    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 242.5k Views 61 Watching
    • CadFatherC
      CadFather
      glad to see Didier is back.. Thanks Didier!
      • MALAISEM
        MALAISE
        Hi, Masters are back ! 👍 👍
        I'll try it very soon.
        MALAISE
        • Didier BurD
          Didier Bur
          Massimo,
          I cannot reproduce the division problem. How do you do it ?
          DB
          • I
            ideas_arte
            Many thank you very much ..!
            If the first is very good, this is much much better ..!
            Thanks friend ..! 😍
            • massimoM
              massimo Moderator
              Really strange. I've tried again. Sometimes works and sometimes not. Simply draw a rectangle then pushpull. Copy the solid along the green axe and apply to the first solid "insert guide at divisions" horizontally (it works), press esc, and then apply to the second the tool vertically (sometimes it doesn't works). The same happens (never works) if you try to do that on a single face in order to have a grid (horizontally + vertically).
              Maybe it's only my problem?
              • Didier BurD
                Didier Bur
                Unfortunately I think it is your problem, because what you describe always work on my side...
                DB
                • mitcorbM
                  mitcorb
                  could it be camera position relative to horizon when selection is done? probably not, just wondering.
                  • massimoM
                    massimo Moderator
                    Unfortunately nothing to do with camera position, Mitcorb. Don't understand why but it simply doesn't work for me.
                      Any chance to integrate an "Offset" or similar in the "Extrude line along a vector"?
                      • massimoM
                        massimo Moderator
                        Hi Didier and thanks for your patience. When i use for the second time "insert guides at divisions" some lines are missed (very often the middle line) but i've noticed that if i click a little bit below the edge of the solid it works fine. Maybe this makes some sense to you?
                        • urgenU
                          urgen
                          ... hi Dider! ....is it possible to add old function "create lines at intersection of selected faces" in a script?...It's very useful function 😕 ....I do not want come back to old script "ClineAtFaceIntersection.rb" 😒
                          --pupil forever...------
                          • Didier BurD
                            Didier Bur
                            OK, no problem, I was thinking this one were not so useful. I'll put it in next update.
                            DB
                            • urgenU
                              urgen
                              ....thanks,Didier! 😛
                              ...For drawing of difficult roofs this function is very necessary 😉
                              • Didier BurD
                                Didier Bur
                                Yes, it is due to the "automatic cleaner" bug. Bug was corrected yesterday, that's why this didn't happen here 😉
                                DB
                                  rv1974
                                  Hi Didier!
                                  I can't make your new commands work.
                                  Some quotations from console:
                                  Error: #<NameError: uninitialized constant ProjectCpointTool>
                                  C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:47
                                  C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:47:in call' Error: #<NameError: uninitialized constant XLinesThrougLinesTool> C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:23 C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:23:in call'
                                  Any ideas what's wrong in my case?
                                  And thank you again and again for your contributions.
                                  • Didier BurD
                                    Didier Bur
                                    hi rv1974,
                                    your installation is incorrect. You must have a sub-folder "projections" under plugins after unzipping the archive. Check for it, i'm almost sure this is not the case 😉
                                    DB
                                      DIEGO-RODRIGUEZ
                                      Didier, thank you for this fantastic tool.
                                      But I have the same problem massimo, with guide lines
                                        rv1974
                                        @didier bur said:
                                        hi rv1974,
                                        For a 1st sight everything is OK. In fact I have your toolbar and the point tool working (one single click though)
                                        • Didier BurD
                                          Didier Bur
                                          Yes but I also see that you have another 'projection.rb' file which is the previous version. Do a clean install, removing ALL previous files in the Projections folder, and everything will go OK.
                                          Regards,
                                          DB
                                          • massimoM
                                            massimo Moderator
                                            Thanks Didier, now it works very well. 👍
                                            • 1 / 8
