    New API doc - typos and questions
    370 Posts 35 Posters 295.6k Views 35 Watching
      Face.mesh
      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#mesh
      The mesh method creates a polygon mesh that represents the face. See the PolygonMesh class for more information.
      Valid flags are:
      * 0: Include PolygonMeshPoints,
      * 1: Include PolygonMeshUVQFront,
      * 2: Include PolygonMeshUVQBack,
      * 4: Include PolygonMeshNormals.
      Add these numbers together to combine flags. A value of 5 will include all flags, for example.
      The example uses 7. Typo or undocumented feature?
        avariant
        You can bit-wise OR the options together. 7 means 4 + 2 + 1, so normals, front UV, and back UV.
          remus
          For acolor it's always = 255 [100% opaque]... there is a color.alpha= method but it's never ever worked, you must set alpha [transparency] for a material itself not material.color e.g. material.alpha=0.4 for 40% opacity will work but the material.color.alpha still reports 255 [100%], if you try to change it, it just does nothing !
          So to recap - the fourth item in a SUp material.color array is its alpha [r,g,b,a] but it's not used ! The alpha of the material itself works as a 0 to 1.0, equivalent to % setting of opacity...
          http://code.google.com/apis/sketchup/do ... color.html
            UI.inputbox
            http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#inputbox
            Returns false, not nil when user cancels.
              WebDialog.new
              http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#new
              Two last parameters isn't explained.
                remus
                BoundingBox.min
                returns: a Point3d object representing the point where x, y, and z are the maximum in the bounding box.
                Im guessing it should say minimum.
                  WebDialog.get_element_value
                  http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#get_element_value
                  The example hasn't escaped the HTML tags - so the HTML sample text is instead interpreted by the browser..
                    Curve.move_vertices
                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/curve.html#move_vertices
                    Description says:
                    The vertices method retrieves a collection of all vertices in a curve.
                      Tool.enableVCB?
                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/tool.html#enableVCB?
                      The enableVCB? method is used to tell SketchUp whether to allow the user to enter text into the VCB (value control box, aka the "measurements" panel). If you do not implement this method, then the vcb is disabled by default.
                      I've never used this method for my Tools. But the VCB has still worked.
                        Image.size=
                        http://code.google.com/apis/sketchup/docs/ourdoc/image.html#size=
                        It appears that the second argument is optional.
                          Entity.entityID
                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entity.html#entityID
                          The entityID method is used to retrieve a unique ID assigned to an entity.
                          The entityID is not persistent between sessions.
                          Is it persistent within a session? Can it be relied on for the length of one session?
                            ComponentDefinition.guid
                            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/componentdefinition.html#guid
                            Is this value persistent between sessions?
                              Jim
                              Sketchup::Color.new
                              new can accept a hex value (not string) as the parameter: for example 0xFF0000 (undocumented)
                              But, it reverses the red and blue values. Here is a Console session. (bug)
                              Sketchup;;Color.new 0xFF0000
                              Color(  0,   0, 255, 255)
                              Sketchup;;Color.new 0x0000FF
                              Color(255,   0,   0, 255)
                              • scottliningerS Offline
                                scottlininger
                                I've got some catching up to do. Thanks for all of the details, guys! 😉
                                • Scott Lininger
                                  SketchUp Software Engineer
                                  Have you visited the Ruby API Docs?
                                  ModelObserver.onDeleteModel vs ModelObserver.onEraseAll
                                  http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onDeleteModel
                                  When does the onDeleteModel event trigger? I don't think I've ever seen it trigger. When I open an existing model or create a new model onEraseAll is triggered.
                                    Jim
                                    UI.start_timer
                                    This post on the API blog is showing start_timer with a fraction of a second resolution. In my experience, UI.start_timer has a whole second resolution and rounds partial seconds down to the nearest second.
                                        t1=Time.now; UI.start_timer(0.1) {p Time.now-t1} ==> 0.01
                                        t1=Time.now; UI.start_timer(0.999) {p Time.now-t1} ==> 0.01
                                        t1=Time.now; UI.start_timer(1) {p Time.now-t1} ==> 1.001
                                        t1=Time.now; UI.start_timer(1.9) {p Time.now-t1} ==> 1.002
                                      Jim
                                      Point3d.linear_combination
                                      Uses example from Geom.linear_combination.
                                      I would guess the Point3d.linear_combination would only take 2 arguments - the weight, and other point since the first point is the receiver of the method.
                                        MaterialsObserver
                                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/materialsobserver.html
                                        Observer events that doesn't trigger:
                                        Sketchup 6
                                        onMaterialChange*
                                        onMaterialRefChange
                                        Sketchup 7
                                        onMaterialChange*
                                        onMaterialRefChange
                                        onMaterialSetCurrent
                                        • Only triggers when the name changes. Not when any of the other properties changes.
                                          Jim
                                          Group.move!
                                          This method is the same as the transform! method except that it does not record the move in an undo operation. This method is useful for transparently moving things during an animation.
                                          .move! resets the rotational and scaling components of the receiver's transformation, and does not result in the same final translation as using .transform!
                                            Layer.page_behavior vs Layer.page_behavior=
                                            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior
                                            The flag values seems to contradict between descriptions of the two methods.
                                            • 18
                                            • 19
                                            • 7 / 19
