    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 236.1k Views 61 Watching
    • massimoM Offline
      massimo Moderator
      Hi Didier, first of all thanks for this great update (i especially like tools n#4 and n#5). I tried it quickly and i had two problems.
      1. In SU 6 i overwrote the folder and the .rb file on the older projections ones. I opened SU, the new toolbar was there but, with the exception of the point tool, nothing worked. So i deleted the .rb file and the folder from the plugins folder, i reinstalled them and that worked. But..
      2. The tool n#2 seems not working properly. The temporary display appears, but when i click on a face, for example on a cube face, the behaviour of the tool is strange. Sometimes it draws only 3 construction lines, sometimes nothing. The same happens with a line click.
        Maybe my fault?
        Thanks.
        Massimo.
        silver_shadow
        gonna give it a shot, thanx
          dmatho
          Ahhhh-mazing! Thanks Didier!
          Cheers,
          • Diego -
          • Didier BurD Offline
            Didier Bur
            Hi Massimo,
            You found the first bug !
            The automatic guides cleaner is guilty 🎉
            Let's wait a little for other bug reports, and I'll publish a patch.
            Thanks for reporting,
            DB
              AH cool this new version ! 👍
              Whish there is the extrude along vector with selection at the end 😄 (yes it is!)
              Bravo 😎
              Ps Extrude along a vector will be absolutely terrific if "offset" (or tricky sign of vector) can be integrated when necessary!
              Maybe with CTRL pressed?
              Because if I use the normal offset I lost the selection for follow the extrude along a vector! 😮
              Allez Didier un dernier petit effort et c'est gagné! ☀
              • urgenU Offline
                urgen
                ....many thanks Didier! 👍
                --pupil forever...------
                • massimoM Offline
                  massimo Moderator
                  I've played a bit with tool n#5 with 4 divisions.
                  Maybe another bug?
                  • CadFatherC Offline
                    CadFather
                    glad to see Didier is back.. Thanks Didier!
                    • MALAISEM Offline
                      MALAISE
                      Hi, Masters are back ! 👍 👍
                      I'll try it very soon.
                      MALAISE
                        Didier Bur
                        Massimo,
                        I cannot reproduce the division problem. How do you do it ?
                        DB
                        • I Offline
                          ideas_arte
                          Many thank you very much ..!
                          If the first is very good, this is much much better ..!
                          Thanks friend ..! 😍
                          • massimoM Offline
                            massimo Moderator
                            Really strange. I've tried again. Sometimes works and sometimes not. Simply draw a rectangle then pushpull. Copy the solid along the green axe and apply to the first solid "insert guide at divisions" horizontally (it works), press esc, and then apply to the second the tool vertically (sometimes it doesn't works). The same happens (never works) if you try to do that on a single face in order to have a grid (horizontally + vertically).
                            Maybe it's only my problem?
                              Didier Bur
                              Unfortunately I think it is your problem, because what you describe always work on my side...
                              DB
                              • mitcorbM Offline
                                mitcorb
                                could it be camera position relative to horizon when selection is done? probably not, just wondering.
                                • massimoM Offline
                                  massimo Moderator
                                  Unfortunately nothing to do with camera position, Mitcorb. Don't understand why but it simply doesn't work for me.
                                    Any chance to integrate an "Offset" or similar in the "Extrude line along a vector"?
                                    • massimoM Offline
                                      massimo Moderator
                                      Hi Didier and thanks for your patience. When i use for the second time "insert guides at divisions" some lines are missed (very often the middle line) but i've noticed that if i click a little bit below the edge of the solid it works fine. Maybe this makes some sense to you?
                                      • urgenU Offline
                                        urgen
                                        ... hi Dider! ....is it possible to add old function "create lines at intersection of selected faces" in a script?...It's very useful function 😕 ....I do not want come back to old script "ClineAtFaceIntersection.rb" 😒
                                          Didier Bur
                                          OK, no problem, I was thinking this one were not so useful. I'll put it in next update.
                                          DB
                                          • urgenU Offline
                                            urgen
                                            ....thanks,Didier! 😛
                                            ...For drawing of difficult roofs this function is very necessary 😉
                                            • 1 / 8
