    [Plugin] Multi face offset
    49 Posts 15 Posters 71.6k Views 15 Watching
      DIEGO-RODRIGUEZ
      Be possible. After applying offset. be selected the new drawing?
      then able to apply, for example, multiple Push Pull
      http://img72.imageshack.us/img72/6033/sinttulo1p.jpg
      sorry for my English. Thank you
        DIEGO-RODRIGUEZ
        "Pilou" You're right, thank you very much
          Protrude above can make that , just offset= 0 after use it and enable Height = that you want ๐Ÿ˜‰
          Only Protrude keep the selection ๐Ÿ˜‰ Protrude is a very funny plug! ๐Ÿ˜Ž
          For Push Pull multiple in general you can also use Joint Push Pull by Fredo6 or Projection2 by Didier Bur ๐Ÿ˜‰
          But both lost the selection! ๐Ÿ˜ฎ
          • CadFatherC
            CadFather
            Hi Remus, first thanks for the useful script - i found out the offset may end reversed at times
              remus
              So it does. I dont suppose youve found what causes it? Whatever it is, i suspect it is a bug in offset.rb, it would be good to be able to pass it on to rickw, though.
              • CadFatherC
                CadFather
                the hunch, says it may be something to do with the direction of the lines (start-end-front-back business..) - but i could not spot the pattern for sure yet
                • CadFatherC
                  CadFather
                  Remus, couple of icons if needed..
                    remus
                    I dont know how to do toolbars ๐Ÿ˜ณ
                    I'll give it a go, though, those icons are too nice to waste ๐Ÿ‘
                    • CadFatherC
                      CadFather
                      i think it's something along these lines.. check out Chris's loft or other tools - they will make sense
                      	if !file_loaded?(__FILE__) then
                      		toolbar = UI;;Toolbar.new "RTK"
                      		cmd = UI;;Command.new("Offset Multiple Faces (Remus Knowles)"){RTK.multi_face_offset}
                      		cmd.small_icon = "RTK/moffset_16.png"
                      		cmd.large_icon = "RTK/moffset_24.png"
                      		cmd.tooltip = "Offset Multiple Faces"
                      		toolbar = toolbar.add_item cmd
                      • pep75P
                        pep75
                        Hey All!
                        Does anyone has this fantastic plugin working in version 8?! I installed offset.rb and the latest Multifaceoffset.rb but only the input dialogue appears and it doesn't do anything...
                        Thank you!
                        Grtzz
                        Pep
                        ....or does anyone know how to offset multi faces in another way?!
                          @pep75 said:
                          Hey All!
                          Thank you!
                          Grtzz
                          Pep
                          It works fine in v8 for me [and others].
                          Have you tried running it with the Ruby Console open to see error messages.
                          It seems to be failing after the dialog, so probbaly an 'offest' error/deficiency...
                          You need both the Multifaceoffset.rb and the offset.rb in the main Plugins folder...
                          • pep75P
                            pep75
                            Hey TIG, Thanks!
                            I already placed the both *.rb files in the main plugins folder, just as usual...And I got the following error message in the Ruby Console but that is Chinese to me! ๐Ÿ˜ฒ
                            I don't know what's wrong?
                              What are the sizes of your box's faces and what size offset are you entering in the dialog - it might be that the face won't offset if there will be no result... How do you enter the offset exactly ? Can you take a screen-shot of the dialog just before you press OK...
                              This is a very simple few line script by Remus, it has very few things that could go wrong... ๐Ÿ˜•
                              • pep75P
                                pep75
                                Hey Tig,
                                The size of the box is given in the capture en the amount of offset is 150mm...It has always done the trick...Can you mail me the offset.rb and the multifaceoffset.rb you are using?
                                Thanks for your time!
                                Grtz
                                Pep
                                  pep75
                                  I have PM'd the two files...
                                  • pep75P
                                    pep75
                                    IT'S WORKING! Thank you!!! But the offset.rb and the multioffset.rb that can be downloaded from this topic are different than the ones you've send....strange huh?
                                    Nevertheless thank you!!
                                    Grtz and a happy new year!
                                    Pep
                                      I have tweaked the code slightly over time BUT they should still be the same basic functions ? ๐Ÿ˜‰
                                      • G
                                        gariglianot
                                        Hi guys, I know I'm poking into a discussion that is already 4 years old, but, il seems I have the same problem that pep 75 had... i have both multifaceoffset.rb and offset.rb, but gives me the same error message, and doesnt offset... could TIG perhaps post the scripts that he sent to pep75 that where working? I need it!!!!! thanxxx
                                          Here they are...OffestTools.zip
                                            Avex
                                            Hi all
                                            I have a question, how can I get a rounded offset?
                                            For doing something like that --->
                                            • 2 / 3
