    New API doc - typos and questions
    370 Posts 35 Posters 269.7k Views 35 Watching
      Entity.entityID
      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entity.html#entityID
      The entityID method is used to retrieve a unique ID assigned to an entity.
      The entityID is not persistent between sessions.
      Is it persistent within a session? Can it be relied on for the length of one session?
        ComponentDefinition.guid
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/componentdefinition.html#guid
        Is this value persistent between sessions?
          Jim
          Sketchup::Color.new
          new can accept a hex value (not string) as the parameter: for example 0xFF0000 (undocumented)
          But, it reverses the red and blue values. Here is a Console session. (bug)
          Sketchup;;Color.new 0xFF0000
          Color(  0,   0, 255, 255)
          Sketchup;;Color.new 0x0000FF
          Color(255,   0,   0, 255)
          • scottliningerS Offline
            scottlininger
            I've got some catching up to do. Thanks for all of the details, guys! πŸ˜‰
            • Scott Lininger
              SketchUp Software Engineer
              Have you visited the Ruby API Docs?
              ModelObserver.onDeleteModel vs ModelObserver.onEraseAll
              http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onDeleteModel
              When does the onDeleteModel event trigger? I don't think I've ever seen it trigger. When I open an existing model or create a new model onEraseAll is triggered.
                Jim
                UI.start_timer
                This post on the API blog is showing start_timer with a fraction of a second resolution. In my experience, UI.start_timer has a whole second resolution and rounds partial seconds down to the nearest second.
                    t1=Time.now; UI.start_timer(0.1) {p Time.now-t1} ==> 0.01
                    t1=Time.now; UI.start_timer(0.999) {p Time.now-t1} ==> 0.01
                    t1=Time.now; UI.start_timer(1) {p Time.now-t1} ==> 1.001
                    t1=Time.now; UI.start_timer(1.9) {p Time.now-t1} ==> 1.002
                  Jim
                  Point3d.linear_combination
                  Uses example from Geom.linear_combination.
                  I would guess the Point3d.linear_combination would only take 2 arguments - the weight, and other point since the first point is the receiver of the method.
                    MaterialsObserver
                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/materialsobserver.html
                    Observer events that doesn't trigger:
                    Sketchup 6
                    onMaterialChange*
                    onMaterialRefChange
                    Sketchup 7
                    onMaterialChange*
                    onMaterialRefChange
                    onMaterialSetCurrent
                    • Only triggers when the name changes. Not when any of the other properties changes.
                      Jim
                      Group.move!
                      This method is the same as the transform! method except that it does not record the move in an undo operation. This method is useful for transparently moving things during an animation.
                      .move! resets the rotational and scaling components of the receiver's transformation, and does not result in the same final translation as using .transform!
                        Layer.page_behavior vs Layer.page_behavior=
                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior
                        The flag values seems to contradict between descriptions of the two methods.
                          Pages.add_frame_change_observer
                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/pages.html#add_frame_change_observer
                          I don't find any more info on this FrameChange observer. Missing documentation?
                          The argument is an object that implements a method frameChange with the following form:
                          But then there's no example. And no FrameChange observer is listed in the Observer list.
                            Transformation.to_a
                            http://code.google.com/apis/sketchup/docs/ourdoc/transformation.html#to_a
                            It would be every helpful if this listed the many items in this array and explained which each of them represents
                            e.g. tra[14]= Z value
                            • Chris FullmerC Offline
                              @tig said:
                              Transformation.to_a
                              I AGREE!! πŸ˜„
                                remus
                                I dont know if that would be possible, as what each element means varies a lot depending on the transformation (or combination of transformations) that have happened. The exception to this is the final column ([12],[13],[14]) which always represent translation.
                                  Well, an explaination of the difference would be great. Because transformation is a big scary wolf when you start SU scripting... IMO...
                                    remus
                                    I wonder if theyd mind linking out to another site, theres lots of stuff out there:
                                    301 Moved Permanently
                                    (www.ugrad.cs.ubc.ca)
                                    301 Moved
                                    (www.google.co.uk)
                                      Got to disagree there. .os_language and .get_locale should both return the system settings, as that's what they indicate. They have their uses. But maybe there should be extra method to get the SU language...
                                        Ah, I see now:
                                        http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#get_locale
                                        The get_locale method returns the language code for the language SketchUp is running in.
                                        Valid return values include (but are not limited to): EN, QE, DE, FR, JP, ES, and IT.
                                        Yes, Sketchup.get_locale should according to the docs NOT return the system locale...
                                          tomasz
                                          Yep, get_locale should not be an alias of os_language as doc suggests and os_language should read os language instead of local SU language. πŸ˜• πŸ˜„
                                            tomasz
                                            Sketchup.os_language
                                            Sketchup.get_locale
                                            In Polish version of SU6 PL both methods return 'pl' string.
                                            Current description is misleading because I've got SU6 PL installed in Vista EN.
                                            get_locale should refer to SU language instead of OS!
                                            The os_language method is used to retrieve a two character code representing the os language. This is an alias for the get_locale method.
                                            • 18
                                            • 19
                                            • 4 / 19
