    [Plugin] Multi face offset
    49 Posts 15 Posters 71.6k Views 15 Watching
    • CadFatherC
      CadFather
      i think it's something along these lines.. check out Chris's loft or other tools - they will make sense
      	if !file_loaded?(__FILE__) then
      		toolbar = UI;;Toolbar.new "RTK"
      		cmd = UI;;Command.new("Offset Multiple Faces (Remus Knowles)"){RTK.multi_face_offset}
      		cmd.small_icon = "RTK/moffset_16.png"
      		cmd.large_icon = "RTK/moffset_24.png"
      		cmd.tooltip = "Offset Multiple Faces"
      		toolbar = toolbar.add_item cmd
      • pep75P
        pep75
        Hey All!
        Does anyone has this fantastic plugin working in version 8?! I installed offset.rb and the latest Multifaceoffset.rb but only the input dialogue appears and it doesn't do anything...
        Thank you!
        Grtzz
        Pep
        ....or does anyone know how to offset multi faces in another way?!
          @pep75 said:
          Hey All!
          Thank you!
          Grtzz
          Pep
          It works fine in v8 for me [and others].
          Have you tried running it with the Ruby Console open to see error messages.
          It seems to be failing after the dialog, so probbaly an 'offest' error/deficiency...
          You need both the Multifaceoffset.rb and the offset.rb in the main Plugins folder...
          • pep75P
            pep75
            Hey TIG, Thanks!
            I already placed the both *.rb files in the main plugins folder, just as usual...And I got the following error message in the Ruby Console but that is Chinese to me! 😲
            I don't know what's wrong?
              What are the sizes of your box's faces and what size offset are you entering in the dialog - it might be that the face won't offset if there will be no result... How do you enter the offset exactly ? Can you take a screen-shot of the dialog just before you press OK...
              This is a very simple few line script by Remus, it has very few things that could go wrong... πŸ˜•
              • pep75P
                pep75
                Hey Tig,
                The size of the box is given in the capture en the amount of offset is 150mm...It has always done the trick...Can you mail me the offset.rb and the multifaceoffset.rb you are using?
                Thanks for your time!
                Grtz
                Pep
                  pep75
                  I have PM'd the two files...
                  • pep75P
                    pep75
                    IT'S WORKING! Thank you!!! But the offset.rb and the multioffset.rb that can be downloaded from this topic are different than the ones you've send....strange huh?
                    Nevertheless thank you!!
                    Grtz and a happy new year!
                    Pep
                      I have tweaked the code slightly over time BUT they should still be the same basic functions ? πŸ˜‰
                      • G
                        gariglianot
                        Hi guys, I know I'm poking into a discussion that is already 4 years old, but, il seems I have the same problem that pep 75 had... i have both multifaceoffset.rb and offset.rb, but gives me the same error message, and doesnt offset... could TIG perhaps post the scripts that he sent to pep75 that where working? I need it!!!!! thanxxx
                          Here they are...OffestTools.zip
                            Avex
                            Hi all
                            I have a question, how can I get a rounded offset?
                            For doing something like that --->
                            • olisheaO
                              olishea
                              good question!!
                              This is a great plugin. I know a simple way to improve it.
                              After the plugin has executed the offsets....it should prompt the option:
                              "Keep the offset face selected=1 Keep original faces selected = 0" (as in yes/no)
                              Is this possible? It would allow JPP/scale (for example) immediately on offset faces, without having to select them all manually. Wings 3D has a similar feature with its multiple offset feature.
                              Or a plugin to select inverse faces of a mesh? ❓
                              oli
                                And about the round Plugin from a Polygon above?
                                And there from the selection of all polygons because make one by one is a little tiedous πŸ˜„
                                • olisheaO
                                  olishea
                                  I have a little difficulty understanding what you mean, Pilou.
                                  oli
                                    VoronoΓ― XY By Mattc
                                    http://www.3dsaloon.fr/phpbb3/download/file.php?id=3666
                                    Say I have that πŸ˜„
                                    But now how to "round" the polygons as asked 2 posts above by Avex 2 years ago? πŸ˜‰
                                    • olisheaO
                                      olishea
                                      Ahhhh.
                                      I would happily pay for a Voronoi TOS style plugin.
                                      Why not multiple offset and then Artisan? edit, maybe it's not so "true" though.
                                      oli
                                      • P
                                        parkmancarter
                                        I have the plugin working in SU8Pro, but only have the option to set the offset distance. What about all the other wild (and potentially very useful) options that appear in this video?
                                        The ability to keep faces or not, to do a sequence of offsets, etc... is this a different plugin??
                                          Multiple Offsets (list etc...) is by Sdmitch πŸ˜‰
                                          • 2 / 3
