    New API doc - typos and questions
    370 Posts 35 Posters 293.3k Views 35 Watching
      Image.size=
      http://code.google.com/apis/sketchup/docs/ourdoc/image.html#size=
      It appears that the second argument is optional.
        Entity.entityID
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entity.html#entityID
        The entityID method is used to retrieve a unique ID assigned to an entity.
        The entityID is not persistent between sessions.
        Is it persistent within a session? Can it be relied on for the length of one session?
          ComponentDefinition.guid
          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/componentdefinition.html#guid
          Is this value persistent between sessions?
            Jim
            Sketchup::Color.new
            new can accept a hex value (not string) as the parameter: for example 0xFF0000 (undocumented)
            But, it reverses the red and blue values. Here is a Console session. (bug)
            Sketchup;;Color.new 0xFF0000
            Color(  0,   0, 255, 255)
            Sketchup;;Color.new 0x0000FF
            Color(255,   0,   0, 255)
            • scottliningerS Offline
              scottlininger
              I've got some catching up to do. Thanks for all of the details, guys! πŸ˜‰
              • Scott Lininger
                SketchUp Software Engineer
                Have you visited the Ruby API Docs?
                ModelObserver.onDeleteModel vs ModelObserver.onEraseAll
                http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onDeleteModel
                When does the onDeleteModel event trigger? I don't think I've ever seen it trigger. When I open an existing model or create a new model onEraseAll is triggered.
                  Jim
                  UI.start_timer
                  This post on the API blog is showing start_timer with a fraction of a second resolution. In my experience, UI.start_timer has a whole second resolution and rounds partial seconds down to the nearest second.
                      t1=Time.now; UI.start_timer(0.1) {p Time.now-t1} ==> 0.01
                      t1=Time.now; UI.start_timer(0.999) {p Time.now-t1} ==> 0.01
                      t1=Time.now; UI.start_timer(1) {p Time.now-t1} ==> 1.001
                      t1=Time.now; UI.start_timer(1.9) {p Time.now-t1} ==> 1.002
                    Jim
                    Point3d.linear_combination
                    Uses example from Geom.linear_combination.
                    I would guess the Point3d.linear_combination would only take 2 arguments - the weight, and other point since the first point is the receiver of the method.
                      MaterialsObserver
                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/materialsobserver.html
                      Observer events that doesn't trigger:
                      Sketchup 6
                      onMaterialChange*
                      onMaterialRefChange
                      Sketchup 7
                      onMaterialChange*
                      onMaterialRefChange
                      onMaterialSetCurrent
                      • Only triggers when the name changes. Not when any of the other properties changes.
                        Jim
                        Group.move!
                        This method is the same as the transform! method except that it does not record the move in an undo operation. This method is useful for transparently moving things during an animation.
                        .move! resets the rotational and scaling components of the receiver's transformation, and does not result in the same final translation as using .transform!
                          Layer.page_behavior vs Layer.page_behavior=
                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior
                          The flag values seems to contradict between descriptions of the two methods.
                            Pages.add_frame_change_observer
                            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/pages.html#add_frame_change_observer
                            I don't find any more info on this FrameChange observer. Missing documentation?
                            The argument is an object that implements a method frameChange with the following form:
                            But then there's no example. And no FrameChange observer is listed in the Observer list.
                              Transformation.to_a
                              http://code.google.com/apis/sketchup/docs/ourdoc/transformation.html#to_a
                              It would be every helpful if this listed the many items in this array and explained which each of them represents
                              e.g. tra[14]= Z value
                              • Chris FullmerC Offline
                                @tig said:
                                Transformation.to_a
                                I AGREE!! πŸ˜„
                                  remus
                                  I dont know if that would be possible, as what each element means varies a lot depending on the transformation (or combination of transformations) that have happened. The exception to this is the final column ([12],[13],[14]) which always represent translation.
                                    Well, an explaination of the difference would be great. Because transformation is a big scary wolf when you start SU scripting... IMO...
                                      remus
                                      I wonder if theyd mind linking out to another site, theres lots of stuff out there:
                                      301 Moved Permanently
                                      (www.ugrad.cs.ubc.ca)
                                      301 Moved
                                      (www.google.co.uk)
                                        Got to disagree there. .os_language and .get_locale should both return the system settings, as that's what they indicate. They have their uses. But maybe there should be extra method to get the SU language...
                                          Ah, I see now:
                                          http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#get_locale
                                          The get_locale method returns the language code for the language SketchUp is running in.
                                          Valid return values include (but are not limited to): EN, QE, DE, FR, JP, ES, and IT.
                                          Yes, Sketchup.get_locale should according to the docs NOT return the system locale...
                                            tomasz
                                            Yep, get_locale should not be an alias of os_language as doc suggests and os_language should read os language instead of local SU language. πŸ˜• πŸ˜„
                                            • 18
                                            • 19
                                            • 7 / 19
