    Leopard hang fix
    80 Posts 53 Posters 33.0k Views 53 Watching
    • I Offline
      inio
      @edson said:
      does it work for the latest build (10035)? is it restricted to Intel GMA950 graphics? it seems that the same problem afflicts other macs running 10.5.6 as well.
      There should't be anything build-specific about the patch. It just causes a certain OpenGL call (glClear) to make an extra call (CGLFlushDrawable) when it's called after drawing to the front buffer. As long as SketchUp follows the same call pattern, it should continue working.
      It's possible that this bug exists in other drivers. I'll test on a current-gen MacBook tonight if I remember. Other than that I don't have any other Intel macs available.
      • EdsonE Offline
        Edson
        thanks. for what it is worth, i own an intel macbook pro 2.4ghz and its graphic card is the geforce 8600M GT.
        http://www.mahfuz.arq.br
          bjanzen
          1. Make sure you're not affected by http://support.apple.com/kb/TS2377.
          2. We also look at http://developer.apple.com/graphicsimaging/opengl/capabilities/ but you should be OK with that list.
          3. Send me the model, steps to test, and time, and I'll write an automation script to repeat it and time it with multiple tries.
          4. Look at Mitchel's 3D Basecamp presentation on working with large models: http://www.youtube.com/watch?v=hnhkei2dSrY if it's not hardware related.
          Hope that helps.
          b
            lehieu1810
            My Macbook Pro T9300 2.5Ghz,4GB RAM, VGA 8600M GT,Leopard 10.5.7 run SU 6 & 7 very slow,in rotate,move,....(working on a large model).I try Thawup,maybe it not work, I don't see different.
            In Window,SU run smooth!! Maybe VGA driver support for MAC not good!
            Any ideas ???
            • Chris FullmerC Offline
              Hi Lehieu, you can try updating your Mac video card drivers directly from the video card makers website. Also, there's no need to write in bold like that. We can all read it even easier if its plain type. Thanks
              • EdsonE Offline
                Edson
                chris,
                there is no update for mac drivers at the makers' site. it seems that only PC drivers can be updated.
                • jeff hammondJ Offline
                  right. nvidia, for instance, doesn't develop OS X drivers and they are provided by apple. The driver updates are included with the normal software updates.
                  It's probably just a case of a big SU model acting sluggish and lehieu didn't actually say the same exact model is smooth with windows but not on his mac..
                  i'd be interested in knowing how large the model is (model info->stats)
                  • EdsonE Offline
                    Edson
                    there is also the issue of model organisation. if he does not use layers and scenes to organise the model and its visualisation no graphics card will be able to handle it.
                      anugill333
                      thank you....worked like a charm
                        lehieu1810
                        I was reinstall MAC OS 10.5.6 (come back from 10.5.7) and install SU7,SU6,ThawUp (Thawup is only install in SU6 folder).Sketchup on MAC OSX still working slow (in rotate,view...action,fps is down). In Win,it's faster,smooth (on large model). I don't know the problem ?? Who can help me??
                        Macbook Pro 2.5ghz, VGA 8600M GT
                          lehieu1810
                          Who can help me ??
                            RHD
                            Just installed it. You total star! I've lived with is bug so long I've got used to it.
                            I'm usually just grateful if SketchUp doesn't crash. It's a great program but massively unstable on Mac OS which is a huge shame.
                            Your patch has speeded up performance on big files amazingly too.
                              minicrazy592
                              Sketch Up still hanging after install on OSX 10.5.7. Thaw Up seems to work for me and sometimes not. It's extremely frustrating when I am trying to do a project. I've done the Leopard graphics update at 10.5.2 and installed Thaw Up shortly after. The problem really hasn't seemed to go away all up to now. Any ideas?
                              Specs:
                              Model Name: Mac mini
                              Model Identifier: Macmini2,1 (Late 2007)
                              Processor Name: Intel Core 2 Duo
                              Processor Speed: 1.83 GHz
                              Number Of Processors: 1
                              Total Number Of Cores: 2
                              L2 Cache: 2 MB
                              Memory: 4 GB-hangs and crashes don't last nearly as long as when I had 1GB lol
                              Bus Speed: 667 MHz
                              Boot ROM Version: MM21.009A.B00
                              SMC Version (system): 1.19f2
                              Also I have a partition of an early Snow Leopard developer edition (Build 10a222). It still seems persistent in there as well.
                                gvelis28
                                I have this same issue on my Macbook. My setup is: GMA x3100 video card v10.5.7
                                Hardware Overview:
                                Model Name: MacBook
                                Model Identifier: MacBook4,1
                                Processor Speed: 2.4 GHz
                                L2 Cache: 3 MB
                                Memory: 4 GB
                                Bus Speed: 800 MHz
                                Boot ROM Version: MB41.00C1.B00
                                SMC Version (system): 1.31f0
                                I am working on a very basic sketchup model, I get a long lag time when I selected an area with the rectangle tool. I tried the Thawupinstallerbut it did not seem to help. Anyone know anything else that could be the root of this problem? Since I'm using SU7 will this not work for it? Thanks.
                                  anttisykari
                                  I'm experiencing hangs as well; the usually occur when trying to select a line. The hangs take about 10 seconds. They occur only when "Hardware acceleration" is ticked in Preferences. Installing the ThawUp patch did not help.
                                  Sketchup version: 7.0.10248
                                  Video chipset: GMA X3100
                                  Model Name: MacBook
                                  Processor Speed: 2.1 GHz
                                  L2 Cache: 3 MB
                                  Memory: 4 GB
                                  Bus Speed: 800 MHz
                                    peter s
                                    hi&thanks for this great patch!
                                    i got pretty frustrated to see that my old p4 pc running sketchup on winxp easily outperforms my macbook due to the mentioned freezes...
                                    disabling fast feedback only did not help. if i disable hw acceleration, the freezes vanish. but of course you get visibly better performance using the patch. (btw, rotating large structures without hw accel on the mac looks about as "smooth" as with hw accel on the mentioned pc with geforce fx 5200 go)
                                    details:
                                    Model Name: MacBook
                                    L2 Cache: 3 MB
                                    Memory: 2 GB
                                    Bus Speed: 800 MHz
                                    running SketchUp 7 (7.0.10938) on Mac OS X 10.5.8
                                    i wonder if 10.6 works any better - according to http://developer.apple.com/graphicsimaging/opengl/capabilities/ opengl implementetion has been worked on since 10.5.8 (version 2.0 for gma x3100 and 1.4 for gma 950 instead of 1.2 for both in leopard).
                                    regards
                                    peter
                                    • 2 / 4
