = UI;;Toolbar.new "RTK"
                                		cmd = UI;;Command.new("Offset Multiple Faces (Remus Knowles)"){RTK.multi_face_offset}
                                		cmd.small_icon = "RTK/moffset_16.png"
                                		cmd.large_icon = "RTK/moffset_24.png"
                                		cmd.tooltip = "Offset Multiple Faces"
                                		toolbar = toolbar.add_item cmd
                                • pep75P Offline
                                  pep75
                                  Hey All!
                                  Does anyone has this fantastic plugin working in version 8?! I installed offset.rb and the latest Multifaceoffset.rb but only the input dialogue appears and it doesn't do anything...
                                  Thank you!
                                  Grtzz
                                  Pep
                                  ....or does anyone know how to offset multi faces in another way?!
                                    @pep75 said:
                                    Hey All!
                                    Thank you!
                                    Grtzz
                                    Pep
                                    It works fine in v8 for me [and others].
                                    Have you tried running it with the Ruby Console open to see error messages.
                                    It seems to be failing after the dialog, so probbaly an 'offest' error/deficiency...
                                    You need both the Multifaceoffset.rb and the offset.rb in the main Plugins folder...
                                    • pep75P Offline
                                      pep75
                                      Hey TIG, Thanks!
                                      I already placed the both *.rb files in the main plugins folder, just as usual...And I got the following error message in the Ruby Console but that is Chinese to me! 😲
                                      I don't know what's wrong?
                                        What are the sizes of your box's faces and what size offset are you entering in the dialog - it might be that the face won't offset if there will be no result... How do you enter the offset exactly ? Can you take a screen-shot of the dialog just before you press OK...
                                        This is a very simple few line script by Remus, it has very few things that could go wrong... 😕
                                        • pep75P Offline
                                          pep75
                                          Hey Tig,
                                          The size of the box is given in the capture en the amount of offset is 150mm...It has always done the trick...Can you mail me the offset.rb and the multifaceoffset.rb you are using?
                                          Thanks for your time!
                                          Grtz
                                          Pep
                                            pep75
                                            I have PM'd the two files...
                                            • 2 / 3
