    New API doc - typos and questions
    370 Posts 35 Posters 355.3k Views 35 Watching
      Jim
      Sketchup::Color.new
      new can accept a hex value (not string) as the parameter: for example 0xFF0000 (undocumented)
      But, it reverses the red and blue values. Here is a Console session. (bug)
      Sketchup;;Color.new 0xFF0000
      Color(  0,   0, 255, 255)
      Sketchup;;Color.new 0x0000FF
      Color(255,   0,   0, 255)
      • scottliningerS
        scottlininger
        I've got some catching up to do. Thanks for all of the details, guys! πŸ˜‰
        • Scott Lininger
          SketchUp Software Engineer
          Have you visited the Ruby API Docs?
          ModelObserver.onDeleteModel vs ModelObserver.onEraseAll
          http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onDeleteModel
          When does the onDeleteModel event trigger? I don't think I've ever seen it trigger. When I open an existing model or create a new model onEraseAll is triggered.
            Jim
            UI.start_timer
            This post on the API blog is showing start_timer with a fraction of a second resolution. In my experience, UI.start_timer has a whole second resolution and rounds partial seconds down to the nearest second.
                t1=Time.now; UI.start_timer(0.1) {p Time.now-t1} ==> 0.01
                t1=Time.now; UI.start_timer(0.999) {p Time.now-t1} ==> 0.01
                t1=Time.now; UI.start_timer(1) {p Time.now-t1} ==> 1.001
                t1=Time.now; UI.start_timer(1.9) {p Time.now-t1} ==> 1.002
              Jim
              Point3d.linear_combination
              Uses example from Geom.linear_combination.
              I would guess the Point3d.linear_combination would only take 2 arguments - the weight, and other point since the first point is the receiver of the method.
                MaterialsObserver
                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/materialsobserver.html
                Observer events that doesn't trigger:
                Sketchup 6
                onMaterialChange*
                onMaterialRefChange
                Sketchup 7
                onMaterialChange*
                onMaterialRefChange
                onMaterialSetCurrent
                • Only triggers when the name changes. Not when any of the other properties changes.
                  Jim
                  Group.move!
                  This method is the same as the transform! method except that it does not record the move in an undo operation. This method is useful for transparently moving things during an animation.
                  .move! resets the rotational and scaling components of the receiver's transformation, and does not result in the same final translation as using .transform!
                    Layer.page_behavior vs Layer.page_behavior=
                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior
                    The flag values seems to contradict between descriptions of the two methods.
                      Pages.add_frame_change_observer
                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/pages.html#add_frame_change_observer
                      I don't find any more info on this FrameChange observer. Missing documentation?
                      The argument is an object that implements a method frameChange with the following form:
                      But then there's no example. And no FrameChange observer is listed in the Observer list.
                        Transformation.to_a
                        http://code.google.com/apis/sketchup/docs/ourdoc/transformation.html#to_a
                        It would be every helpful if this listed the many items in this array and explained which each of them represents
                        e.g. tra[14]= Z value
                        • Chris FullmerC
                          @tig said:
                          Transformation.to_a
                          I AGREE!! πŸ˜„
                            remus
                            I dont know if that would be possible, as what each element means varies a lot depending on the transformation (or combination of transformations) that have happened. The exception to this is the final column ([12],[13],[14]) which always represent translation.
                              Well, an explaination of the difference would be great. Because transformation is a big scary wolf when you start SU scripting... IMO...
                                remus
                                I wonder if theyd mind linking out to another site, theres lots of stuff out there:
                                http://www.ugrad.cs.ubc.ca/~cs414/notes/applets/trans/trans.html
                                http://www.google.co.uk/search?rlz=1C1CHMG_enGB291GB303&sourceid=chrome&ie=UTF-8&q=4x4+transformation+matrix
                                  Got to disagree there. .os_language and .get_locale should both return the system settings, as that's what they indicate. They have their uses. But maybe there should be extra method to get the SU language...
                                    Ah, I see now:
                                    http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#get_locale
                                    The get_locale method returns the language code for the language SketchUp is running in.
                                    Valid return values include (but are not limited to): EN, QE, DE, FR, JP, ES, and IT.
                                    Yes, Sketchup.get_locale should according to the docs NOT return the system locale...
                                    • T
                                      tomasz
                                      Yep, get_locale should not be an alias of os_language as doc suggests and os_language should read os language instead of local SU language. πŸ˜• πŸ˜„
                                      • T
                                        tomasz
                                        Sketchup.os_language
                                        Sketchup.get_locale
                                        In Polish version of SU6 PL both methods return 'pl' string.
                                        Current description is misleading because I've got SU6 PL installed in Vista EN.
                                        get_locale should refer to SU language instead of OS!
                                        The os_language method is used to retrieve a two character code representing the os language. This is an alias for the get_locale method.
                                          So, os_language reads the SU locale? that's the wrong method?
                                          • T
                                            tomasz
                                            I have investigated the case and it turned out that SU reads the OS language settings , not the language version of the OS itself. I had the language settings set to Polish in VistaENG. That was why SU returned os_language as 'pl' and get_locale also as 'pl'. So the documentation in right when the OS language selected in OS settings has its presence in SU.
                                            When OS language settings, say Portuguese, is not supported by SU then os_language returns 'en-US' which is wrong.
                                            • 18
                                            • 19
                                            • 7 / 19
