    New API doc - typos and questions
    370 Posts 35 Posters 355.3k Views 35 Watching
      WebDialog.get_element_value
      http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#get_element_value
      The example hasn't escaped the HTML tags - so the HTML sample text is instead interpreted by the browser..
        Curve.move_vertices
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/curve.html#move_vertices
        Description says:
        The vertices method retrieves a collection of all vertices in a curve.
          Tool.enableVCB?
          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/tool.html#enableVCB?
          The enableVCB? method is used to tell SketchUp whether to allow the user to enter text into the VCB (value control box, aka the "measurements" panel). If you do not implement this method, then the vcb is disabled by default.
          I've never used this method for my Tools. But the VCB has still worked.
            Image.size=
            http://code.google.com/apis/sketchup/docs/ourdoc/image.html#size=
            It appears that the second argument is optional.
              Entity.entityID
              http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entity.html#entityID
              The entityID method is used to retrieve a unique ID assigned to an entity.
              The entityID is not persistent between sessions.
              Is it persistent within a session? Can it be relied on for the length of one session?
                ComponentDefinition.guid
                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/componentdefinition.html#guid
                Is this value persistent between sessions?
                  Jim
                  Sketchup::Color.new
                  new can accept a hex value (not string) as the parameter: for example 0xFF0000 (undocumented)
                  But, it reverses the red and blue values. Here is a Console session. (bug)
                  Sketchup;;Color.new 0xFF0000
                  Color(  0,   0, 255, 255)
                  Sketchup;;Color.new 0x0000FF
                  Color(255,   0,   0, 255)
                  • scottliningerS
                    scottlininger
                    I've got some catching up to do. Thanks for all of the details, guys! 😉
                    • Scott Lininger
                      SketchUp Software Engineer
                      Have you visited the Ruby API Docs?
                      ModelObserver.onDeleteModel vs ModelObserver.onEraseAll
                      http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onDeleteModel
                      When does the onDeleteModel event trigger? I don't think I've ever seen it trigger. When I open an existing model or create a new model onEraseAll is triggered.
                        Jim
                        UI.start_timer
                        This post on the API blog is showing start_timer with a fraction of a second resolution. In my experience, UI.start_timer has a whole second resolution and rounds partial seconds down to the nearest second.
                            t1=Time.now; UI.start_timer(0.1) {p Time.now-t1} ==> 0.01
                            t1=Time.now; UI.start_timer(0.999) {p Time.now-t1} ==> 0.01
                            t1=Time.now; UI.start_timer(1) {p Time.now-t1} ==> 1.001
                            t1=Time.now; UI.start_timer(1.9) {p Time.now-t1} ==> 1.002
                          Jim
                          Point3d.linear_combination
                          Uses example from Geom.linear_combination.
                          I would guess the Point3d.linear_combination would only take 2 arguments - the weight, and other point since the first point is the receiver of the method.
                            MaterialsObserver
                            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/materialsobserver.html
                            Observer events that doesn't trigger:
                            Sketchup 6
                            onMaterialChange*
                            onMaterialRefChange
                            Sketchup 7
                            onMaterialChange*
                            onMaterialRefChange
                            onMaterialSetCurrent
                            • Only triggers when the name changes. Not when any of the other properties changes.
                              Jim
                              Group.move!
                              This method is the same as the transform! method except that it does not record the move in an undo operation. This method is useful for transparently moving things during an animation.
                              .move! resets the rotational and scaling components of the receiver's transformation, and does not result in the same final translation as using .transform!
                                Layer.page_behavior vs Layer.page_behavior=
                                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior
                                The flag values seems to contradict between descriptions of the two methods.
                                  Pages.add_frame_change_observer
                                  http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/pages.html#add_frame_change_observer
                                  I don't find any more info on this FrameChange observer. Missing documentation?
                                  The argument is an object that implements a method frameChange with the following form:
                                  But then there's no example. And no FrameChange observer is listed in the Observer list.
                                    Transformation.to_a
                                    http://code.google.com/apis/sketchup/docs/ourdoc/transformation.html#to_a
                                    It would be every helpful if this listed the many items in this array and explained which each of them represents
                                    e.g. tra[14]= Z value
                                    • Chris FullmerC
                                      @tig said:
                                      Transformation.to_a
                                      I AGREE!! 😄
                                        remus
                                        I dont know if that would be possible, as what each element means varies a lot depending on the transformation (or combination of transformations) that have happened. The exception to this is the final column ([12],[13],[14]) which always represent translation.
                                          Well, an explaination of the difference would be great. Because transformation is a big scary wolf when you start SU scripting... IMO...
                                            remus
                                            I wonder if theyd mind linking out to another site, theres lots of stuff out there:
                                            http://www.ugrad.cs.ubc.ca/~cs414/notes/applets/trans/trans.html
                                            http://www.google.co.uk/search?rlz=1C1CHMG_enGB291GB303&sourceid=chrome&ie=UTF-8&q=4x4+transformation+matrix
                                            • 18
                                            • 19
                                            • 7 / 19
