    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 224.8k Views 61 Watching
    • Didier BurD Offline
      Didier Bur
      Hi Massimo,
      You found the first bug !
      The automatic guides cleaner is guilty ๐ŸŽ‰
      Let's wait a little for other bug reports, and I'll publish a patch.
      Thanks for reporting,
      DB
        AH cool this new version ! ๐Ÿ‘
        Whish there is the extrude along vector with selection at the end ๐Ÿ˜„ (yes it is!)
        Bravo ๐Ÿ˜Ž
        Ps Extrude along a vector will be absolutely terrific if "offset" (or tricky sign of vector) can be integrated when necessary!
        Maybe with CTRL pressed?
        Because if I use the normal offset I lost the selection for follow the extrude along a vector! ๐Ÿ˜ฎ
        Allez Didier un dernier petit effort et c'est gagnรฉ! โ˜€
        • urgenU Offline
          urgen
          ....many thanks Didier! ๐Ÿ‘
          --pupil forever...------
          • massimoM Offline
            massimo Moderator
            I've played a bit with tool n#5 with 4 divisions.
            Maybe another bug?
            • CadFatherC Offline
              CadFather
              glad to see Didier is back.. Thanks Didier!
              • MALAISEM Offline
                MALAISE
                Hi, Masters are back ! ๐Ÿ‘ ๐Ÿ‘
                I'll try it very soon.
                MALAISE
                La Connaissance n'a de valeur que partagรฉe
                  Didier Bur
                  Massimo,
                  I cannot reproduce the division problem. How do you do it ?
                  DB
                  • I Offline
                    ideas_arte
                    Many thank you very much ..!
                    If the first is very good, this is much much better ..!
                    Thanks friend ..! ๐Ÿ˜
                    • massimoM Offline
                      massimo Moderator
                      Really strange. I've tried again. Sometimes works and sometimes not. Simply draw a rectangle then pushpull. Copy the solid along the green axe and apply to the first solid "insert guide at divisions" horizontally (it works), press esc, and then apply to the second the tool vertically (sometimes it doesn't works). The same happens (never works) if you try to do that on a single face in order to have a grid (horizontally + vertically).
                      Maybe it's only my problem?
                        Didier Bur
                        Unfortunately I think it is your problem, because what you describe always work on my side...
                        DB
                        • mitcorbM Offline
                          mitcorb
                          could it be camera position relative to horizon when selection is done? probably not, just wondering.
                          • massimoM Offline
                            massimo Moderator
                            Unfortunately nothing to do with camera position, Mitcorb. Don't understand why but it simply doesn't work for me.
                              Any chance to integrate an "Offset" or similar in the "Extrude line along a vector"?
                              • massimoM Offline
                                massimo Moderator
                                Hi Didier and thanks for your patience. When i use for the second time "insert guides at divisions" some lines are missed (very often the middle line) but i've noticed that if i click a little bit below the edge of the solid it works fine. Maybe this makes some sense to you?
                                • urgenU Offline
                                  urgen
                                  ... hi Dider! ....is it possible to add old function "create lines at intersection of selected faces" in a script?...It's very useful function ๐Ÿ˜• ....I do not want come back to old script "ClineAtFaceIntersection.rb" ๐Ÿ˜’
                                    Didier Bur
                                    OK, no problem, I was thinking this one were not so useful. I'll put it in next update.
                                    DB
                                    • urgenU Offline
                                      urgen
                                      ....thanks,Didier! ๐Ÿ˜›
                                      ...For drawing of difficult roofs this function is very necessary ๐Ÿ˜‰
                                        Didier Bur
                                        Yes, it is due to the "automatic cleaner" bug. Bug was corrected yesterday, that's why this didn't happen here ๐Ÿ˜‰
                                        DB
                                          rv1974
                                          Hi Didier!
                                          I can't make your new commands work.
                                          Some quotations from console:
                                          Error: #<NameError: uninitialized constant ProjectCpointTool>
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:47
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:47:in call' Error: #<NameError: uninitialized constant XLinesThrougLinesTool> C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:23 C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:23:in call'
                                          Any ideas what's wrong in my case?
                                          And thank you again and again for your contributions.
                                            Didier Bur
                                            hi rv1974,
                                            your installation is incorrect. You must have a sub-folder "projections" under plugins after unzipping the archive. Check for it, i'm almost sure this is not the case ๐Ÿ˜‰
                                            DB
                                            • 1 / 8
