    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 242.5k Views 61 Watching
      AH cool this new version ! 👍
      Whish there is the extrude along vector with selection at the end 😄 (yes it is!)
      Bravo 😎
      Ps Extrude along a vector will be absolutely terrific if "offset" (or tricky sign of vector) can be integrated when necessary!
      Maybe with CTRL pressed?
      Because if I use the normal offset I lost the selection for follow the extrude along a vector! 😮
      Allez Didier un dernier petit effort et c'est gagné! ☀
      • urgenU
        urgen
        ....many thanks Didier! 👍
        --pupil forever...------
        • massimoM
          massimo Moderator
          I've played a bit with tool n#5 with 4 divisions.
          Maybe another bug?
          • CadFatherC
            CadFather
            glad to see Didier is back.. Thanks Didier!
            • MALAISEM
              MALAISE
              Hi, Masters are back ! 👍 👍
              I'll try it very soon.
              MALAISE
              • Didier BurD
                Didier Bur
                Massimo,
                I cannot reproduce the division problem. How do you do it ?
                DB
                • I
                  ideas_arte
                  Many thank you very much ..!
                  If the first is very good, this is much much better ..!
                  Thanks friend ..! 😍
                  • massimoM
                    massimo Moderator
                    Really strange. I've tried again. Sometimes works and sometimes not. Simply draw a rectangle then pushpull. Copy the solid along the green axe and apply to the first solid "insert guide at divisions" horizontally (it works), press esc, and then apply to the second the tool vertically (sometimes it doesn't works). The same happens (never works) if you try to do that on a single face in order to have a grid (horizontally + vertically).
                    Maybe it's only my problem?
                    • Didier BurD
                      Didier Bur
                      Unfortunately I think it is your problem, because what you describe always work on my side...
                      DB
                      • mitcorbM
                        mitcorb
                        could it be camera position relative to horizon when selection is done? probably not, just wondering.
                        • massimoM
                          massimo Moderator
                          Unfortunately nothing to do with camera position, Mitcorb. Don't understand why but it simply doesn't work for me.
                            Any chance to integrate an "Offset" or similar in the "Extrude line along a vector"?
                            • massimoM
                              massimo Moderator
                              Hi Didier and thanks for your patience. When i use for the second time "insert guides at divisions" some lines are missed (very often the middle line) but i've noticed that if i click a little bit below the edge of the solid it works fine. Maybe this makes some sense to you?
                              • urgenU
                                urgen
                                ... hi Dider! ....is it possible to add old function "create lines at intersection of selected faces" in a script?...It's very useful function 😕 ....I do not want come back to old script "ClineAtFaceIntersection.rb" 😒
                                • Didier BurD
                                  Didier Bur
                                  OK, no problem, I was thinking this one were not so useful. I'll put it in next update.
                                  DB
                                  • urgenU
                                    urgen
                                    ....thanks,Didier! 😛
                                    ...For drawing of difficult roofs this function is very necessary 😉
                                    • Didier BurD
                                      Didier Bur
                                      Yes, it is due to the "automatic cleaner" bug. Bug was corrected yesterday, that's why this didn't happen here 😉
                                      DB
                                        rv1974
                                        Hi Didier!
                                        I can't make your new commands work.
                                        Some quotations from console:
                                        Error: #<NameError: uninitialized constant ProjectCpointTool>
                                        C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:47
                                        C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:47:in call' Error: #<NameError: uninitialized constant XLinesThrougLinesTool> C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:23 C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:23:in call'
                                        Any ideas what's wrong in my case?
                                        And thank you again and again for your contributions.
                                        • Didier BurD
                                          Didier Bur
                                          hi rv1974,
                                          your installation is incorrect. You must have a sub-folder "projections" under plugins after unzipping the archive. Check for it, i'm almost sure this is not the case 😉
                                          DB
                                            DIEGO-RODRIGUEZ
                                            Didier, thank you for this fantastic tool.
                                            But I have the same problem massimo, with guide lines
                                            • 1 / 8
